Content Count
2,397 -
Calendar
Everything posted by Cyberthrasher
Basically, you're going to have to wet it down (hopefully - depending on the leather) and wet form it to fit YOUR shoulder. Once it's wet, it should bend and stretch without all the wrinkles and then once it's dry, it will hold that shape. But, test the moisture on a small section of the handle that's not visible to see how it reacts. And, we're not talking a spritz here - WET.
Sounds like you means when doing filigrees/underlay. Best method I've found is to use my bone folder to get in there.
With a brush - good and heavy.
Cutting Two Pieces Identical
Cyberthrasher replied to Eternal Custom Designs's topic in How Do I Do That?
Thanks Kate!! If there's enough interest I'll probably do a real one with a teal live camera and pictures you can see -
Sounds like a good enough reason to me for black. Just make sure they're well defined and it should be cool.
If it's just a little bit on the top side you should be fine. I would only be concerned if it was coming off on the bottom, but I believe I remember that you were leaving the bottom natural. -
Is this the one that's already finished with Resolene? If so, you probably need another coat. But, just buff and buff once the Aussie is done and see if you get any more color off. -
I'd say I can probably get about a 10 inch or so section with it just wiping back and forth to cover. If you see some light spots where your dye's running out, reload and go back over it. It's a really even application and pretty hard to mess it up when you're only doing one color. It's basically block dying, without the block. So, if you have any tooling/impressions, it will go right over that without getting dye in there, but you can touch that up if needed. -
You also have that A104 , but I'm not a big fan of those either. Get yourself some Barry King bevelers since you're buying some new ones anyway. You'll want them for the detail in those flames.
Just remember that dye can take time, so let it do it's thing before you panic too much. You'll be amazed at how it evens out over time. I think that was Tom who said he uses the old T-shirt for resolene. I'm a sock or blue shop paper towel kind of guy I stopped using the towels for Resolene, but still use them for dye all the time. Just fold it up into 1/4's, hold it over the dye bottle, and splash some up there. Wipe that on and it will be perfectly even. You'll have to reload a lot, but you won't get streaks or uneven spots as easily. -
do some test flames on scrap and see what you like best. Do a portion of it with no background, then a portion with each of the backgrounders you have. Other than that it's just beveling.
How big are your scraps? When testing coloring, I like to use stuff about the size of a post card or so. But, for overall single color, I use the rag method that we were discussing and just wipe it on. It's easy to get even coverage that way without building up too much. -
Not really. Since the dye soaks into the leather, you can't remove it. Is it only too dark in certain areas? If so, apply a light coat of neatsfoot oil over the whole thing and then just let it sit. The dye may even itself out. -
Pictorial edge finishing guide for those who are struggling. I just whipped it up real quick for the purpose of this topic, but I may do something more thorough in the future. It's basically my take on Bob Park's instructions. Hopefully pictures will help those who have been having issues. http://leatherworker.net/forum/index.php?showtopic=48696&st=90&gopid=309196entry309196
I'm still learning, but here's a REALLY GOOD video from one of our members http://leatherworker.net/forum/index.php?showtopic=12259 Here's another one he did about how to sharpen your awl, since it's something that a lot of people have troubles with. http://leatherworker.net/forum/index.php?showtopic=47996 Hopefully these pictures about edging will show others that Gum Trag is NOT necessary to get a good edge easily. I continuously tell people it's just a crutch and only glues things down. It should be clear that this edge is smooth and will hold on its own without the aid of something holding the fibers down. -
Next up we I take the leather with lubricated edges (from the saddle soap) over to my dremel burnisher. This makes it super quick and easy, but doing it by hand works too. I use the back channel on this one because it fits the profile of the leather better. Yes, I know, I need to clean my burnisher These next two shots are attempting to show the burnished look of it with a bad cell phone picture. Since I wasn't getting a good shot, I decided to offer some contrast and put some dye on the edge. I just splashed some dye onto my blue shop paper towel (as tom explained earlier) and rubbed it on. See how the dye pretty much stopped solid on the line? That's because the burnished edge doesn't allow it to bleed past it. I also briskly buffed it up with the dirty side of my denim scrap. Dirty as in, it's already got black streaks on it. I should also add that I really didn't take any time to make sure I had good dye coverage on it since I was just going for contrast to show in the pictures. Had this been a real project, I would have use a sponge or foam brush to get good coverage, or at least worked a touch longer on applying it with the rag. This was just a QUICK rub down. Here's our "finished" result. I have wax loaded into that denim pretty good, so I rub it in and then get a non-waxed portion of the denim to quickly rub at the edge and cause friction. This makes for a super smooth and shiny edge that you can hardly tell was once two pieces. Now, if I were putting Resolene or other finish on, I would do it before waxing. Other than that, my process is the same. As I said, this entire thing took about 5 minutes, with a lot of that stopping to take pictures over and over until I got a clear one I usually just leave that natural and give it a quick rub with my bone folder to slick it up a little. If the customer requests that I color it, I'll brush some in there. You'll also find that Sharpie can work wonders here I don't do any texting or anything, but this method is working fine. -
Ok, so let's see if these crappy photos help out at all. I was doing some stitching practice last night and decided to edge it up for you real quick to take photos of the process. The seam is held together with seam tape, not glue, so that part could be better. Also, there is no resolene or other finish on the edge - it was a quick job. I think it took me about 5 minutes here. First off, we have 2 pieces of 5/6 oz leather stitched together as close as possible to an even edge. I've sanded up the edge to get it as even as possible with little to know sign of it being 2 layers. This was done with a small piece of 220 grit, followed up with a little 400 because I thought it needed a touch more smoothing. I pulled out my #2 edger to knock off the corners - front and back. I think I should have used a #3 here, but we'll make it work. because I had a little bit of a ridge from beveling the edge (the "mohawk" effect), I went back to the sanding real quick to even that out and make it a rounded profile like it should be. Once I'm happy with the profile and the smoothness, I get ready to burnish. Here you see my bar of glycerin saddle soap that I've rubbed into many edges - hence the groove. I don't get it wet at all, some do. I find I get better results this way. I usually do the front first and then the edges, but it doesn't really matter. Q-tip should work fine. What you're about to see in the next round of pictures is a quick way to do it that doesn't offer the best coverage. Just make sure the edges are well burnished first as you'll see here -
Thanks Coop! I talked him into doing the crosses like that since I knew they would really POP without being too over the top. Makes the center of them separate from the background, but not a huge amount of in your face gold to distract the eyes from the other details.
