First post here on a first-time sewing machine owner. Get ready for a hot mess...
Yesterday I won an auction for a Pfaff 545-H3-6/01-CLMN which I am hoping I will be able to use to sew mostly clothing projects. I am scheduled to remove the machine tomorrow. I have a few questions...
1. Disassembly tutorials - Reading here I see a lot of advice to remove the machine from teh table. Can someone link me to a good step-by-step for taking the machine off the table. I understand that there may be a need to drain the oil first.
2. Disassembly Gear -  What tools and equipment should I bring? Is there any special tricks I need to know?
3. Transport vehicle - I have a minivan for a regular vehicle. Will the machine and table fit in the back of a minivan, or should I rent a trailer? If I rent a trailer, it is cold and wet outside. I imagine I would need to tarp the machine before driving it home (about a 100 km/60 mile drive).
4. Reassembly - On reassembly, should the machine be given a day or two to acclimatize before being run? Does the oil need time to settle in the sump? Is there a need to pump the oil through the machine or similar?
5. Temperature of workspace - I plan to use the machine in a garage that is only heated when I am working out there. Should I be careful to get the oil warmed up before using the machine? Would it be worth it to put a battery blanket or heat tape on the bottom of the machine?
Edited by LePoisson
  • Replies 25
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Most industrial machine you disassemble very easy by taking the leather belt off and just rocking the machine head away from you and pulling clear
Some machines have a more complicated set up with electronic or hydraulic / air controls which may need expert assistance
The weight of the machine you need to check but only lift able is a man and well built the table is also heavy especially if it has a clutch motor
If you have a tail lift van it may be easier to keep all together
Most machines will run in any conditions but would pay to keep covered so condensation does not occur and lead to rust
Those will oil tank need to be emptied and fresh oil top up before starting
Mi omputer is ot ood at speeling , it's not me
This is what I do when I have to disassemble a industrial sewing machine for transport in my Honda Fit. Moving any industrial sewing machine is best done with two people but can be done easily done by one person if you break it down to relatively easily moveable pieces.
1. Cut top thread and tie off / tape the end closest to the thread spool to the machine. Remove thread from needle. Have the pressor foot in the down position. Don't remove top thread from tension disks so when you have the machine installed at home it will be just a matter of tying the top thread from the spool to the taped down cuttoff and pulling the thread from the needle end. That way you don't have to figure out how the machine gets the top thread path.
2. Remove all other items from the table top like i) the thread spool holder ii) tilt back stop remove it as well iii) bobbin winder.
3. As a lot of machines have the drive belt fully enclosed above table level remove the drive belt cover. The cover probably has a couple of screws holding it in place.
4. Tilt machine back slightly so the belt can be slide of the machines pulley as well as removed from the drive motor.
5. Tilt machine back a little further and lift straight up the machine from table. This is easier done with two people. I lay the machines on their rear side on something soft like a folded moving blanket.
6. Drain oil from oil pan by removing drain plug and wipe dry the pan with a cloth. If it just has a drip pan just wipe it dry.
7. Tilt sewing machine table over so the underside is exposed but put a cloth or piece of cardboard down so the top doesn't get scratched.
8. Remove the bolts that are holding the motor foot pedal and connecting rod from the metal side legs and motor.
9. Remove the screws, bolts, nuts that are holding the motor, controller, on/off switch etc to the table top. Pull motor straight up from the motor mounting bolts. If it is a clutch motor it will be heavy and is removed much easier with two people. If the machine has a servo motor I don't remove it, the controller or on/off switch from the the table top. My thought is I am probably going to replace the clutch motor anyway with a servo motor so it will be quicker in the end.
10. Remove the legs typically "K" legs and cross bracing from table top.
I usually use a small two wheel handcart for moving the various parts to my vehicle but the sewing machine head I physically carry to my vehicle first to be wrapped and secured off the floor. I place the table top side down on moving blankets and the other bits and pieces around it. I take a complete socket set with both metric and imperial sockets, drill with various screw driver bits, couple of thumb wrenches and of course vise grips.
Hope this helps,
kgg
Remove the balance wheel. If you lay the machine down, lay it on its backside not the front. Make sure you pad the hand lift lever against direct pressure. Use foam and blankets. Bring a tackle box for small parts and screws. Ditto for loose spools of thread.
Pfaff machines are expensive and so are replacement parts. Do as little damage as possible!
Posted IMHO, by Wiz
I've moved a few, always remove the head unit (easy to do) and as Wiz said lay it down with plenty of packing (old blankets etc). I had to completely disassemble the tables to get them in my car, but again no big deal. Just take an assortment of tools - screwdrivers (Philips and flat blade), a socket set, adjustable wrench, pair of pliers and some rags to wipe your hands!! If it has a clutch motor be aware they are heavy, if possible flip the table on its back and remove the motor. Having a mini-van you might be able to get the table inside in one piece and so save a bit of work.
The worst thing to move was my Kansai Special coverstitch: heavy and mounted to the table. I basically immobilized the hole table inside a minivan, by tying it down with spare seatbelts.
Light-weight heads like Pfaff 545 can be taken off and safely transported between the 1st and 2nd row seats, on the floor, wrapped in corrugated cardboard or old blankets. Old sofa cushions help as well.
Since it is a dry head you can also lay the whole table on its side as long as the trunk permits.
Machines: Mitsubishi DB-130 single needle, Kansai Special RX-9803/UTC coverstitch, Union Special 56300F chainstitch, Pfaff 335-17 cylinder arm walking foot, Bonis Type A fur machine, Huji 43-6 patcher, Singer 99 hand cranked, Juki DDL-553 single needle (for sale)
You just confused me... doesn't this machine have an oil sump?
My packing list so far. I head out in a couple hours so if I need to add anything to the kit, I'd love your suggestions.
  • 4-wheeled flat appliance dolly plus plywood cover (flat platform I can roll around if needed)
  • 2-wheeled hand-truck dolly
  • 1/4" drive socket set
  • 3/8" drive socket set
  • Adjustable wrenches (small and large)
  • Vice Grips
  • Linesman and needlenose pliers
  • Screwdriver set
  • Box knife
  • Tape (duct and masking)
  • Blankets
  • Bottle for oil
  • Ratchet/cam straps to secure load
  • Small boxes/ziplock bags plus tags to label items
  • Sharpie marker
  • Rags
Check out this image, and you will see oiling holes (painted red):
