Members Munday Posted November 27, 2021 Members Report Posted November 27, 2021 For my first project I thought I’d make a simple folder-over knife sheath. When I was forming it and clamped the edges with black spring clamps, I discovered some of the clamps left black marks on the leather. I couldn’t remove the black marks so I dyed the leather. I also discovered the clamps left dents in the leather and I don’t know if the dents can be fixed. I went ahead and stitched it together knowing I’d be doing it over (just to get some experience); the stitching didn’t go well either but I know more now. I wetted a scrap piece of leather to test the clamps. Quote
CFM chuck123wapati Posted November 27, 2021 CFM Report Posted November 27, 2021 (edited) use contact cement. you can get weldwood brand at about any hardware store or walmart Edited November 27, 2021 by chuck123wapati Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members battlemunky Posted November 27, 2021 Members Report Posted November 27, 2021 Iron changes the composition of the leather chemically. I'm betting that the iron in the spring steel of those binder clips made it through to the leather and got you the black you see. Quote
CFM tsunkasapa Posted November 27, 2021 CFM Report Posted November 27, 2021 And your leather was far too wet if the clamps left those marks. Quote Hoka Hey! Today, tomorrow, next week, what does it matter?
Members Handstitched Posted November 28, 2021 Members Report Posted November 28, 2021 Yep, as @chuck123wapati said, contact adhesive. I've learnt my lesson when using those clamps. I only use them briefly just to hold the leather together while the adhesive sets, otherwise they will leave marks.They are an extra pair of hands in leather, but I never keep them on for long lengths of time. Looks like your leather was a bit too wet. HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Members HandyDave Posted November 28, 2021 Members Report Posted November 28, 2021 When i do have to clamp something and leave it for a time. I put some scrap strips of leather between my clamps and my finished piece. And i also have seen similar clamps that look rubber coated that might work better without the problem. The scrap leather under clamps also helps spread out the load enough to not indent if leather is a little wetterthen it needs to be. Quote
Contributing Member fredk Posted November 28, 2021 Contributing Member Report Posted November 28, 2021 I use either scraps of leather or pieces of lolly sticks between the bulldog clamps and the leather. Which I use depends on a: what come to hand or b: the shape of the glued line Lolly sticks spread the clamping load better and leather will conform to a curve better I've left things clamped up like this for days or weeks, not usually deliberately but because I've forgotten to finish the item or I've been waiting on something to finish it off Quote Al speling misteaks aer all mi own werk..
Members Munday Posted November 28, 2021 Author Members Report Posted November 28, 2021 Thanks for the information. Quote
Contributing Member fredk Posted November 28, 2021 Contributing Member Report Posted November 28, 2021 You see your knife sheath there? If you clamp it up with lengths of lolly (popsicle?) stick along the shape you can get a nice sharp line along the blade edge Quote Al speling misteaks aer all mi own werk..
Members jcuk Posted November 28, 2021 Members Report Posted November 28, 2021 These maybe of use to you also 18mm are available in some places. Things like that i usually lightly tack but each to their own. https://www.artisanleathersupply.com/products/locking-pins Hope this helps JCUK Quote
Contributing Member fredk Posted November 28, 2021 Contributing Member Report Posted November 28, 2021 A cheaper alternative to those fancy pins is a mapping pin into a small block of cork Quote Al speling misteaks aer all mi own werk..
Members zuludog Posted November 28, 2021 Members Report Posted November 28, 2021 (edited) Besides all the previous comments, your clamps are too strong and have too narrow a surface area. Have a look at this video. You can see that Ian has used less powerful clamps, and also wrapped them in thinner leather to cushion them Or you could try clothes pegs/clothes pins But there's something I do -- the plastic clothes hangers for ladies' skirts often have clips or clamps on them to hold the skirt, and those clamps have a larger surface area; I just saw them off with a junior hacksaw, and use those Making a Leather Knife Sheath - YouTube Edited November 28, 2021 by zuludog Quote
CFM chuck123wapati Posted November 28, 2021 CFM Report Posted November 28, 2021 I don't use clamps on leather that's what contact cement is for, glue it, hammer it then i sew it up and its clamped for good. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
CFM chuck123wapati Posted November 28, 2021 CFM Report Posted November 28, 2021 7 minutes ago, zuludog said: Besides all the previous comments, your clamps are too strong. Have a look at this video. You can see that Ian has used less powerful clamps, and also wrapped them in thinner leather to cushion them Making a Leather Knife Sheath - YouTube man he is good with that awl ! Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members zuludog Posted November 28, 2021 Members Report Posted November 28, 2021 1 minute ago, chuck123wapati said: man he is good with that awl ! We're in danger of going OT here, but yes, he is; also watch videos by JH Leather. She uses pricking iron + awl for most of her sewing, and she's excellent. IMO her video on doing the saddle stitch is one of the best Quote
Members JayEhl Posted November 29, 2021 Members Report Posted November 29, 2021 In the most recent issue of leather crafters Leather Crafters and Saddlers Journal an article was written about how you can easily take apart those office binders and taking some scrap leather that's long enough to wrap the inside of the clamp, punching a couple of holes for the levers (or whatever you want to call it) and put it back together. I've made a bin of different sizes of these. Works great. I also found this on the omnicientweb: https://www.instructables.com/Leather-Workshop-Binder-Clips-two-Minutes-Hack/ Quote
CFM Hardrada Posted November 29, 2021 CFM Report Posted November 29, 2021 (edited) There are clamps that are non-marring. Irwin Quick-Grip come to mind. The only time I use bulldog clamps is when I'm wet-moulding and the stitch line will go right along and over the marks left by the clamps. Some time ago someone from Japan joined the forum and his YT channel had a tutorial on how to make leather covered bulldog clamp jaws, to prevent this problem, but I didn't bookmark the video, alas. ___________ Hah! What you know... I found it. Edited November 29, 2021 by Hardrada Quote
