Members Rannoch Posted April 28, 2021 Members Report Posted April 28, 2021 What is the best technique for filling in or otherwise hiding holes made by sewing gone awry? When you make a mistake and pull the thread out, the holes remain. Is there a compound our technique for filling in these holes or masking them? thanks Quote
Members Rahere Posted April 28, 2021 Members Report Posted April 28, 2021 First see if they'll swell closed with water. If cut with a sharp awl, it's not unknown. If punched so material's been removed, gluing a plug from the same punch and material might work too. Quote
Members Norton Custom Leather Posted May 4, 2021 Members Report Posted May 4, 2021 Rannoch you may be able to fill the holes depending on the final color of the leather. Black yes, show brown yes Quote
Members Handstitched Posted May 5, 2021 Members Report Posted May 5, 2021 One thing I have used is the left over bits of boot polish that have gone a bit hard in the tin . I use them fill any marks etc. , ...or holes , on hard leathers , mostly black, , sort of like a ' body filler' , and being polish they finish up quite good . I guess a bit of hard bees wax might work too . Hope this helps a bit HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Members Rannoch Posted May 5, 2021 Author Members Report Posted May 5, 2021 Thanks for the replies. I'll give these ideas a try. I wonder if anyone has tried to fill them with paint? Getting the color just right could be difficult. Quote
Members JayEhl Posted May 5, 2021 Members Report Posted May 5, 2021 I read somewhere on here how some folks were mixing leather 'dust' with some superglue to create plugs. May want to give that a try? Quote
Members Rahere Posted May 5, 2021 Members Report Posted May 5, 2021 (edited) 1 hour ago, JayEhl said: I read somewhere on here how some folks were mixing leather 'dust' with some superglue to create plugs. May want to give that a try? It'll be too stiffl for anything worthwhile. In extremis, experiment with silocon caulk molding< thinning caulk with naphtha?white spirits< the using leather powder reather than cornflour as the thickener> Edited May 5, 2021 by Rahere Quote
CFM chuck123wapati Posted May 5, 2021 CFM Report Posted May 5, 2021 can you fill them with fake stitches? Cover them with some type of do dad like maybe a concho or something similar? Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members jcuk Posted May 5, 2021 Members Report Posted May 5, 2021 I have used Bees wax works okay not perfect but ok. Hope this helps JCUK Quote
Members sbrownn Posted May 5, 2021 Members Report Posted May 5, 2021 If this is something you are selling and that wetting with water and burnishing won't fix, then either reduce the price with the customer's approval or start over; if it is something for yourself then don't worry about it. Customers pay for the quality of your leather work so it's up to you what you want that quality to be. When I am making an item for a customer that I make a mistake on I usually just start over and give the one with the mistake to the customer for free. Quote
