Members FellowLeathersmith Posted March 22, 2021 Members Report Posted March 22, 2021 Hello! First post and thank you for accepting me to this community. I'm looking a sewing machine that doesn't take too much space. I'm mainly sewing belts and wallets as of now, but I'm hoping to get into making sheaths for kitchen knives and such. I've been looking at Sailrite leather sewing machines, but I am open to suggestions as well. Thank you! Quote
Members Aven Posted March 23, 2021 Members Report Posted March 23, 2021 Welcome to the forum Fellowleathersmith. I hate to be the bearer of bad news, but you will need to pick one either belts/sheaths or wallets. No machine is going to do them both. There is a world of difference between the total leather thickness for belts and for wallets. And that difference will require different machines. So... which one do you do more of, want to do more of? Which one can you do by hand? Quote
Members FellowLeathersmith Posted March 23, 2021 Author Members Report Posted March 23, 2021 I tend to do more small goods like wallets and such. The belts/sheaths I can do by hand. If wanted to do more small leather goods, what is the sewing machine I should look into or a sewing machine for belts and sheaths? Quote
Uwe Posted March 23, 2021 Report Posted March 23, 2021 (edited) The Juki LU-1508NH may be a machine that can cover the projects you describe. The original is available from Juki and there are clones/copies of this design available under various brand names. There are several versions of the basic 1508 design (N, NS, NH, etc.)- you want the NH version. It may not be the cheapest design, but it sure would be cheaper than two separate machines. Since you have space limitations, this might be a good candidate to investigate. The video below shows the Titan branded clone, and they demo sewing both Tex70 and Tex277 thread, very few machines can handle that wide of a range. That should cover wallets to belts and likely knife sheaths, depending of what type of leather you intend to use. A good servo motor and speed reducer will be essential. Artisan is another clone vendor. They are based in California and call their version the Artisan 1508-10H: http://artisansew.com/walkingfootmachine.html Perhaps Artisan are in day trip distance from you. Buying a machine from a local-ish dealer is kind of a big deal, especially when it comes time to service it. Being able to try out the machine and pick it up in person is just priceless. Edited March 23, 2021 by Uwe Quote
Members FellowLeathersmith Posted March 23, 2021 Author Members Report Posted March 23, 2021 1 hour ago, Uwe said: The Juki LU-1508NH may be a machine that can cover the projects you describe. The original is available from Juki and there are clones/copies of this design available under various brand names. There are several versions of the basic 1508 design (N, NS, NH, etc.)- you want the NH version. It may not be the cheapest design, but it sure would be cheaper than two separate machines. Since you have space limitations, this might be a good candidate to investigate. The video below shows the Titan branded clone, and they demo sewing both Tex70 and Tex277 thread, very few machines can handle that wide of a range. That should cover wallets to belts and likely knife sheaths, depending of what type of leather you intend to use. A good servo motor and speed reducer will be essential. Artisan is another clone vendor. They are based in California and call their version the Artisan 1508-10H: http://artisansew.com/walkingfootmachine.html Perhaps Artisan are in day trip distance from you. Buying a machine from a local-ish dealer is kind of a big deal, especially when it comes time to service it. Being able to try out the machine and pick it up in person is just priceless. Thank you for the suggestion!!! I was looking at Sailrite's Leather sewing machine and I was wondering what is your take on that machine or just in general! Quote
Uwe Posted March 23, 2021 Report Posted March 23, 2021 The Sailrite machines are okay for certain projects, they’re even perfect in certain situations (e.g. repairing a sail on your boat in the middle of the Atlantic). They are comparatively cheap and certainly portable. They enjoy great marketing. But you get what you pay for. They are not on the same level as other true industrial machines in terms of design and build strength.I doubt you will find a Sailrite in an actual factory (save for the occasional car upholstery shop.) If you can make them work you, then you can a save a little money and a lot of space. Alas, you won’t find too many glowing reviews of Sailrite machines here on LW. Quote
