On rebuilding' I would use brass double headed ready-rivets
  • Replies 23
  • Created
  • Last Reply
Top Posters In This Topic
5 hours ago, fredk said:
:16:
My concern is that they will stick up too much and not allow the shells to go in without catching the lip of the rivet.
5 hours ago, Tugadude said:
Very cool project.  Glad you figured out a suitable method.  Make sure to post a pic of the finished belt!
Will do.
  • CFM
most look like eyelets, probably more heavy duty than modern ones. Friggin cool project indeed i love that kind of stuff.
  • CFM
Will do.
maybe these would work
https://www.mcmaster.com/rivets/hollow-rivets/
Smashed down tight the head of a ready-rivet would be no higher than what had been in. Plus the head would be a smoother surface than the edges of what had been there
I think you also posted this project on another site.  Now that I am looking at more detail, are they rivets or grommets used as rivets?  Such grommets were used back then- you'll see them once in a while for the belt holes for the tongue of the buckle.
23 hours ago, chuck123wapati said:
Thanks.
I will give it a look and see.
The holes are 3/32 holes I believe and they will be going in leather that is about 8-9 oz or 3.9mm thick.
The original belt was a little less thick but I am going back with what I have on hand already.
I did post somewhere else and ask about them. They may be grommets.
Will do.
Set the inside rivet on a flat, or as flat as possible, object.  When I set capped rivets inside a holster for a strap I hammer them flat on an anvil.  Not had an issue yet.  Or put the cup on the back of the belt and hammer the inside with the flat side of the setter.
Here is a link to the finished project. Thanks for any info you helped with.
I hope that you will check out the link.
JWheeler331: Pooler & Jones Boss Shotshell Cartridge Belt Restoration
You've done an excellent job restoring that, well done , love to see the old become new again  :thumbsup:
I have had difficulties  in the past  trying to set rivets on ' round' projects . So on some projects I have used a small piece of steel pipe around the same size, fit the rivet post through the hole, , slide the pipe in gently,  put the cap on,  and use it as an anvil .
HS
' I have a very gweat friend in Wome called Biggus Dickus,
He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '  :rofl:
