Everything posted by BDAZ
Bob, didn't mean to appear snooty, but you are quite right. Actually I should have stated the speed reducer or the hand wheel to be accurate. Regardless, a great machine that has paid for itself many times over! Bob
Yes I believe it also functions as a flywheel: fly·wheel ˈflīˌ(h)wēl/ noun a heavy revolving wheel in a machine that is used to increase the machine's momentum and thereby provide greater stability or a reserve of available power during interruptions in the delivery of power to the machine.
Dye interior belt quest...
BDAZ replied to D2G's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Gum Tragacanth is water soluble, so may be OK for Eskimos but NOT for a belt in Spain, other than to produce a glossy edge. Since the flesh side of the belt will possibly get wet from sweat, you should seal it. I use Resolene, which is an acrylic and will seal the leather and prevent any staining of either pants or leather. Where in Ireland are you? I used to live in Dublin but spend a lot of time in West Clare. Bob -
Grey dye
BDAZ replied to glockanator's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
I have found vinagaroon to be both unstable and unpredictable. I found it lightens over the years. I no longer use it. I would suggest acrylic paints from the local hobby store like michaels. I have tested their durability and they hold up for years, especially under a coat of resolene. Go for the expensive ones ($.79 a bottle). It's a good as any acrylic leather paint. Bob -
See if he will let you know what dye he used, whether acrylic or alcohol. Don't go slopping solvents on the chair till you have that information. If acrylic, acetone will soften it but it's a real mess to remove. If it's alcohol (or oil dye) then use denatured alcohol, and again, have a ton of paper towels and rubber gloves. BTW, methylated spirits is the same term as denatured alcohol, used in the former colonies. Bob
I have had my 3200 since 2014 and besides a bad bearing in the flywheel, replaced by Bob immediately, I haven't had a moments down time and not one dropped stitch. Its a wonderful machine, cost effective and does everything I need. Make sue you watch a few of the "how to lubricate your 441clone" videos as it is easy to miss some critical areas. I did modify the electronics to give more range on the lowest stitching speeds. Bob
Nice work! My last collar was a black, studded collar for a chihuahua. Bob
I take a wool applicator that has been used with USMC black and allowed to dry, slice the end off and slice a flat side and it works like a champ. Stiff enough to keep paint on the edge but holds enough for a decent run down the edge. Price is right.
Well said! BTW I lectured in Photography at Trent Poly in the 70s. Bob
I use the double 90% of the time and the left the rest on my Cowboy. Bob
This is based on my experience in wide format digital printing and memory of having read this description of those dyes. There are two ways to design a dye, either using pigments held in suspension (a colloid) in a solvent (water can be the solvent as well as alcohol) or actual dyes dissolved in a solvent. The low VOC (volatile organic compounds) can be acrylic or use solvents that do not evaporate as quickly as alcohols. There are regulations in CA making it very difficult to sell certain high VOC products. That being said, I would and do use the solvent dyes as they tend to penetrate deeper into the leather and require less buffing to remove excess which hasn't penetrated. Neatsfoot is supposed to be an oil derived from the shin bones of calves. It's unlikely that is the case today but there is a percentage of real neatsfoot in the "pure" derived from bones. The compound is the natural oil extended/adulterated with other oils including petrochemicals. Here is the MSDS of the pure: 1. Ingredients Name CAS# OSHA ACGIH % Triglycerides 8002-64-0 N/A N/A 100 This product contains no hazardous material. HEALTH - 1 REACTIVITY - 0 FLAMMABILLTY - 0 Here's the MSDS on the compound: Severely Hydrotreated Heavy - INHALATION: Vapors or oil mist from this product may Naphthenic Distillate cause mild irritation of the upper respiratory tract. (CAS Reg No. 64742-52-5) INGESTION: Considered no more than slightly toxic if OSHA PEL: swallowed. Acute oral LD50 (rat) greater than 5 g/kg of ACGIH TLV: body weight. Severely