GerryR
Everything posted by GerryR
Custom speed reducer pulley for Singer 51W56
GerryR replied to FDC's topic in Leather Sewing Machines
Links to AC Drive Components: VFD good for up to 1HP 3-phase motor: https://www.amazon.com/dp/B0DFB57721/?coliid=I8NFU0YE5UPT8&colid=17LBFSFMFWW6H&psc=1&ref_=list_c_wl_lv_ov_lig_dp_it Note: I bought mine through Ebay, but this is the same one. Motor: https://www.bodine-electric.com/products/ac-3-phase-inverter-duty-gearmotors-and-motors/42r-fx-parallel-shaft-ac-3-phase-inverter-duty-gearmotor/ Note: I was able to get model 2263, which has 58 in-lbs. of torque and 340 RPM at 60 Hz. You can choose outputs suitable to your needs and even get right angle output shaft versions. Just for comparison, the DC servomotor I was using was rated at 28.8 in-lbs. Foot Pedal Control: This is where I got a little creative. I took a TIG welder foot pedal and did a little rewiring. I got the unit off of Ebay: https://www.ebay.com/itm/176920994141?_skw=TIG+Welder+foot+pedal&itmmeta=01K01RR8XF07B0ETNHVT3SNZC6&hash=item293150215d:g:7KQAAOSwha9jZI28&itmprp=enc%3AAQAKAAAA8FkggFvd1GGDu0w3yXCmi1cdg2dYapN7bLOj7QNBNYvFBgb9nYOw6ivyhEaLfbTDARnhlFmmmIvRE5v%2BmSHS6NHzBxmYRm%2FS%2FOUguxh4QASZ6dKnq4aAfCKcCK9LWjU5OyPxxvNKcH3CjV9WGIL7ylcLvGzb6%2Bdvpe9MAB418aLD72qlvGirmqZ2XNTPpOEnSdadqe%2BJUuU70vTyKzaCPmAPE85JgmuvVu3AwzJYH9iW5vfdQNC7nCE8q1Im3b6Kp6cynjjiIrNBiNTH1T%2Fur%2B7h1JYK8hs%2Bt5hyHSlK4eaNsbSQ%2FRi%2Bmrmp2OVY%2BjRpfg%3D%3D|tkp%3ABk9SR4CP4biAZg I rewired it so the knob-controlled pot limited the top speed so the foot controlled pot had full range to that limited speed. I put everything in a case: https://www.ebay.com/itm/165626696069 These are the basics. I added circuitry for a position sensor that worked off a jog button. I don't use the position sensor, but it is available if I ever want to use it. The jog is so slow that I can stop the needle anywhere I want. This should give you a good start. Feel free to ask any other questions you might have. Happy to help! -
I realize that you already have the DC servo drive, but for future projects, you should consider an AC system with a variable frequency drive (VFD) and a 3 phase inverter rated gearmotor. As an example of the control you would have, a 3 ph, 3/8 HP, 5:1 gearmotor can be operated from 10-90 Hz giving an output shaft speed of 35-459 rpm. Any speed running with less than 60 Hz is in constant torque mode, and greater than 60 hz is in constant horsepower mode. The speed is controlled by a variable pot, not a link to an optical control and is easily top-speed adjustable, giving full range of the pot for control to the selected top speed. The VFDs are relatively inexpensive, but the motors are a little pricey depending on your source, but for control, I think they are better than DC systems. JMO, YMMV. P.S. Beautiful job on that machine!! -
Good advice; sanding it is not a good option as it will just ball up and clog the paper; it needs to be shaved, not sanded. Is the back side in good shape? Can you just flip it over and use that until it needs refinishing, and then have both sides redone at one time?
I'm not familiar with the pneumatic foot controls so I'll assume (ass-u-me) they actually are piped in to the actuating cylinders and are pneumatic switches. If this is the case, then yes, it can be done using electrically controlled solenoid valves and electrical foot switches and an appropriate power source, depending on the valves chosen. If you want to replace the pneumatics completely, then that is more complicated.
Development of best servo motor for leather sewing machine
GerryR replied to CowBoyOUTLAW's topic in Leather Sewing Machines
Well, according to the way the OP responded to my post above, he claimed he achieved all the points I mentioned, which included a 5:1 gear reducer. Must be the language barrier, as I mentioned possibly using an AC servo control, and I doubt he has done that. -
My opinion, from a mechanical standpoint, is to start with a servo that has an integral 5:1 gear reducer. This automatically increases torque and allows the servo to start at a higher speed. This is easier on the motor and the drive electronics. Also, a dual pot foot pedal, one pot sets the max speed and is hand adjustable, the other is the foot-operated pot so you always have the full range of the foot pedal for whatever your max speed is set to. I have this on my system which utilizes a variable frequency drive (VFD).) You might even consider offering an AC-servo system (VFD controlled) instead of a DC system. The electronics are inexpensive, especially for 1 HP and less, however, they require a 3 ph motor to operate, but they can be had with integral gear boxes. As you are designing from scratch, you can spec your own motor. I have had two systems with AC servos and two with DC servos and personally prefer the AC units. Also, a needle position sensor can be implemented with a proximity sensor and metel "flags" put at appropriate locations and you can have multiple flags to stop at various needle positions. If this is implemented along with a jog button or heel pedal switch, you can control all your stop positions quite easily. Just some food for thought. -
Many of the three phase motors produced today are "inverter" rated and are spec'd to run from 10 to 90 Hz (175-2295 rpm) and are usually attached to a gearbox. In my particular case, a 5:1 gearbox giving 35 to459 rpm final output. Further reduction from the motor pulley to the sewing machine pulley keeps you well above the 10 Hz minimum with plenty of low speed control. Couple that with the VFD setup which allows the top speed to be programmed so that the full range of the pot, in this case foot pedal, is from 0 to programmed top rpm and you have very fine speed control. (The DCservos operate the same way as far as programmed top speed is concerned.)
If you want to control the VFD with a foot pedal rather than from the control panel of the VFD, you can get an inexpensive TIG welder pedal (Ebay) that contains the potentiometer (pot) needed by the VFD for external speed control. I mentioned this in another thread. (Not all TIG pedals have the pot included, some just contain a switch, so you have to be careful when ordering.) Just lock the clutch on the 3-phase clutch-motor and use the foot pedal to regulate speed. The one I'm using on my machine is called a "HITBOX" (www.unitweld.com) and I got it off Ebay. It contains two pots, one the foot pedal operates and another that can be used to limit top speed that is mounted on the box and has a control knob. Just my $.02 @Tigweldor Very neat solution!!
Welcome aboard! Very Nice work!! Interesting wood; type?
I've had mine for years, red handle (fine) and purple handle (medium). I also have their pen style (roundish) that I use for odd shaped cutters; for example I used it for getting into the curved end of my farrier knife and to touch up coarse serrated blades. Very handy, long lasting Items.
Advice for speed reducer for Seiko CW-8B
GerryR replied to WMages's topic in Leather Sewing Machines
I don't know anything about your Seiko but would recommend you look at some AC drives (VFDs - Variable Frequency Drive) and AC-3 phase gearmotors. The VFD will convert a single phase input (like regular household power) to 3-phase power that the motor requires. AC gearmotors can be bought with different ratios; I use one that is a 5:1 reduction. The gearmotors are much more compact than speed reducers made with pulleys and belts. The VFD requires a potentiometer input to vary speed. I found a TIG welder footpedal, new, for $35.00, which had the included pot I needed to control the VFD. Just another option. CowboyBob, on this forum, I believe offers DC servo systems and good support from the comments I have seen. -
I never end up on the good side of making money on my ideas. Seems the lawyers are who make the coin. Besides I'm too old to care; I just do these projects to stay busy and keep out of trouble (most of the time anyway!)
Yes - When trying to sew 20 oz. leather, the 135x16 needle's shoulder would enter the leather, distorting the entry hole, due to the added stroke associated with using the M-bobbins. CowboyBob recommended the 190 needles which were approximately 5+ mm longer. By cutting a few mm off the shank, the shoulder is now above the 20 oz. leather at full down stroke on the machine because of the longer 190 blade.. It worked out well. Added the Photo of the Needles: Needle on left is 136x16, center standard 190, right is shortened 190. Notice the extra length in the blade compared to the 135x16.
As I seldom use 207 thread, I left the tension on the bobbin alone; it works as is for 69 thru 138 (I don't use 69 much either). The 207/207 in the picture above had too much bobbin tension, but I didn't fool with it much. I just wanted to make sure it functioned with the three thread sizes (92,138 and 207). Once I get it motorized, i'll do some long runs with the proper adjustments for all the thread sizes. There is enough range in tension setting for the upper thread, I think, to compensate for the 207 in the bobbin. On the Chinese patchers there are two upper thread tension setups (Some people say one is for bobbin winding, but I can't see how that works for bobbins the way it is set up). I always use both (actaully 1-1/2) for upper tension adjustment and have had no problems. On my unmodified patcher, I changed the needle system to 135x16/17 because of all the leather options, but because of the added stroke of the modified unit above, I'm using a shortened 190 needle system. Projects like this one keep me in the shop and out of trouble, mostly!