Members FellowLeathersmith Posted March 23, 2021 Author Members Report Posted March 23, 2021 36 minutes ago, Uwe said: The Sailrite machines are okay for certain projects, they’re even perfect in certain situations (e.g. repairing a sail on your boat in the middle of the Atlantic). They are comparatively cheap and certainly portable. They enjoy great marketing. But you get what you pay for. They are not on the same level as other true industrial machines in terms of design and build strength.I doubt you will find a Sailrite in an actual factory (save for the occasional car upholstery shop.) If you can make them work you, then you can a save a little money and a lot of space. Alas, you won’t find too many glowing reviews of Sailrite machines here on LW. Yes I've been looking through for reviews, but very few that I've seen. Its tough because I don't have much space and the size of the Sailrite is perfect. I just don't think I can accommodate the table for the 1508. Quote
kgg Posted March 23, 2021 Report Posted March 23, 2021 As listed in their menu "Leatherwork sewing machine" These are just a their portable LS model painted green instead of the rust brown with a maximum thread size of V92. However they did table mounted them on a nice compact table and coupled it with a nice servo motor on it. They use to be marketed through Tandy. These portable sewing machines were intended for repairing sail canvas. Keeping presser foot / feed dog marks/indentations from you leather is going to be difficult. I think for what you want to sew, you would be disappointed with the performance / ability. If you are really dead set on that type of machine an alternative is the Reliable Barracuda and at about $500 US. You could then buy a servo motor and build a small table to sit it in. I agree and disagree with UWE on the the Juki 1508 or its clones. I found that with my Juki 1541S which is down from the 1508 capability wise that if I was doing thick stuff it was great. When it came to thinner stuff I had to spend to much time in dumbing it down and then reverse the process to do thick stuff again. So to do thin stuff I bought a Juki 1181N, that machine covers off the thinner stuff and leaves the 1541S to do what it was good at. The 1508 will do your sheaths and more but on wallets I think it would be over kill. I would agree with Uwe buying as local as possible and being able to test drive a machine is invaluable. kgg Quote
Members nylonRigging Posted March 23, 2021 Members Report Posted March 23, 2021 47 minutes ago, FellowLeathersmith said: Yes I've been looking through for reviews, but very few that I've seen. Its tough because I don't have much space and the size of the Sailrite is perfect. I just don't think I can accommodate the table for the 1508. ( depending on machine model ) .. what about a shorter length table-top set-up ?. . Or a half table top with a left-side hinged drop leaf, to swing up/down when needed ? . Quote
Members FellowLeathersmith Posted March 23, 2021 Author Members Report Posted March 23, 2021 26 minutes ago, kgg said: As listed in their menu "Leatherwork sewing machine" These are just a their portable LS model painted green instead of the rust brown with a maximum thread size of V92. However they did table mounted them on a nice compact table and coupled it with a nice servo motor on it. They use to be marketed through Tandy. These portable sewing machines were intended for repairing sail canvas. Keeping presser foot / feed dog marks/indentations from you leather is going to be difficult. I think for what you want to sew, you would be disappointed with the performance / ability. If you are really dead set on that type of machine an alternative is the Reliable Barracuda and at about $500 US. You could then buy a servo motor and build a small table to sit it in. I agree and disagree with UWE on the the Juki 1508 or its clones. I found that with my Juki 1541S which is down from the 1508 capability wise that if I was doing thick stuff it was great. When it came to thinner stuff I had to spend to much time in dumbing it down and then reverse the process to do thick stuff again. So to do thin stuff I bought a Juki 1181N, that machine covers off the thinner stuff and leaves the 1541S to do what it was good at. The 1508 will do your sheaths and more but on wallets I think it would be over kill. I would agree with Uwe buying as local as possible and being able to test drive a machine is invaluable. kgg Very interesting! Thank you for the advice! Quote
DonInReno Posted March 23, 2021 Report Posted March 23, 2021 The photos are scattered about and impossible to search for it seems, but many people in your situation have cobbled together sewing tables for full size machines that can be used on a kitchen table and hid in a closet or under a bed when not being used. The major downside to this is the high weight of a full size industrial - 50 lbs is awkward to carry and dropping one can cause considerable damage. If you had a sailrite machine set up next to a full size and used them both it wouldn’t take long for the full size to be the favorite. Artisan is one of the few that has a table top setup for cylinder bed machines. Quote