Hydrotreated Light - CARCINOGENICITY: Naphthenic Distillate NTP? No (CAS Reg No. 64742-53-6) IARC MONOGRAPHS? No OSHA PEL: OSHA REGULATED? No ACGIH TLV: SIGNS AND SYMPTOMS OF EXPOSURE: As noted above. Prolonged Exposure limit for total product None and repeated skin contact may lead to various skin as mineral oil mist in air: disorders such as dermatitis, oil acne or folliculitis. OSHA PEL: 5 mg/m3 Minute amounts aspirated into the lungs during ingestion ACGIH TLV: 5 mg/m3 (TLV/TWA); 10 mg/m3 (TLV/STEL) I stick with the pure. Hope that helps, but note, I am no expert in leather dyes. I do hold patents on soy based solvents and am currently a partner in an international wide format printing business. Bob
Heavy Dutyartisan® TORO-3200 Stitchers with a 12 1⁄2" working area cylinder bed are known as Compound Needle Feed, Walking Foot (Unison Feed) Lockstitch Sewing Machine and include a very large size Bobbin and Oscillating Shuttle Hook system designed to stitch from as light as 2 to 3 sheets of paper, up to as heavy as 9⁄10 inch or 24.1 mm thick. Some features of theartisan® TORO-3200 include a lever type stitch regulator with Reverse feed and a built-in bobbin winder mechanism. The machines stitch using threads manufactured using bonded twisted Nylon or Poly Threads from light weight sizes such as z-69 (tex 70) up to as heavy as size z-415 (tex 410) industrial threads. We recommend genuine SCHMETZ brand Needles from diameters as light as 794 NM110, (#18) up to NM250 (#27) including leather point needles 794 S #21 to #26 and 794 D #23 to #25.artisan®is the direct distributor of Schmetz brand, German manufactured highest quality needles and carries all of the various sizes. Please telephone or E-mail us at 888 838 1408 for help in deciding what is best size needle for your requirements. TORO-3200 with "U" Table$2175.00 My suggestion is to stop screwing around and purchase a machine that will do it all or stay with hand stitching and stop whinging. I saw this advertised in a magazine and it seems to have a wider range of capabilities than the 3200 Cowboy. If you want to spend your time tinkering instead of making leather products that could generate income, that's your choice bou IMHO, not a productive one. The only work I have done on my 3200 was to rework the electronics to slow the stitch rate way down, and to replace a flywheel with a bad bearing. I never have to waste any production time messing around with tinkering. To that end, the 3200 paid for itself long ago, both is sales and not a single product ruined by the machine. I can stitch a full belt and the last stitches are in the exact holes as the first. Again, please post a photograph of one of your items with the desired thread. Bob
I am a former fine arts professor and department head. IMHO, there are two aspects of being an artist. First is mastering the craft of the media you are working in. This could be leather, water color, photography, paint, music, dance. Once mastered, a small percentage of the participants (my guess is 5%) then have the ability to create art using the craft they have mastered. The other 95% produce well crafted items that generally sell at a fraction of those items that are acknowledged as art. Sometimes the process of recognizing a true artists is impaired due to the cultural norms at the time the work is being evaluated. Most great artists have rarely been recognized during their lifetimes, and many who have been are discarded as our cultural aesthetic moves on. As for me, I am definitely NOT an artist with leather. I am only interested in producing affordable products with a market and sufficient profit to justify my time. I consider myself a craft person, or artisan but not an artist. On the other hand, I do consider myself an artist in the realm of music and photography. Although I have supported my self well teaching and doing architectural photography, it was a means to an end. The same with music. I have the option not to either perform nor record anything I don't feel is "artistic". In addition, I will only photograph architecture that is worthy of my efforts, and have turned down many commissions. I have seen many artists displaying their work on this site, work that I am sure, they could never charge enough to pay for their time, but that generally is not top priority for most artists. Just my two cents. Bob