Just to finish up and make some final comments: Here is a picture of the different size threads run on the machine. Everything ran pretty well except when running the 207 thread in the bobbin. I need to increase the upper thread tension or lower the bobbin tension to get the knot to pull further into the leather. I did the stitching one-handed with the machine clamped to a table, hence the crooked stitch paths. Once I get it motorized, I can use two hands and guide the leather better. Like I stated earlier, it is no longer a true "patcher" due to the size of the arm however, the dimensions of the new arm are 1.5" wide by 1" deep, so it can still be used in fairly tight places. It was a fun project and with the larger M-style bobbins, I can do "longer" projects between bobbin changes. Also, being able to use 207 top and bottom makes for more sewing options; 207 in the original patcher bobbins wouldn't get you very far.
Is that not a DC servo controller/motor that is driving your machine? If so, why not just change the parameters in the controller to get better low speed control. Most of the DC servo systems can "crawl" and have ample torque for the machine. Just curious.
I don't know how your machine is assembled but my lathe has oil level windows that pop out of the front of the machine and you just replace an O-ring to stop a leak from the window. I use a thin blade to work around the window to get it out. I dont know of any "repair" sealer that will work once the oil starts leaking; maybe someone else does.
@CowboyBob The 190 system works perfectly. I trimmed 5mm off the top of the shank and can now do 20 oz. leather (machine limit) without the shoulder hitting the leather and widening the top of the hole. Thank you for your input!
I was told it could be done, just have never seen it done. From the article linked, it is very involved; unless you are running some large motors with very expensive VFDs (for which Rockwell Automation is noted for) I think it would be cheaper and safer to use one VFD per motor. But, thanks for the link; never to old to learn something new!
I'm working on a project, just for my amusement, where I changed the needle stroke (I'm presently using the 135x16 needles) of the machine. Because of this the added stroke causes the shoulder of the needle to just enter the leather on 16 oz and and above, widening the hole at the needle entry point. I read that the 328 needles have a 1.98mm shank diameter up to size 140 and a larger shank(s) after that. the 135x16 needles have a 1.98mm shank. If the 328 needles have a slightly longer blade, I could cut the shank to get the same total needle length (~45mm) and keep the shoulder away from the leather. This is part of my conversion project of a Chinese patcher to using M-style bobbins. If the total length of the 328 is near 60mm, as Tigwelder indicated, then maybe I chose the wrong system to modify. Like I said, just amusing myself.
Looking for the actual length of the shank, shoulder and blade of the 328 needles sizes 19/120 and 22/ 140. I found the overall length of 5.2cm and shank diameter of 1.98mm by searching but can't find the other info. Any help will be appreciated! Thanks in advance.
I have never seen a multi-motor machine running off of a single VFD; one motor per VFD. Most VFDs require the motor parameters to be entered into it and it is only programmed for one set of motor parameters. Besides, at the price of these VFDs these days, one per motor is pretty affordable, at least in the 5 hp and less range.
That's a great idea, using one "portable" VFD to run multiple machines!
help from the masters..... Is the machine fixable?
GerryR replied to MattiJoy2's topic in Leather Sewing Machines
I'm a little late to the party, but here is my $.02 If everything runs freely, the casting can be brazed, or if just a hairline crack, silver soldered; I wouldn't weld it. -
I don't know much about clutch motors but have assumed they run at full speed and that you "feather" the clutch to regulate the output(??). If that is the case, then running it with a VFD is not a problem. As stated above, you need to worry about low RPM because of the cooling. Many "inverter rated" motors are spec'd at 10-90 Hz. I have run many VFD's on fractional to 100+ Hp motors (factory automation). I presently have one on an old Boyer-Shultz 3 ph. surface grinder in my shop (running full speed) that has been running for over 20 years, and I have a VFD running as my speed controller on my leather sewing machine; the sewing machine has an inverter-rated gear motor with a 5:1 reducer, so motor low-speed control is not a problem. The point is you can use some form of reducer to raise the low-end motor RPM to keep it cooler. I have recommended VFD's as optional speed controllers for sewing machines with clutch motors, lock the clutch on and use the VFD with a TIG welder footpedal to control the speed. Many Tig welder footpedals have a built-in potentiometer for regulating output power which can be used to control the VFD output frequency. Just some thoughts that might help if you run into problems. (By the way, I'm using a unit similar to what you purchased (in my case 220VAC 1ph. in to 220VAC 3ph. out) and it works perfectly!)
