Have brought a binder for my 111G155 but having problems going around corners with the bias tape, it looks so simple on yt but not for me.
I think its the position of the binder as i cannot get it very close to the machine so about 5mm away from the end of the straight guide after the 90% bend. have placed magnetic guide alongside zip feet and needle to fill in the gap but still having problems,
I have been trying to swivel the material at the needle position but tape is coming away from material, any clues to my stupidity
Limited holes n machine to place the binder and cannot move it closer to needle as would require a hole drilled through the thin part of the right plate so would not take a thread
Mi omputer is ot ood at speeling , it's not me
  • Replies 24
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Binder is too far away from the needle, bring it closer to the needle and if necessary cut down the inner foot.
Edited by Constabulary
This topic might help you Chris...
This is the problem with the style of binder you are using on the flatbed. The 90 degree binder is more suited to the cylinder arm machines. I find using the cheap inline binders much better as you can get the exit part of the binder to just about touching the pressor foot to stop binder tape run away. I even built an adapter for my cylinder bed to accept the inline binders. I'm cheap and why have to styles of binders. An option if you really want to use an 90 degree binder is to find one that has a 1/2" long exit fold that is at 90 degrees to the binder tip. That will allow you to get it closer to the pressor foot.
kgg
To you visualize the 1/2" long exit fold that is at 90 degrees to the binder tip and another alternative using a 90 binder mounted to a feed dog cover-plate. The one mounted to the plate hasn't got a 90 exit piece as it can be set really close to the needle. This may give you some idea's.
kgg
I use the generic double-fold 90-deg. binders (which are SOLD for use on flatbeds) mounted to the bobbin cover plate. This combination WAS mounted on my 111w152 but is now on a rebadged LU-562. As you can see, the needle just can't be much closer to the finished work exiting from the back of the folder. I have the synchronous binder stuff available on my CU-865 Mitsubishi cylinder arm, and it works pretty well, but I really can't see much advantage to it unless the work has a 3-D curved shape and won't lay properly if sewn flattened out.
-DC
Machines: Juki LU-563, Consew 206-RB5, Singer 20U33, Pfaff 481, Mitsubishi CU-865-22, Consew 29B, Rebadged Juki LU-562,  Mitsubishi LS2-180,  Seiko SK-6, Juki LG-158-1
The most important thing I find is how close you can get to the needle without having the pressor foot touch and the proper back tension being applied to the binding tape. Personally, I prefer the inline binders over the 90 degree binders which I think has more to do with personal preference rather then performance and of course cost is always a factor.
kgg
Many thanks folks for the suggestions, It looks like i need to by a swing adapter from College tomorrow as unable to get this binder any closer. and apart from the rather expensive binders available, cannot see and that offer 45% which would possible give more fixing flexibility
Binding tighter *inside curves* easily with an inline binder requires some arcane incantations I never was taught, I suppose. The 90 degree makes it way easier. I suppose doing enough faceplants attempting it with an inline binder makes my 90 degree cure a sort of personal preference.   LOL.
-DC
On 7/4/2021 at 4:01 AM, chrisash said:
modification of threads title .. Having problems binding around corners  'Radius Curve' .
If you having difficulty binding around Radius curves ?  Then you will find little Joy with  'Turning Corners' . .. LOL
Edited by nylonRigging