Members FellowLeathersmith Posted March 23, 2021 Author Members Report Posted March 23, 2021 16 hours ago, nylonRigging said: ( depending on machine model ) .. what about a shorter length table-top set-up ?. . Or a half table top with a left-side hinged drop leaf, to swing up/down when needed ? . Yes that would be something I would look into on that! Quote
Members FellowLeathersmith Posted March 23, 2021 Author Members Report Posted March 23, 2021 8 hours ago, DonInReno said: The photos are scattered about and impossible to search for it seems, but many people in your situation have cobbled together sewing tables for full size machines that can be used on a kitchen table and hid in a closet or under a bed when not being used. The major downside to this is the high weight of a full size industrial - 50 lbs is awkward to carry and dropping one can cause considerable damage. If you had a sailrite machine set up next to a full size and used them both it wouldn’t take long for the full size to be the favorite. Artisan is one of the few that has a table top setup for cylinder bed machines. Thank you for your suggestion. I'll definitely look into it! Quote
Members sbrownn Posted March 23, 2021 Members Report Posted March 23, 2021 23 hours ago, Aven said: Welcome to the forum Fellowleathersmith. I hate to be the bearer of bad news, but you will need to pick one either belts/sheaths or wallets. No machine is going to do them both. There is a world of difference between the total leather thickness for belts and for wallets. And that difference will require different machines. So... which one do you do more of, want to do more of? Which one can you do by hand? I disagree. I have a machine that will sew belts, holsters, knife sheaths, journal covers, wallets and anything else with just a thread and needle change. Quote
Members Aven Posted March 24, 2021 Members Report Posted March 24, 2021 42 minutes ago, sbrownn said: I disagree. I have a machine that will sew belts, holsters, knife sheaths, journal covers, wallets and anything else with just a thread and needle change. Okay. Gonna share what that machine is? Quote
Members FellowLeathersmith Posted March 24, 2021 Author Members Report Posted March 24, 2021 4 hours ago, sbrownn said: I disagree. I have a machine that will sew belts, holsters, knife sheaths, journal covers, wallets and anything else with just a thread and needle change. Yes I would like to hear about this sewing machine that you have! Quote
Members JayEhl Posted March 24, 2021 Members Report Posted March 24, 2021 14 hours ago, Aven said: Okay. Gonna share what that machine is? Boy, I am interested in knowing this machine, too! Quote
Members sbrownn Posted March 24, 2021 Members Report Posted March 24, 2021 Just now, JayEhl said: Boy, I am interested in knowing this machine, too! Campbell Randall needle and awl machine. Quote
Members JayEhl Posted March 24, 2021 Members Report Posted March 24, 2021 3 minutes ago, sbrownn said: Campbell Randall needle and awl machine. Reading this thread here on this form, I'm guessing it isn't really a beginners machine and understandably, a 'you get what you pay for' price tag. Back to the search! Quote
Members sbrownn Posted March 24, 2021 Members Report Posted March 24, 2021 3 minutes ago, JayEhl said: Reading this thread here on this form, I'm guessing it isn't really a beginners machine and understandably, a 'you get what you pay for' price tag. Back to the search! Well...it was my first sewing machine and it cost less than a 441 clone. Quote
Members JayEhl Posted March 24, 2021 Members Report Posted March 24, 2021 Just now, sbrownn said: Well...it was my first sewing machine and it cost less than a 441 clone. LOL, i was going to ask you what a 441 clone was but figured it was already answered in the forum and sure enough. Totally love this community! Quote
Members sbrownn Posted March 24, 2021 Members Report Posted March 24, 2021 3 minutes ago, JayEhl said: LOL, i was going to ask you what a 441 clone was but figured it was already answered in the forum and sure enough. Totally love this community! I would like to have a 441 clone as the cylinder arm and the clearance allows you to sew things I can't sew on my machine. Quote
Members JayEhl Posted March 24, 2021 Members Report Posted March 24, 2021 I just want a sewing machine! LOL! Quote
Members sbrownn Posted March 24, 2021 Members Report Posted March 24, 2021 1 minute ago, JayEhl said: I just want a sewing machine! LOL! Yes, I hear you. I think Cowboy used to sell their 3200 as the head only with a hand crank knob on the flywheel. That was about the cheapest way I found to get into a leather machine that could eventually be motorized as funds permitted. Quote
Members JayEhl Posted March 24, 2021 Members Report Posted March 24, 2021 The cowboy outlaw hand crank? Quote
