Members Bert03241 Posted April 3, 2021 Members Report Posted April 3, 2021 If using a water based contact cement in wet molding, will the glue degrade ? I glue my sheaths together then sew then wet mold. I don't want the glue coming apart in the wet molding process. Quote
Members mike02130 Posted April 3, 2021 Members Report Posted April 3, 2021 Experiment and find out for sure. Glue two scraps together and try it. Quote @mike02130 Instagram
Members Bert03241 Posted April 3, 2021 Author Members Report Posted April 3, 2021 On 4/3/2021 at 11:17 AM, mike02130 said: Experiment and find out for sure. Glue two scraps together and try it. Expand There in lies the problem. I didn't want to buy any water based glue until I know it would satisfactory replace what I'm using now. Don't want to buy something then throw it out. Quote
Members klutes Posted April 3, 2021 Members Report Posted April 3, 2021 Are you glueing two pieces up letting it dry them soaking in water to wet form mold??? Quote Machines: Adler 69 , Adler 30-7, Adler 467, Cowboy bell skiver, Beilers embossing machine
Northmount Posted April 4, 2021 Report Posted April 4, 2021 Soaking until wet through will weaken the bond. Warm water will make it worse. What about just dampening the two sides, then wet molding? I find the leather in general does not need to be soaked through like many do it. Also a can or bottle of contact glue is not that expensive for a test to determine its value for such a case. I'm sure you could find other uses for the remaining cement as well. Follow the directions so you get the best bond to start with. Let it dry for a couple days to set up its strongest bond. Quote
Members Bert03241 Posted April 6, 2021 Author Members Report Posted April 6, 2021 thanks Ill buy a small bottle Quote
Members Zonker1972 Posted April 6, 2021 Members Report Posted April 6, 2021 if you are wet molding after you sew, i don't see why it matters if the glue is degraded. the glue is only there to hold the leather until you sew a permanent bond. if the water degrades the glue, the leather is still sewn together. Quote
CFM chuck123wapati Posted April 6, 2021 CFM Report Posted April 6, 2021 On 4/3/2021 at 4:44 PM, Bert03241 said: There in lies the problem. I didn't want to buy any water based glue until I know it would satisfactory replace what I'm using now. Don't want to buy something then throw it out. Expand you can always use it on stuff you dont wet mold. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members Bert03241 Posted April 7, 2021 Author Members Report Posted April 7, 2021 On 4/6/2021 at 5:52 PM, chuck123wapati said: you can always use it on stuff you dont wet mold. Expand Quote
