Members patmcf1 Posted December 8, 2021 Members Report Posted December 8, 2021 Here's one place to purchase 3M polishing sandpaper... https://www.stewmac.com/luthier-tools-and-supplies/supplies/sanding-and-polishing/sandpaper-and-finishing-papers/3m-flexible-polishing-papers/?utm_source=google&utm_medium=shopping&utm_campaign=2021-12-gp&gclid=Cj0KCQiAqbyNBhC2ARIsALDwAsBvtL1IcZSJKgs6hifG7l7ixBRXWPKPmHAaW_8Xlj1vwx3d-zgFT-UaAqpTEALw_wcB Quote
Members Davm Posted December 13, 2021 Members Report Posted December 13, 2021 I also make knives and use a green chrome rouge to polish to a mirror finish, so...I applied that to my strop. IMHO if you are drawing the edge toward you when stropping the idea is to remove tiny burs and sucjh and the angle doesn't have to be quite as precise as when actually honing on a stone. Texas Knife makers Supply should have the green chrome. Quote
Members JayEhl Posted January 14, 2022 Members Report Posted January 14, 2022 Hi, While here, I have a question about the polishing compound, more specifically what is the consistency supposed to be like? I know a few will cringe when I say I am still using the white compound from my starter kit from Tandy. It is hard as a rock and I have to rub kind of aggressively to get it on my cardboard backing (what I normally use). Should it be that hard? And I've read somewhere that different colors offer contains different material used for the sharpening, but what color is best for ceramic v metal blades? And what should the consistency be like out of the box, meaning, if it's supposed to be hard as a rock. Thanks in advance. Quote
CFM tsunkasapa Posted January 14, 2022 CFM Report Posted January 14, 2022 I have three colors, white, red and green. And they are all fairly hard. Personally, I like the green. It is what my friends that make knives use. Quote Hoka Hey! Today, tomorrow, next week, what does it matter?
Members DrmCa Posted January 14, 2022 Members Report Posted January 14, 2022 What material are ceramic blades made of? (Please, do not say, ceramics!) If they are made of anything like alumina then they can be stropped with tungsten carbide or boron carbide compound. If they are made of tungsten carbide then they can only be stropped with diamonds. It would be a waste of time to try to strop an alumina blade on alumina-based or chromium oxide compound because their hardness is pretty much the same, and there will be nearly zero grinding effect. TC tool bits can only be re-sharpened on a diamond wheel. They would chew through anything else. Quote Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
