I am trying to make a desk blotter that has a small lip on the end, at a right angle, to protect the desk edge.
I used about a 7oz veg tan that I wet and bent over a piece of 90degree smooth quartz that I found at a remnant store. Clipped down another piece of smooth quartz on top of it about a week.
initially it had a good right angle but over time it’s flattening out. what did I do wrong?
Molded 90 degree
Edited by LOM
Added photo
I'm not for certain but I think you need to gouge out a line from the under side?
This might help explain better:
If you wet the leather (wet molding ), and gouge a channel,  then press the angle you want and allow to dry it will  have a better chance of staying  at the 90 degree angle.
  • CFM
:16:
  • CFM
I would also take it a bit PAST 90 to allow for the inevitable 'relaxation' that comes after release.
9 hours ago, chuck123wapati said:
:16:
:thankyou:
Good thought!
This is great, thank you!
has any one tried metals reinforcements? Like a thin sheet metal that could be attached by rivet? I’ve seen that in cheaper vinyl , leather lookalike blotters and wondering if that’s worth trying.
Is the pad two layers? I wud try some thin sheet aluminium double-sided taped to the top piece and covered by the bottom piece which has been sewn on. Aluminium, from a cleaned drinks can and about 2 inches wide
  • 2 weeks later...
@fredk interesting! I may give this a shot!
Edited by LOM
