Everything posted by mikeymoto
Only the top-most sample in that photo was oiled with neatsfoot, then sealed with carnauba cream. I'm using a gallon of distilled white vinegar and 6 pieces of new, fine steel wool. To make the samples above I held in the vinegaroon for at least 60 seconds, then swished around in a baking soda and water mix, then rinsed and let dry. EDIT: Oh yeah, at first I was keeping it in my garage which is not heated. After the 3rd day I brought it inside and set it near a heater vent and I think that helped a good bit. It's mostly sitting inside now except when I take it out for testing.
I'm mixing up my first batch of vinegaroon and have been making samples on successive days to see how the process is coming along. I'm past 10 days now and the surface of the leather is still not turning very black but I will continue waiting and testing. Once it seems like it's not getting any darker then I'll try using it on a project. Here are the first 9 days of samples. I sure like the blue-gray from day 6. The day 9 sample was oiled and sealed.
Hair thingies
mikeymoto replied to howardb's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
I'm a sucker for celtic patterns. Great work! -
Wife's New Purse
mikeymoto replied to rookie's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
That looks really very nice. Can I presume you applied a resist to the raised portions of the carving, but not down in the depressions? Or did you resist all of the non-background areas and the antique pooled up a bit in the low areas? I think it looks great. -
I got Quickbooks when I started my business, but I have yet to figure out how to efficiently enter my receipts for supplies, or how to configure the tax portions so I know how much I owe and to whom! (since I pay city and state tax) I also found something worrisome last night when I was looking at how to enter my receipts for expenses - it seems like my local Tandy is charging .2% less tax than the state things they should be, so it's not clear if I technically still owe the state money (use tax) on portions of those purchases.
Yes. I have the hand press Tandy sells and I use the line 24 dies for pull-the-dots.
This cross-draw knife sheath is a recent example where I used pull-the-dot snaps in conjunction with line 24 snaps. The line 24 is on "top" and the pull-the-dot is on "bottom": My design calls for the top snap to unbutton easily, so the "pin lock" can slide out and rotate away on the second snap. The pull-the-dot snap does not accidentally pull off when you're pulling on the upper snap, since the pull-the-dot only comes off if you pull "up" on it (in the opposite direction). The strap can still be removed if desired for retention-free carry, and is easily replaced. Here you see that the pull-the-dot snap does not sit flush and so it "jiggles" a bit when fastened: Lastly here is the difference in the look of the studs: I stitched around the line 24 stud since it requires some force to unfasten, and I don't want the layers of leather to start pulling apart. Since the pull-the-dot fastener comes undone easily when pulled in the right direction, it does not require the same reinforcement, IMO.
I use pull-the-dot fasteners on 8/9 oz. leather. The diameter of the snaps is for all intents and purposes the same. A line 24 snap can be opened from any direction and snaps firmly in place. A pull-the-dot snap can only be opened when pulled in one direction (so be thoughtful when you set them) and can only be fastened in the opposite direction, and the "standard" pull-the-dot has a lighter snap action than a line 24. I have noticed that they sell a version that is a harder snap, but I have not tried those. When fastened, the pull-the-dot snaps are more loose/jiggly than line 24 snaps. Be careful of the eyelet post length when you buy pull-the-dot fasteners because my experience is that most online places sell short posts for work with linens. The design of the pull-the-dot stud requires a longer post! I recommend the .370" eyelet. Also of note - when setting pull-the-dot fasteners on leather the "dot" does not get stamped into the button. You'll see what I mean about this when you get some. Not a big deal in my opinion as the direction of pull for snaps on a sheath should be self-explanatory. I have bought happily from dotfastenersdirect.com.
My work bench is in my garage and the overhead lighting does not cut it for carving at any time of day. I have a small halogen desk lamp I use when carving, to the front right of the work and pointed in at an angle. This helps me very much!
