Everything posted by BDAZ
Good point about the air bubbles. I occasionally use vinageroon and neutralize with baking soda and it is definitely CO2, not air I see. A test would be to soal the leather in water, drain and then apply the ammonia...bubbles = CO2 = PH Change. BTW I used to build bodhrans when I lived in Ireland. I buried the fresh skins in alum for a couple of weeks and the trick it to apply the wet skins to the rim. After drying once they are never the same. (I also play Irish tenor and and on my way to a session this afternoon) As for glues, try one of the polyurethanes, which is moisture activated. I have never used it on leather but I imagine it would work well for for certain applications, not as flexible as RTV but it will penetrate and expand. Cya! Bob
Usually drying wet formed products i the sun is no problem but every once in a while I have a larger order and it rains! I have a fron load tryer which came with a rack for drying objects like shoes. When sun drying mt items will reach 140F which I find ideal. I use the very low heat setting in the dryer and it works perfectly. Tiara: never use ammonia on leather!! Those bubbles you saw were a natural reaction to the acids in the leather which are critical for longevity. Cya! Bob
My Belt Cutting Setup Ain't "cutting It"
BDAZ replied to msdeluca's topic in Leatherwork Conversation
Sorry, missed that but I do find the 60" mat is a lot easier to use than 8 1/2". I have it attacked to a custom made table with shelves for leather storage underneath. Cya! Bob -
http://hancockfabrics.com/cutting-mat-56-in.-x-33-in.-3546926.html Cya! Bob -
My main "earners" come in 3 different widths and 3 different colors. I buy drum dyed hides which cuts a number of steps off the process. I offer lined, for an extra charge, or unlined f I offer customization in the form of a name or other stamp choices and choice of a few other items, at no charge. If I don't have a custom order I emboss which looks great but faster and time is money. I pre cut my leather when I receive my hides and will shortly have dies to reduce the production times. I can offer a 24 hour turn around, at an extra charge, easy because most of the time consuming work is already done, and I offer wholesale at 35% off retail. My typical wholesale order will run $1,000 or more. I will invest in anything I can use to maintain the hand made, high quality look and feel of the product and make them faster and cheaper. Cheaper = more profit. Some days I feel like I'm doing piecework in Mexico but never when I deposit the checks. I have been investigating dog collars for some time and I feel there is a market niche I could address. It does mean making off the shelf product for sale at shows, investing in the right equipment and coming up with a slightly better design than what's currently out there. In addition it will require investing in exhibit space at craft and dog events and having sufficient inventory. I hope this is helpful. Cya! Bob
- 12 replies
- pricing
- value-based pricing
(and 1 more)
I don't have the patience or whatever it takes to listen to the window shoppers.I'm going to just go for the premium and above customers. What you don't get is that a few of those window shopper are the premium customers.Every potential customer is gold and until you understand that you will fail. Good luck! Bob
- 12 replies
- pricing
(and 1 more)
First off I I think one has to decide whether one is in a hobby business or a real business. If you are just interested in making some money on the side or just breaking even, then blow off the business you don't like. Turn away customers who are looking for a deal (who isn't) and take it personally. If you are interested in having a business that also gives you the opportunity to be creative and artistic, then you need to develop products that are competitively priced, and quick and easy to produce. This involves investing in the production equipment required to produce high quality at lower than custom prices. I attend a lot of dog shows and that is an excellent venue for selling BOTH production collars and custom ones that will cost significantly more. Money is typically no object for those folks but an off the shelf collar or harness is a foot in the door. As for determining what a yet to be made product is worth to each individual customer..a fools errand IMHO. Best of luck! Bob
- 12 replies
- pricing
(and 1 more)
Spence, please elaborate a bit on your issues. What do you make, what market have you lost, what are your margins and how do you cost your overheads, time and materials. Sometimes charging more and selling less is a very good marketing strategy.. Cya! Bob
- 12 replies
- pricing
(and 1 more)
Cb3200 Breaking Needle Thread In Reverse
BDAZ replied to RoosterShooter's topic in Leather Sewing Machines
Rooster: Common Courtesy: if you ask for help and some folks ask questions, answer them... Cya! Bob -
Does anyone know if the Weaver clicker plate adapters will work in a Harbor Freight press? Thanks, Bob
Few Questions: 1. Did the reverse ever work properly? 2. Have you changed needles and thread since it arrived? What size needle and thread. 3. What happens if you manually reverse the machine without flipping the lever. 4. Do you have a washer under the stitch lever plate? Cya! Bob -
Sewing Between 1 And 2 Layers Of 5 Oz - Cowboy 3200 Best Way?
