Everything posted by BDAZ
I simply use a piece of granite on my 2 ton press. I hve some smaller plates for larger cutom stamps but for regular 2D and 3D work I use the Tandy Mules foot. The ram on the 2 ton is much bigger than the one ton. Cya! Bob
Much better than I thought it would. After covering grain side printing with Resolene, it's pretty impervious. It seems permanent on suede as well. Cya! Bob
I recently had a request for a custom "makers Stamp" for an Item I am working on. I used a technique that I often use for transferring patterns from the computer to either grain or flesh side. In this case I needed to print on the suede lining. The process is utter simplicity, Print the text or graphic on a standard piece of copy paper, either with a laser printer or copier. Reverse the image so it prints backwards. I trim the print then tape it over the leather on a cutting board. Next, using a swab, I saturate the paper with acetone, then burnish lightly with a bone creaser. This may not be news to anyone but I haven't seen any references to the process. I have always used to to trace cutting lines, but this time I tested it for fastness with oil dyes, various finishes and neatsfoot oil and it doesn't run or blur. This test is printed on a scrap piece of pigskin suede. YMMV Cya! Bob
Welcome. Can't ask for a better climate for leather working! Really interesting items on your web site. I guess you are in NE Tucson, I'm in NW. Cya! Bob
Invest in a 2 Ton arbor press. Heavy but it has a lot of working room and easy to eyeball type face stamps. Buy two sets of each so if you have double letters you can keep them aligned. Cya! Bob
Vinagroon Changed Color
BDAZ replied to Red Cent's topic in Gun Holsters, Rifle Slings and Knife Sheathes
You could let it settle and filter it again, then add more vinegar and steel wool.. I usually have 5 or 6 bottles perking and each is a different color, from black to tea like. Cya! Bob -
I have not had to do this pattern but when I have a complex stitch pattern I lay it out on Photoshop using 1-2 pixels for line width. I reverse the image if I am going for the grain side or keep it as is for the flesh side. If the design is symetrical, like this it doesn't matter.Then I simply print out the pattern with a laser printer. I align the pattern, toner side down and hold it in place with masking tape. I then use a dauber and wet the back of the paper with acetone then applying pressure with a bone creaser and carefully remove the paper and you will have a perfect pattern on the leather. Then I will use a groover over the lines if they are on the grain side and I'm ready to stitch. Cya! Bob
I decant oil into a smaller bottler and keep a Tandy wool dauber in the bottle which I reuse until it becomes too discolored. I only oil after tooling and wet forming and the item is completely dry, assisted by the Arizona sun. My workshop is cooled to 85F and the oil penetrates well at that temperature. In the sun, a black item can reach 140F and the oil is distributed quickly. I re-oil once more before waxing and shipping. I don't oil between production stages to save time. Cya! Bob
A Different Kind Of Gun Leather
BDAZ replied to Hilly's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Any issues with cooling the barrel during rabid fire?? Beautiful work! Maybe a colonial - revolutionary war theme would help with the blue states. Cya! Bob -
I am attending a 3 day agility trial and most of the dogs have their cages shrouded to minimize visual stimulation. The Thundercap sounds like a great idea!. And Wiggy, you know not of what you speak. Cya! Bob
I use a blend of soy wax and beeswax. Soy wax is available at a number of different meting points, lower than either bees wax or paraffin. I can't go too low because my products can get quite warm drying in the sun (145F) here in Arizona so I use a blend and works well. You can add neatsfoot or olive oil to the wax as well. Cya! Bob
I lived in Berkshire for a few years and had heard it pronounced Shrow. I also lived in Berkshire County in Massachusetts and we pronounce it Berk and Bark. Two nations divided by a common language! Cheers! Bob
I used to live in Shrewsbury in the US, near Boston andpronounced Shruusberry, not Shrowsburry FYI.. Bob
Something like this out of leather? Cya! Bob
Available at Home Depot for < $5 and works great with oil dyes. Cya! Bob
- 16 replies
I recently returned a side to Tandy that had a fuzzy pattern on the flesh side..totally unusable! I will generally give the flesh side a light sanding on the belt sander then spray 50% oil dye and spray wax to give a finished appearance for black or brown items. Cya! Bob
The 1/32nd cork from Hobby Lobby was the PERFECT solution! $6 took care of all my straight edges, from 1' to 6' including a few extra thin home made ones. Cya! Bob
I would be afraid that the coarser anti slip materials would mar the leather. Thanks Bob
Buying Keestar Sewing Machine 441 Directly From China..
BDAZ replied to korokan's topic in Leather Sewing Machines
My other company exports 5-6 shipments a month from Europe. We have a speial deal on fees but if UPS screws up they can bill as much as $150 on a $200 duty free item. Cya! Bob -
Arbor Press One Ton
I graduated to a 2 ton and have never touched my 1 ton.since. With the 2 ton I can use all my hole and belt end punches with no modifications. The one ton is not powerful enough to handle larger custom stamps. In addition, the larger work area makes it easy to visually align stamps on belts and straps. I also use it for snaps and rivets. IMHO, don't wast money on the 1 ton. Cya! Bob -
You didn't understand. You still will need a broker and file customs forms regardless of the duty. Find out what those charges are. You WILL pay fees to the customs and fees to the broker but no duty. Cya! Bob -
I assume you have never been involved with imports because you will need a licensed customs broker to tell the Customs people that there is 0 duty and to file all the paperwork. Check with the sea freight company and ask them what fees would be involved in clearing the item. You may be surprised! Cya! Bob -
http://www.tolindsewmach.com/cb3200.html If the 3200 will do the job, (up to 1/2 inch of leather) the the cost is $1595 out of the box and ready to sew. Besides shipping there will be all kinds of add on fees for customs clearance, port fees, etc. You could be looking at a few hundred dollars additional. Assuming you already have a customs broker.. You would be NUTs to buy this machine from China..IMHO when you could buy a similar warranted, well supported machine for possibly less than the direct import. Cya! Bob -
However, had the owner's name been Mary Absolut, the vodka folks would have to suck wind..Even in Washington. Cya! Bob
