Members spurdude101 Posted May 14, 2021 Members Report Posted May 14, 2021 Bob at Toledo sewing machine sent an inline presser foot set up for the machine. I use the holster plate when I use the set up. It will sew 12 -13 oz. leather really nice and it's great for narrow places. But when I go up in thickness like on a holster binding and increase the thickness to about 16 oz. or more every 5 or 6 stitches misses one stitch. If I watch I can catch it and re do the stitch but what a pain. any ideas? ps. If I switch back to the standard feet I have problem. Quote
RockyAussie Posted May 19, 2021 Report Posted May 19, 2021 A picture showing what you are trying to stitch set up in the machine will help. One picture with the front foot up fully and one with it fully down taken from the cylinder end view. It could be that the leather is too soft and spongy and needs a larger needle. Could be the back foot is badly height adjusted or could be a different foot may work better such as the one that presses down in front of the needle. Quote Wild Harry - Australian made leather goodsYouTube Channel Instagram
CowboyBob Posted May 20, 2021 Report Posted May 20, 2021 On 5/14/2021 at 10:38 AM, spurdude101 said: Bob at Toledo sewing machine sent an inline presser foot set up for the machine. I use the holster plate when I use the set up. It will sew 12 -13 oz. leather really nice and it's great for narrow places. But when I go up in thickness like on a holster binding and increase the thickness to about 16 oz. or more every 5 or 6 stitches misses one stitch. If I watch I can catch it and re do the stitch but what a pain. any ideas? ps. If I switch back to the standard feet I have problem. Make sure it's centered correctly,you might need to give it more foot pressure to hold the leather down when you sew thicker. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Moderator Wizcrafts Posted June 22, 2021 Moderator Report Posted June 22, 2021 You might get better results if you can use the flat slotted plate, or even the standard feed dog and flat plate. If the above is not an option, you may need to tweak the timing of the hook. Or, try increasing the throw of the check spring by moving the bottom stop bracket so the spring goes farther down before bottoming out. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
