Everything posted by Gregg From Keystone Sewing
Servo Motor Is Dead... Options?
Gregg From Keystone Sewing replied to CustomDoug's topic in Leather Sewing Machines
Of course, like said, check fuse. Also check the motor brushes to ensure they are in good condition and are not hung up. We warranty our motors for one year, and will simply send a new motor out to the customer. Then motor goes back to the supplier for credit. Again, this is us, and we operate. -
Highlead Official Website And Email Contact
Gregg From Keystone Sewing replied to Yanni's topic in Leather Sewing Machines
Never thought this was difficult to locate, but here it is; Here is the link for Highlead factory in China I do have some intrest...who is calling what a copy? -
If that Consew 227R labeled machine was Manufactered six years ago, it is made in China; Japan would be a Seiko CW-8B-2 if it were.
Highlead Gc20618-1 Clutch Fault
Yanni, I stock, sell, and support Highlead, and like their products. Safety clutch on this machine is the same that appears on many, many, many model machines, such as Singer 111W, and dozens of other Singers. Not to mention Seiko, Consew, Juki, Durkopp Adler, and many more on new current machines and for at least 50 years back for sure. Now, if the clutch is not working, this is a problem. If it's not made correctly, or has bad parts that do not work, this is a problem, of course. It's not too hard to get that clutch out with the two set screws that hold it down to inspect, and it may in fact need some new parts to replace the bad new parts. Not the first I've seen of this, if this clutch is not made and adjusted just right, it can be problematic for sure, no doubt. I think once this machine has the bugs worked out and is setup correct from the beginning, if it was setup at all, it should provide a long life of reliable service. New machines can be buggy, I know that for sure. Good luck with this machine, either way. -
Yanni, Machine jams can happen to any machine, make, model, or vintage. -
Most needle systems come in a wide variety of sizes, or more specifically, thickness of the blade of the needle that is penetrating the work. For example, a very common needle system, 135X17 (designated above here as DPX16, a cut point needle designation) comes in sizes ranging from NM70//10~NM230/26. As you can see, this is a broad range for a very common needle. Aside from thickness of needle, the thread, any size thread/needle, must be able to pass through the needle eye freely without getting choked off. This, again, does NOT designate the sewing machine capacity to sew through high piles of dense materials. It's a common misconception to think that, because you put a thick needle into a machine that it will do heavier capacity work. Yes, you will get less bending, deflecting, and can sew heavier goods, no doubt. What you may not have is a machine with the drive it may need to do heavy webbing, slings, cargo nets, or the such, in some cases. When we speak about drive, I like to use the analogy I would overhear my Dad tell people; drive is when you take a board in your hand, and I try to hammer a nail in by hand in the air; there is little drive behind it. Now, if I can take that same board, hammer and nail, and lay the board flat on concrete, there would be more drive behind it , and would be easier to nail into the board. This is drive, more or less, and all machines have more or less of it. It's a lot more than inserting a fat thick needle into a high speed garment machine and sewing auto trim with it.
Wiz, Tiz' a Consew model 261-2 (Made by Seiko, Japan) and is a single needle, single thread chainstich (no bobbin) button sewing machine. Also very commonly used for spot tacking on drapery workroom applications. Either way, your correct, no reason to use this unless your sewing buttons or spot tacking with it.
Decent Swing Away Edge Guide?