- 18 replies
- hellhound kustoms
- hk leather
(and 1 more)
I would still try to get it uniform. May not need to get it as smooth as if you were leaving it with no border tooling. I would probably stay away from any of the hatched or checkered tools myself. They may not look right. If you have a seeder and maybe a Camouflage tool, that could work well. I've done some cool stuff with a seeder to make it look like rivets around the edge before. -
Doesn't really matter. They're pretty close in abrasiveness. I have some bad phone pictures of my process that I'll try to get uploaded to show. -
I used to do that with some lint free rags. Then I got to a point at one time where it let me down and wasn't applying as evenly as it should. That's when I started just using the sponge religiously instead. Never failed me before, but that one time where I almost had to start from scratch on the entire order really made me say "not worth it". It was one of those times that was probably a fluke and I was in a hurry not doing something like normal, but I just can't help but say to myself "well, if it happened once it can happen again. Guess I better change." -
Man, I've never made a SINGLE item without something on it that drives me nuts. You just have to see it, study it, find out what went wrong, and study your butt off to solve the problem and learn from it. -
Sounds like you got it. Once the line's made, just use that modeling tool to even things out and try getting a flat surface from the line to the edge - smoothing out the mistakes that are closer to the edge than your baseline. I'm having you use water here because you're making the line and smoothing out some other stuff. That will make it toolable for you. Normally I don't really use any water when I burnish my edges - just bar saddle soap rubbed in. I have a groove worn into the bar that fits most of my leather perfect right now. That's most likely what happened here - too much moisture and it just caved. You can use the denim to polish things up pretty nicely. Just rub it fast and hot. I have one piece loaded with beeswax to wax my edge up and then a dry piece that I used to really polish them. Most of my burnishing is done with a cocobolo dremel burnisher, but there's not reason not to be able to get the same results by hand - just takes more time. Did you get the foam brush wet? Try a plain sponge and see if it's any different. I know those foam brushes can really suck up some material. It may be holding too much and squeezing it out on you. If you get it wet first, it won't suck up as much, and that will help to make sure your not applying too thick. I get 10 packs of sponges from the dollar store and cut them up into 6 - 8 pieces each and use those for wetting things down and applying Resolene. I'll have to test sometime to see if the sponge holds any differently than those foam brushes. Doubt I'll be able to see in time to help you on this though. -
So, for the streaks, you'll need to either lighten up your pressure or make SURE it's cut 50/50 with water. Perhaps you need just a little more water in it. Nothing you can really do to get rid of the ones that are there, but it's possible that the next coat will even some of that out and hide it. Did you pick up a bone folder at all? If not, they have them at Joanne's, and most likely Micheal's. You can try to use that to clean up some of these spots. But, first we have to take care of that line. It's pretty good in spots, so we're going to have to make it look like you meant to do it the best we can Find the line that's the furthest from the edge on the entire strap - we'll use that as a baseline to try to make it look right. If you have some wing dividers, set them at that width. If not, find something you can use to make that line the same distance from the edge all around. Hopefully MOST of it will be pretty close to that point and you can maneuver the leather some and do some rubbing to make it look like it was meant to be. The stuff that's closer to the edge will need to be rubbed out the best you can - preferably with the bone folder or a modeling tool. It looks like they're all pretty close by viewing pictures 1 and 3. Just get that top edge damp and take your time trying to get your line as straight as possible to make it a border. Not sure what you're using to mark your design, but you can even use a stylus if you have to to get that thing going. Once we get that happy little line and it looks like it was done on purpose, I want to see you get that bone folder going and use it to slick up the edges on the spots that are sticking up. Think of it as a touch up burnisher. The far left side of picture 3 actually looks pretty good with maybe just a little roughness on the back edge that can be touched up this way. Let's use that as a baseline.