Up until a couple weeks ago I had used only leather purchased from Tandy. I bought a side of tooling leather from W&C and when I got it I wasn't exactly overjoyed. It looked ok, it wasn't sunburned, it still had some minor defects, but it was not a magical amazing piece. BUT I have to say my first time carving it was last week and the difference there was night and day. Cased the same as other leather I've used, it cut like butter and took impressions really easily. For carving, I'm impressed!
Hehe, been there and done that!
Lots of people like PDF because it is common, and perhaps more importantly because it's an easy way to distribute "read only" copies of documents. It helps prevent other people from making changes to your document and redistributing it. To take full advantage of PDF you need Adobe Acrobat. If you want to read PDFs you can use Adobe Acrobat Reader, or one of many other applications. Some applications let you "save as" PDF format. Others don't. If you want to save as a simple PDF you can get free things to do it, like CutePDF which I have used and it is relatively simple.
I got around to checking the page source and saw it was made using MS Office. The page does not load using Firefox on Linux or Windows. You apparently must use Internet Explorer. Boo on that, but I finally got it opened, so yay on that.
I've tried reading that page before. When I open the link there is no content there!
It would help us if you described how you are ruining the snaps when you try to set them. I mean, what is the end result of your attempt?
I'm pretty sure the page mentioned previously (http://mathcentral.uregina.ca/QQ/database/QQ.02.06/phil1.html) does answer your question. In your case you know the diameter of the upper and lower "rings" of your "cuff" (or whatever your mysterious project is. You also need to choose the length of your project, which I don't think you mentioned. This is arbitrary and can be whatever you want it to be. So let's say for the sake of example that you are making a cuff. The smaller hole (the wrist end of the cuff) is 7" in circumference, the larger hole (where the forearm enters the cuff) is 10" in circumference, and the length of the cuff is 8". What you need to know is where to put the center of your compass to draw the two arcs on your flattened pattern which, when folded, will produce circular openings of sizes 7" and 10". Right? So what you need to determine is the radius of the two entire circles on the pattern, parts of which will be the arcs that when folded make the circular openings. Doing the math on that web page, you find the from a center point, the diameter of the small circle is 18.699" and the diameter of the large circle is 26.713" and your project patterm uses 21.45 degrees of the circles you just drew.
After all the raves about the "head knife" let's get a tutorial on how to use it effectively. I picked one up a couple weeks back but I haven't yet found a good grip or technique that makes it as easy and effective to use as the praise here suggests. I have not spent a lot of time on it, because I have a utility knife that works ok and orders to get out the door. My first few thoughts after I brought the head knife home and sharpened it up were that it looked like a great way to cut my own wrist.
Not that this helps the original poster, but once your swivel knife is sharp you can keep it that way by stropping on something hard with your choice of polishing rouge. If you strop after every time you use your swivel knife, you will never have to take it back to stones or sandpaper. I got my swivel knife from Tandy and the 1/4" angled blade looks to have come with a scandi type grind - a flat grind with no secondary ("micro") bevel. If you want to keep this original grind, do not use a soft-backed material when you strop your knife, or the edge will become convexed pretty quick. If you want a convexed edge, cool, in fact I prefer them on my pocket knives, but you may want to keep the flat grind on your swivel knife.
I recently bought some pull-the-dot snaps from Sailrite and unfortunately I ran into a snag. I'm working with 8oz leather and the post for the stud is way too short. The reason it's too short is because the center of the stud is raised to almost the top. Has anyone found other combinations of Covill/DOT pull-the-dot products that work with thicker leather?
Latests sheath for latest knife
mikeymoto replied to Romey's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Looks great to me! I like how the tooled areas look like an inlay. -
My latest knife sheath
mikeymoto replied to Grunt's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Hi Nick, nice ASH! As was previously mentioned I like how you scalloped the front of the sheath so the handle meshes with it. A classy touch. I also like how the thread color you chose stands out from the sheath's color and is similar to the double cut blade. Cheers! -
Psycho Wallet
mikeymoto replied to steveb's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Your work is incredible. Thanks for posting it!
