On 10/10/2020 at 3:08 PM, $$hobby said:
regarding conveyor belt...
you may want to be careful on whats IN the belt.  Some may have some steel webbing inside.
Very true, that's why I tell them I'm using it as a cutting mat.
  • Replies 21
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
I use a 12 inch self healing cutting match.  It does not leave an imprint from previous cutting and your knife will not get bogged done in a previous cut.  I've found them on Amazon.  My newest mat is 36 X 48 for when I'm cutting large selections of leather.
I've ordered one of these. There is a conveyor belt piece on Ebay that'a slightly more expensive but I was drawn to this one.
https://www.ebay.co.uk/itm/HDPE-Sheet-NATURAL-BLACK-High-Density-Polyethylene-PEHD-Polythene-mm/401002482629?ssPageName=STRK%3AMEBIDX%3AIT&var=670531748255&_trksid=p2057872.m2749.l2649
And because I make the dies with a wood core I'll just have to make sure the thickness doesn't allow the knife to go too deep.
  • 1 month later...
1 hour ago, Danne said:
Thanks Danne. The HDPE one that I ordered turned out good. No give in it but soft enough surface to not damage the dies. I put a longer bar in my arbor press with a decent spring on the back end and the ease of use now is great.
I think you made a good choice. I guess you bought a regular HDPE-board, not specifically made for dye cutting? And my guess is that those Hydroma boards I linked too cost a lot more, and for a company that use them like eight hours a day it can probably be worth spending the extra money, but for more "normal use" my guess is that your board will do the job for a long time (Amateur thoughts here, because I have no experience with dye cutting)
It was Fred that suggested it. I was skeptical because that's what milk cartons are made of but I guess there are different grades.
  • CFM
Before the fire I had an old school mud flap from a semi that I used to cut on. The fronts sometimes have molded logos, but the backs are flat.
I should add that we lost everything in a wildfire 8 years ago. THAT fire.
Edited by tsunkasapa
Can't think of anything worse that those fires. Hope your losses were only material.
  • CFM
We lost one cat about 4 days after, smoke damage? All other animals (us included) made it through. Everything else was just "stuff". Some was important, some was sentimental, some was expensive. But it was still just stuff. Life is now as normal as it ever gets around here. :crazy:
