ewayne53 Report post Posted December 5, 2020 I want to make a belt for my son-in-law but I don't have a single length of leather to make the entire belt. I need some ideas on how to make a design or something that doesn't look tacky to make the belt. Like maybe adding billets on the buckle and/or the tip end. Any ideas or patterns are greatly appreciated. Thank you and God bless. Quote Share this post Link to post Share on other sites
Aven Report post Posted December 5, 2020 How much longer do you need to make the belt? Quote Share this post Link to post Share on other sites
ewayne53 Report post Posted December 5, 2020 I would have to measure again but 6-10" Quote Share this post Link to post Share on other sites
fredk Report post Posted December 5, 2020 Make 1 piece for going around the sides and back of the waist. Make it wide, say 1 3/4 inches, then make two shorter end pieces, maybe 1 or 1 1/4 inch wide and sew to the wider piece. Quote Share this post Link to post Share on other sites
jcuk Report post Posted December 5, 2020 Here is a couple of designs that may give you some ideas. https://www.equusleather.co.uk/belts/the-guards-belt.html http://www.christopherlong.co.uk/gal/Leatherwork/slides/20180228 Stable Belt Leather Heavy Buckle Elastic 04.jpg Hope this helps JCUK Quote Share this post Link to post Share on other sites
ewayne53 Report post Posted December 5, 2020 I thought about making something like a ranger belt design but making the main body of the belt stop short of the buckle and tip. Quote Share this post Link to post Share on other sites
toxo Report post Posted December 5, 2020 How about a long skive, say 6/7 inches glued and stitched making sure the outside skived edge is bang in the center of the back and then cover it with some tooling or a patch? Quote Share this post Link to post Share on other sites
Ed in Tx Report post Posted December 5, 2020 A Ranger style belt would be the best way to go in my opinion. Even with that the main part of the belt should be a bit larger than the persons waist size. A small amount of overlap is best. Quote Share this post Link to post Share on other sites
MikeRock Report post Posted December 5, 2020 Ed, Thanks for that tip. God bless Quote Share this post Link to post Share on other sites
Rahere Report post Posted December 6, 2020 The only decorative way is to put vertical lines of chisel cuts in, about 1/4" long, spaced by 1/4" between lines and the same apart, staggered | | | | | | | | so they open like a mesh. However, it's not recommended! Quote Share this post Link to post Share on other sites
