Everything posted by Colt W Knight
Prevail sprayer
- 22 replies
Thanks yall
New Servo Motor Dropped in Easy - Singer 111W155
Colt W Knight replied to leecopp's topic in Leather Sewing Machines
I put one on my Consew 206, and found it to be an easy retrofit aside from wrestling that big ole heavy clutch motor. -
After watching some gunsmithing videos, 30 LPI seems extreme for bevelers. That would be more like a back grounding tool. I am going to order 50 LPI checkering file.
Depending on the size of the box, a regular old light bulb will work to dry and circulate the air.
That is why I went to using an airbrush, all my shades of brown turned out dark brown once I got even coverage. I would dip dye more if I had a nice place to keep the tubs. I have hand tremors, so I have a hard time hanging on to things or dropping things. So no vats of dye anywhere where I will most likely spill it.
- 22 replies
THanks THanks
The end of the bolts are crowned and dressed, so I am not sure how it is any different for the maul than removing them all together. I left the threads to provide grip so the tool doesnt slip from my hand. I keep my index finger there. If I had a lathe, I would knurl the shank. Bolts are rough ground on an 8" bench grinder. Final shaping and dressing is done on a 1 " belt sander, and then the ends are buffed to a mirror polish on an 8" buffing wheel. Bolts are kept cool by dipping in water frequently.
Thanks, but I used power tools to make the stamps.
I use mine everytime. Be sure to get one with a plastic basket, not a tray
Thanks, I am excited to try to attempt to make some more tools. Thanks, I am excited to try to attempt to make some more tools.
Thanks, I never was a fan of the guitar straps with the slot punches, either the two piece straps or the ones with the pads. Took me a while to realize I didn't have to make guitar straps like everyone else.
A good friend of mine asked me to make an oakleaf tooled padfolio for her as a gift for someone. I tried to talk her out of it because I do not like tooling flowers and leaves. Flowers and leaves were not what drew me into leatherwork, and sometimes I find them a bit cliche because so many leather projects are cut and paste from old leather working books/patterns. Plus, I am not very good at it. Anyway, she talked me into giving it a try. I had to make my own stamping tools to get the job done.
I want to make a set of checkered bevelers, steep angle bevelers, and some more undercut bevelers and lifting tools. Just need to order some more SS bolts.
I needed some bevelers and a lifter, but I wasn't too enthusiastic about the 25-35$ price tag on quality tools. Picked up some 1/4" SS bolts and made a beveler. It worked better than my Crafttool beveler, so I made a set of 3. Then someone asked me to make some oak leaves and I made a lifter from a 3/8" hardened bolt used for electric poles.
I gave 80$ on Amazon Prime, but come to find out they sell this same machine under a lot of brand names. Harbor Freight carries it, and you can uze thise 20% and 25% off coupons on it. I use Angelus leather paint which is a water based acrylic, and this machine does a great job cleaning my Iwata airbrush. If its caked on, I run it through the 8 minute heated setting and i may have to wipe the tip off with a papert towel. If i put it in the cleaner right after use, it cleans it right off.
I recently bought a heated ultrasonic cleaner for my airbrushes, and I am trying to only use products that will clean up with warm water and a spoon full of dawn dish soap. Fiebings pro oil dye, Angelus leather paint and and mop n glo all clean up on the 8 minute setting.
I just use it straight. I was thinning it 50/50, but it sprays better and doesn't drip if I spray it straight through the airbrush. It comes out kinda glossy if you spray it straight, but if I want a matte finish, I spray it on heavy, let it set a minute or two, then wipe it with a paper towel. Comes out great. I haven't experienced any negatives using Mop N Glo
I use Mop N Glo as resist, works great if applied just right and let it dry. Plus its cheap and readily available. By the way, nice tooling. Wish mine was that nice.
I use angelus leather paint sprayed through an airbrush - Takes 3 coats.
I would highly recommend this tool https://www.tandyleather.com/en/product/table-top-edge-dyeing-roller
Dobro Strap and a Wallet out today
Colt W Knight replied to Chief31794's topic in Musical Instruments
Fine looking strap. -