I think you are barking up the wrong mast. Do you have any pictures of your bags with the monster threads? Bob
I have used a black marker for edging which seems to hold up. Permanent marker is soluble in Alcohol. You may want to try to wipe down the belt with Acetone or Methylated Spirits (denatured Alcohol) and remove as much gunk as possible and try again. I doubt it will ever be 100% but you never know. Bob
- 22 replies
- black dye
- black antique
(and 1 more)
That's for sure! I have converted a bathroom to a humidor using a home made swamp cooler which keeps all my leather and musical instruments at 60% Works like a champ! Wne I lived in SFl, everything turned green! Bob
Yep, this time of year is perfect leather weather... wet forming takes no more than an hour or two in the sun at 5% humidity. Where were you in AZ and where are you now? Bob I don't think he considered the practicality of the aesthetics he would like to achieve. With the walking foot and heavy upholstery thread the Singer does an adequate job for the $$. I turn down jobs for any light weight leathers. I find you can't recoup the cost of time in the price. Bob
If you go back to the original post I think you are missing the point. He is not making holsters, which is an ideal task for a 3200. I stitch 5-6oz leather with it and I suspect 4oz would be just too thin, because, in my case, there are parts of an item which requires a stitch through a single layer of 5-6oz and it's very difficult to get the knot right. I doubt a single 4oz would work without a loop. I use heavy polyester and a 110 needle and I get excellent results on thinner leathers and corduras.And for <$200 it's a new machine with a warranty and the option to return it if it doesn't do the job. Bob
My suggestion is to head into a sewing shop like Jo Ann's and bring in some scrap leather and have then load up one of the heavy duty Singers with Polyester Outdoor Upholstery thread and 110 leather needles and do some testing. JoAnn's has the singer heavy duty at $229 with a 40% discount tomorrow. There is an inexpensive walking foot attachment available as well. Again, I have successfully stitched 5-6oz x 2 with this machine and it supplements my Cowboy on thinner materials and fabrics as well as neoprene. Bob
Then we have the problem of BBQ sauce. I am a fan of East Carolina BBQ sauce but will accept the brown stuff in a pinch.. Now where's my spray bottle, I have some leather to case! Bob
- 55 replies
Musical instrument cases. The largest is around 30" Bob
- 22 replies
- black dye
- black antique
(and 1 more)
There was a food show that took real New York Pizza, Boston pan "pizza" and Chicago thin crust "pizza" and did taste tests around the rest of the country. 9 out of 10 preferred the NY Pizza. It is what it is..The speed of light is 186,000 mps give or take and it's not an opinion. Just to address Immiketoo's comment about Rome. I will of course make an exception for Napoli Pizza since they invented what I would consider the precursor and also have the right attitude maintaining strict controls of what can and can't be called pizza. http://www.pizzanapoletana.org/en/chi_siamo So I would accept Napoli Pizza as the great grandfather of New York Pizza. BTW I don't eat at Panda Express, Taco Bell, Opah! or most sushi places. Speaking of Chicago I spent a week in Greek Town..GREAT food! You can even get Retsina. Bob
- 55 replies
No fight or arguments, just like debating the speed of light. It is what it is. There are round flat breads cooked in pans with tomato and cheese goop, thick doughy cakes with tomato and cheese goop and don't even get me started on Pineapple. There's Brooklyn style Pizza (AKA NY Style) and then all the other stuff. As they say, no accounting for taste and some folks drink Bud light..lots of em. If you can see through a glass of beer, I don't drink it and if a slice cracks when you fold it, I don't eat it. Bob Is this quick casing or traditional??
- 55 replies
Sorry Gary, no pizza exists West of the Hudson and SOuth of Brooklyn or North of the Bronx. It's just the way it is. Bob
- 55 replies
There is difference between used and vintage as well. You may find used industrial machines which may cost a bit more but will do the job for many years and also have a reasonable resale price. Toledo, usually in the banner ads, sells used machines and not too far from MI. Bob
