Tejas
Everything posted by Tejas
Tree Reaper would you please report your machine and the settings you use. I recently purchased a Pesola precision spring scale that measures 0 - 300 g the same purpose. I'm still experimenting and have only used it for thread tension, Juki 1508, V-92 thread with a setting of about 275 g. The idea came from the following link. http://sew24.blogspot.com/2012/11/how-to-measure-thread-tension-with.html
I use three tools: For straight cuts -- an Olfa 45 mm rotary cutter on a self-healing 24" x 36" Olfa rotary pad For curves -- Kai 7250 scissors For some fine detail -- Olfa utility knife with various exchangeable blade styles
Threading Singer 211G155... Is This Right? Pic Heavy
Tejas replied to RoosterShooter's topic in Leather Sewing Machines
The manual in the link below might help. http://parts.singerco.com/IPsvcManuals/221G155_211G156.pdf -
The manual in the following link should help. http://keysew.com/Webpages/DemoImages/Juki_LU-563_Instruction_Keyfooter.pdf
- 18 replies
- juki
- juki 563. timing
(and 1 more)
The following Web site should show the model. If the x is a 6, then the model number seems to be 15. http://www.ismacs.net/singer_sewing_machine_company/serial-numbers/singer-ad-series-serial-numbers.html
Perhaps not so much for leather, but you might find information or be able to get response from this forum. http://www.thesewingforum.co.uk/forumdisplay.php?f=135
Would this link help? http://www.pfaff-industrial.com/pfaff/en/service/downloads/technicaldocu/pfaffdocument?doctype=technical&classid=335&is_submitted=1&submitselect=Show+Results#ergebnis
Since the requirement for reinforcement seems to be primarily at the corners and perhaps secondarily on the edges of the seat, since stitching is proposed perhaps lower weight leather could be used and reinforced at the corners and edges with a strip of leather that sandwiches 30 gauge clear vinyl. I've used clear vinyl without failure on boat canvas to reinforce the setting of snaps and grommets.
I'm always looking for projects for our grandson. This is definitely a next project.
Purchased Used Juki Lu-152 Questions On Bobbin
Tejas replied to MsMaggie's topic in Leather Sewing Machines
Actually, kudos should really go to member Gregg From Keystone who I think I recall originally posted this on another forum.- 11 replies
- juki lu-152
- bobbin threading
(and 1 more)
A PM is a private message. However, no longer necessary. http://www.keysew.co...n_Keyfooter.pdf- 11 replies
- juki lu-152
- bobbin threading
(and 1 more)
If the machine is a Juki LU-562 or 563, send a PM and I'll send a .pdf of the manual that seems quite readable to me.- 11 replies
- juki lu-152
- bobbin threading
(and 1 more)
Might not be correct but from memory of other posts on various forums, the -4 was made in Japan and the -5 is made in China. Google searches should help clarify.
Does Compound Feed Mean It Is A Triple Feed?
Tejas replied to Flattracker's topic in Getting Started
I'm just beginning to sew leather and turning even soft leather from inside out has been a hassle. I've made several different prototype bags in heavy stiff-woven fabric that I've never tried in leather precisely because of that problem. Most of my prior experience has been boat canvas, including sticky materials such as vinyl. Feed-dog and presser-foot marks were not a problem sewing sticky materials. Getting the material to feed was the problem but which can be mitigated by sandwiching the material in news-print. After sewing, the newsprint easily tore-away on the stitch line. I've read about feed-dog and presser-foot marks on leather and thought that if newsprint didn't work, I'd try cold tape and if that didn't work, electricians' tape, all both on the top and bottom if necessary. -
A compound walking-foot machine (aka, compound-feed, unison-feed, triple-feed) has both drop-feed (bottom-feed) and needle-feed (top-feed) with an alternating presser-foot (walking-foot). Drop-feed is accomplished by a set serrated feed-dogs that grip the material between the feed-dog and the presser-foot. When the needle is lifted out of the fabric, the feed-dog raises out of slots in the base of the machine and moves the material. At the end of the movement, the feed-dogs drop and relinquish the grip. Needle-feed is accomplished by moving the material with the needle when the needle is in the material as the needle follows essentially an elliptical path. Needle-feed also mitigates the tendency of lower layers of material to feed faster than upper layers with drop-feed machines. The following links might be helpful. The YouTube video also shows the control possible with a servo motor and do click on "show more." http://en.wikipedia....Feed_mechanisms The following thread is excellent for understanding more about industrial sewing machines. http://leatherworker...showtopic=25239 -
The following link describes the 133K8 as a drop-feed, walking-foot machine -- lacks needle-feed. http://www.ismacs.ne...es-100-199.html -
Singer 111W155, Consew 225, Juki Lu-563, Etc
Tejas replied to Ken B's topic in Leather Sewing Machines
This thread might help. http://leatherworker.net/forum/index.php?showtopic=33637 -
I really don't know, but pages 44 - 45 of TM 10-3530-202-10 for the Singer 111W155 might help. http://i742.photobuc...ps28f45d30.jpeg http://i742.photobuc...ps27db8044.jpeg -
I've just started sewing leather and have been struggling with patterning material for a bag. I've been using brown contractor paper that comes in 35"wide rolls. I think I'd prefer something in sheets that is more ridged.
Seiko Lcw 8Bl Service Manual/ Safety Clutch
Tejas replied to xilli007's topic in Leather Sewing Machines
Here is a manual for "Seiko Flatbed" sewing machines that covers resetting the clutch. http://www.supsew.co...at=1105&kbid=87 Click on Seiko flatbed instruction manual -
Don't know if this helps but here is a link to the user manual for a Juki 5550-6 https://noisebridge.net/images/3/3e/Juki-ddl-5550-6.pdf An engineer's manual from Juki would cost $5. Since the manual seems to be for both the -4 and -6, perhaps the manual above might be sufficient. https://www.juki.com/bookstore/products.php?product=DDL%252d5550%252d4-%26-5550%252d6-series-Engineer's-Manual
Tenara is a sub-brand of Gore and is made of PTFE (polytetrafluoroethylene). It seems to be a monofilament and does not seem to require as much needle tension as polyester. It is quite strong and cannot be cut with a hot knife.
Send me a PM for a rather good pdf copy of the user manual.
While perhaps not helpful in this case, here is a a link about a test of various penetrating oils. http://www.practicalmachinist.com/vb/general/ot-penetrating-oil-196347/ "A study done by Machinist's Workshop magazine in their April 2007 issue looked at different penetrating oils to see which one did the best job of removing a rusted bolt by measuring the pounds of torque required to loosen the bolt once treated." Penetrating oil ..... Average load None ...................... 516 pounds WD-40 ................... 238 pounds PB Blaster .............. 214 pounds Liquid Wrench ...... 127 pounds Kano Kroil ............. 106 pounds ATF-Acetone mix....53 pounds
