Narvi
Everything posted by Narvi
Lacing Is My Life!
Narvi replied to Chief31794's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Very nice work again, Ken. I got inspired by one of your wallets to try the Mexican Round Braid, and then I found your videos on Youtube. Thanks so much for sharing your expertise. -
	3/4 Hermann Oak folds over fine, 4/5 OK, 5/6 too firm. Hermann Oak in general is very firm, but the lighter weights are easy to work with. I'll put in a plug for my local supplier, Golliger Leather in Ventura, CA. Good prices on Hermann Oak and always have A Grade in stock. Give 'em a call.
	Cut little 1/4 inch slits in the bottom of the zipper tape to facilitate the curve, then fold over any excess into pleats to get it to lie flat. I pin the zipper tape down to a cork board with push pins to get it good and tight, then glue the leather to the zipper tape before sewing. Using this technique, you will need to use a lining to hide the awkwardness of the pleats.
Consew 227R-2 Feet/accessories Question
Narvi replied to zuzupetal's topic in Leatherwork Conversation
I have the same machine. Any feet that will fit the ubiquitous consew 206 will also fit the 227. A right zipper foot set is a must for edge sewing, it's what I leave on my machine by default. If you're sewing leather make sure to get a set with a smooth bottom. If you don't have a folding edge guide on your machine, you can get a zipper foot with a built in spring loaded edge guide. You can also get a welting foot to sew piping. -
	I don't know if there's any way to firm it up too much. You might try a clear coat that hardens leather like Resolene or Tan Kote. That will have some effect. Finding the right leather to make bags isn't easy. Chrome tanned is too soft and veg tan is too firm, so what can you do? There's not a lot in the middle that you can buy off the shelf. Commercial products use stiffeners and design tricks to give shape to their chrome tanned products. It's a matter of experience and trial and error.
	You can view stitch tension as a kind of tug-of-war between the top and bottom threads. If the tug-of-war is even, the knot, or more properly, loop made by the hook will get pulled up between the two layers of leather and be invisible to view. Sometimes, one or the other of the threads will be wining the war. If the upper thread is winning, the loop will appear on top of the hole made by the needle, and very ugly it is too. In this case, the upper thread needs to be handicapped by loosening the upper tension mechanism. If the lower thread is winning the tug-of-war, the loop appears on the bottom of the material, so the upper thread needs a stronger hand. So the upper tension must now be tightened. Since the upper tension is easier to adjust, the lower tension should only be messed with if the upper tension is maxed out in one direction or the other and problems are still occurring. Under ordinary circumstances, this should not be the case. Try re-threading the machine and changing out the bobbin before messing with the lower tension. All things being equal, more upper tension will be needed the thicker the material gets. As a rule, if you start sewing 4oz leather on a machine that has been sewing 9oz successfully, you will get knots on top of the material. The upper tension will have to be loosened to get a good result.
Horween Dublin Bi-Fold
Narvi replied to Narvi's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Yes this is machine sewn on my new Consew 227R. Hand sewing this kind of bifold took me 5+ hours, involving 8 separate threads and 16 needles, a real pain. The machine cuts 1 1/2 - 2 hours from production and still looks pretty good, I think. As per Michelle's suggestion about hole size, I may try a smaller needle or use 207 thread on the top side. I'm still dialing these things in, but overall pleased with the new machine. -
Even though Dublin is a veg tan leather, I have not had much success burnishing it. For now I've settled on sanding with 600 grit wet/dry and slicking with gum trag. My usual water + saddle soap + canvas routine doesn't yield good results. Maybe someone else had better success with this leather? -
Narvi posted a topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
	I think size 8 is equivalent to size 92 and size 5 is equivalent to size 138. You should have no trouble sewing size 138 thread on that machine top and bottom using a size 22 needle.
Nakajima 280L Thread Fraying And Breaking
Narvi replied to bobkiss's topic in Leather Sewing Machines
When I had a similar problem it turned out the needle was inserted backwards (concave part should face to the right.) Just a thought. -
	I wax it and then tuck the ends in the hole with an awl after a few backstitches. Then a dab of white glue to secure everything. shows the process.
	Golliger leather in Ventura, CA has what they call a moccasin leather, which is basically a top grain bag leather with medium temper that runs 4-5oz. Lots of colors to choose from and reasonably priced (either $5.50 or $6.50 a sq. ft, I forget which). They have it tanned to their own specs by a U.S. tannery. Their website is pretty basic, so you have to order over the phone, but Carlos, who runs the place, is a very nice guy and patient with newbies. I've been to their warehouse many times and it's clean and well run.
	It is a Highlead machine. Similar to Cobra class 18. You shouldn't have any trouble getting parts as all these machines of similar look use common parts by design.
Typical Tw3-S335B Cylinder Machine Any Good?
Narvi replied to Bigfoot's topic in Leather Sewing Machines
Looks like a clone of the Pfaff 335, complete with binding attatchment. I may be wrong, but I think Typical machines are made by Highlead. This is a light to medium duty machine - 12mm is probably more than it can handle. You might want to look into clones of the Juki 441 which will sew heavier material. -
	For thin veg tan or bridle leather (2-4 oz), I get good results just dampening the leather and using a hard wood burnishing tool on a dremel type rotary tool set at the lowest speed. You can also dampen the edge, rub it with saddle soap and burnish it with canvas while laying the leather on the edge of a table. For floppy stuff - chrome tan or goatskin - edge painting is the way to go. European fashion houses like Hermes use a heated edge tool to seal the edge coat.
	will answer your question. Well worth watching all the way through.
	I like a haft that has at least one straight side to it so that A) it doesn't roll off the workbench, and I can use the feel of the straight side to orient where the blade is pointed.
Small Wallet
Narvi replied to hunio's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Beautiful work. What are you using as your stiffener? -
	It's called a butt stitch. See The Art of Hand Sewing Leather by Al Stohlman.
	You can also skip a hole on the curve. Valerie Michael's Leatherworking book shows how to do this in one of the projects.
	18/3 linen thread works nicely for 8 stitches per inch. I get the 3-ply thread from Royalwood. A standard sadler's awl is fine, just poke only the tip of the blade through and the holes will stay small. I usually pre-poke the holes by stabbing downward with a thick piece of scrap leather below the work.
	I've never used them myself, but I know The Buckle Guy sells some nice looking ones.