Gregg From Keystone Sewing replied to Andrew Chee's topic in Leather Sewing Machines
I get a lot of questions about these swing away roller guides. I stock/sell them for ALL model machines, and will custom setup a kit to send out for your machine. Some machines have provisions for install, some have to have holes drilled and tapped. Each machine model will differ on install. This setup seen here is on a Consew 2050 (Adler 205 clone) we have setup, and comes with all hardware and tools necessary to install. Check out the youtube I made, so you can see this in action; Swing away guide Installed on Consew 2050 (Adler 205) -
Help With My Singer 31-15
Gregg From Keystone Sewing replied to Kerry Gunn's topic in Leather Sewing Machines
Yeah man, no doubt. Not right or wrong, if it works, it works. My father has a few 31-15s with original paint AND original gold leaf paint. He does not have a lot of old machines, but he also has a Howe as well in his family room with stand. Some poeple go crazy over this stuff. -
Wiz, 'By the book', needle system for Singer 31-15 is 16X1, Singer Catalog # 2047. Now, we DO use and sell to folks system 16X87 (AKA 71X1, & 16X73), Singer Catalog # 1526, for 31-15 as well. As it is with needles, it's never straight forward. If your using 16X257 in your machine and have it set properly and it works, great, but we normally would not sell this needle for this machine. -
Decrypting Canu Needle Standard Notation
Gregg From Keystone Sewing replied to amuckart's topic in Leather Sewing Machines
If you are referring to CANU numbers (CAtalogue NUmbers), understand this is system of, ahem... 'Standardization', and is used exclusively by Schmetz. This number does not cross reference with nor will it be found on any other manufacture of needles boxes or reference materials. For example, Groz-Becket does not in any way shape or form use CANU numbers. CANU numbers consist of two groups of figures with two digits separated by a colon. This colon prevents confusion with other four digit system numbers. Within the CANUs the needle are classified according to thier length. A low CANU, for example 01:05, marks a short needle while a long needle has a high CANU as for instance 52:10 To simplify matters further, all needles differing only by the point shape have the same CANU. The point shape is marked by two capital letters behind the CANU. This is true for all point shapes with the exception of the normal round point which is not specially designated. If you REALLY want to know all about CANU numbers, refer to Schmetz's book, "Guide to Sewing Techniques" that your local Schmetz dealer may be able to provide. -
Question About Servo Motors
Gregg From Keystone Sewing replied to particle's topic in Leather Sewing Machines
Yes, sure we do; We stock, supply, and install Efka, Mitsubishi, and Ho Hsing motors of all types. A very nice option is the Ho Hsing 'MJ' series needle positioner motor, seen here on our servo motor page; Click for Ho Hsing MJ motor Thanks for asking! -
If you have the documentation that I'm thinking you have, then it's probally pretty limited for sure. 'Slow Start' or AKA 'Soft Start' is usually a feature found on more expesive Ho Hsing, Mitsubishi, or Efka motors, so having this option on a less expensive motor is a pretty nice feature. -
A 'Slow Start" option that is usually adjustable is great to allow the first few stitches to catch up, so they to do become lose or get caught back into the sewing mechanism. It's a really useful option, IMO, but you can of course turn this feature off if you like. As for the power band, I do hear you, some have a very limited range of variable speed, as in you can go fast to slow with good control, as long as you do it withing a short range of arm movement, where having the flexibility of a larger 'power band' would make life a lot easier for the operator. This is a concern with a lot of these servo motors coming out. -
Attaching A Servo Motor
Gregg From Keystone Sewing replied to Happy Hooligan's topic in Leather Sewing Machines
Sounds like someone had an OLD J & K cluch motor replaced...and yes, that's old. -
Singer 111W155 Presser Foot
Gregg From Keystone Sewing replied to TomG's topic in Leather Sewing Machines
There's never enough time to do it right, but there's always enough time to do it over. -
Thanks for the kind words, and nobody has to call me ASAP; kindly call at your conveince!@# -
Yeah, we do this all the time; just get a standard foot set and cut it down, they already have smooth bottom. I do this same price as standard foot set for people either left or right side. -
I've got the Owners Manual on my website; TN-422 Owners Error codes are at bottom of the page, good luck!
Singer Threads - Tap & Die Set
Gregg From Keystone Sewing replied to Anne Bonnys Locker's topic in Leather Sewing Machines
Here is an image of my Singer/Union Speical tap kit being discussed here (it's mine, and used, of course). -
Bob, Yes sir, we have one 6 class in for repair maybe ten years ago. If your around these machines for any bit of time, you don't forget certain models. The Singer 122-1 I think was here, it was tucked behind next to the steel shelving. Once you spoted it, you had to walk closer to see what the heck it was! I wish I had it here just to look it over again, and take some photos.
