Tienes que encender el controlador con la tecla "P" precio nada, ahí se accede a los comandos de programación. Luego sigues apretando "P" hasta que aparecen las letras SL (speed low),luego apretas P de nuevo y aparece 16, ahí con el botón de abajo de P puedes ir variando el número hasta 03 lo más lento que se puede luego vuelves a apague el controlador hasta que se apaguen todos los indicadores. Luego enciendes de nuevo y verifica la velocidad. pintoramirezdaniel@gmail.com
+56976461320
  • Replies 27
  • Created
  • Last Reply
Top Posters In This Topic
@dikman it is Spanish and says:
You have to turn on the controller with the "P" key, nothing, there you access the programming commands. Then you continue pressing "P" until the letters SL (speed low) appear, then you press P again and 16 appears, there with the button below P you can vary the number up to 03 as slow as possible then you return to Turn off the controller until all indicators turn off. Then turn it on again and check the speed. painteramirezdaniel@gmail.com
kgg
Thanks mate, I couldn't be bothered trying to translate it. Why must people post in a different language when it's obviously an English-speaking forum?  Presumably the poster understands English to be able to comment in the first place?:dunno:
+56976461320
English is the language for this forum.  Please comply.  We are happy to have your input.
Here is a link to Google Translate. You can input any language and translate it into English, or any other supported language. I use it to read and reply to non-English posts asking for assistance. It is fast and easy to use if you know how to copy and paste.
Please don't shoot the messenger. I'm just offering a solution.
Posted IMHO, by Wiz
if you highlight text & right click, chrome has translate in menu.
Edited by 1hp
more info
Wiz, why would I want to shoot you? :lol: You're far to valuable on here.;)