BDAZ replied to BDAZ's topic in Sewing Leather
I replaced the bobbin spring with one obtained from Bob at Toledo and the machine is PERFECT! Loking from the top, you can not see the transition from two layers to a single layer. In addition, my products requires 60" of stitching around the circumference and every time, when I get back to my starting point, the machine drops the last two stitches in the same holes as the first two! Cya! Bob -
One of the really big markers can be used for "block" coloring of 3D stamps. You can also use metallic sharpies and brush them along the raised part of the stamp..I also use the big markers for edge coloring. Cya! Bob
Try metallic silver acrylic paint from the craft store. Works great, inexpensive and lasts. Cya! Bob
I recently tested acrylic paints from Hobby Lobby against "leather" paints and found no difference. I made a test banjo strap which I have used 2-3 gigs a week for the past two months and there has been absolutely do degradation of the painted areas with either paint. I only used one coat and sealed with two coats of resolene. Cya! Bob
The center foot seems to be adjustable with the two set screws or should it be all the way up? i haven't messed with it but does seem to be a possible parameter to play with. I have never had visible knots on the back..guess your top is a little too loose. Thanks! Bob -
Thanks! I just completed 25 items and the leather used ranged from 3-4 oz to 6 oz. I replaced the upper spring with a spring from a bicycle hub quick release, much lighter, and I lightened up on the foot tension. The single layer 6 oz (drum dyed veg tan) was perfect. No knots visible from either top or bottom and the transition to 2 layers of 6 oz is perfect. The items that have a single layer of 3/4 oz look a bit like your pics. The knot is visible if you look for it but below the surface, though not in the middle. All my work is drying from wet forming but I'll post some pics tomorrow. How do you have the center foot height set? Cya! Bob -
Christmas Orders Are Pouring In
BDAZ replied to Chief31794's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I had a 74 HD 28 which was one of the nicest sounding guitars I have ever heard but traded it for a banjo....too many instruments, not enough fingers! Resogat sound like fun! Cya! Bob -
Face Wallet Gag Gift
BDAZ replied to Kaje's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
LOL!!! Cya! Bob -
Great stuff! Enough straps for a bluegrass jam! You '28 has a really nice piece of rosewood for Indian! I still have my original strap made by Roger Sprung on my original guitar, a '63 28 bought new. All three of us are a little worse for wear. I used to tour with Sprung and we used to play at the Fiddlers Convention in Hiawassee every year. Back to the bench!! I am filling an order for 30 musical leather items. Cya! Bob -
You Never Know What You Are Going To Get In To
BDAZ replied to taintedelephant's topic in All About Us and Off Topic
I decided to make all my Christmas presents this year. Probably will be your most expensive Christmas presents EVER! Cya! Bob -
I would NOT use a water based stain on an item expose to water.Find an alcohol based stain and soak the straps so the dye permeates the leather, then buff off excess and Reolene away! Resolene is a waterbased acrylic and sets once dry but won't dissolve the alcohol based dye when applied. Cya! Bob
Chuck, you were responding to the wrong response: The damaged I was referring to was: Anhurset: The only time I've had vinegaroon turn brown was on a bad hide, the surface disintegrated and the leather took on a dark brown color. I only dip for 20-30 seconds then rinse in warm water. There are many folks that don't bother with no apparent issues. Cya! Bob
- 18 replies
- neutralize
- neutralizing
(and 8 more)
Just a follow up to my earlier post. After tweaking the bobbin spring (removing and bending) and loosing up the foot tension as suggested by Wiz, cutting two coils off the tension springs as suggested by Bob Kovar, I now am able to transition from 1 to 2 layers of 5oz. with a perfect stitch and no adjustments during the transition. I just completed stitching 10 identical items and there was slight variations in the knot amongst the 10 due to differences in tanning and thickness. I don't mean to hijack the thread (no pun intended) Cya! Bob
- 11 replies
- reverse stitch
- back tack
(and 1 more)
