Sheilajeanne
Everything posted by Sheilajeanne
  1. Well, the first step is still going to be to dig up the old line, and find just where it goes. That's still a work in progress. If it gives the oil tank and air conditioner a miss, replacing it will be easier. If not, your suggestion is worth a shot!
  2. Here's a better picture of the change purse:
  3. Okay, FINALLY got around to taking photos! The change purse and wallet are projects I had stashed away in a box because I was unhappy with the way they turned out. The tote bag is waiting for me to add a lining to it. The wallet is about the way most of my projects turn out if I antique them. There is some contrast, but not nearly enough. I applied two coats of either Super Sheen or Satin Sheen to it before antiquing. I honestly can't recall if I applied the resist to the whole project or just the area I wanted to protect. It was a long time ago! I know one of the problems with the change purse was the texture of the leather. It would have turned out better if the leather had been smooth veg tan. Also, the tooling could have been deeper, but again, I think that had a lot to do with the temper of the leather. The Molly tote bag was resisted with Resolene. As you will see from the picture of the panels before I assembled it, the finish turned out blotchy, even though I left it to dry for more than a day. I had this happen with a dog collar I did, too, only MUCH worse. It looked so bad I tossed it. And this was with me diluting the Resolene 50/50 with water. I've been so disappointed with the way the Tandy antiques turn out I bought some Fiebing's antique, but the results with it were no better. I can't remember which one I used on the tote bag. The other two were definitely Tandy. What I've done lately is gotten a dark background by painting it with dye and a small brush, as I did with the front of this messenger bag:
  4. Thanks for the suggestion, kgg. Sounds like a good plan. Before it got too hot yesterday, I helped my tenant, W., dig down to where the two sewage lines join just before they go into the tank. Aaaannnd....of course, the line from MY end of the house is also 3 inches in diameter. It isn't covered over by concrete, though...just my back deck. So, the deck is going to have to be partially demolished, and I'll have to find a way of keeping my dog from exploring underneath it, and escaping through the holes in the lattice work at the front of the deck! We don't have the whole of my tenant's sewer line dug out yet, but it's starting to look like it not only goes underneath the oil tank, but also underneath my air conditioner. This job just keeps on gettin' bigger... When the sewer line that was underneath the concrete gets replaced, I'm going to have to bring in some clean fill to bring the surface up to the same level as the existing patio stones. The cement was 4 to 6" thick, while the patio stones are only about an inch and 3/4. Lucky for me, Home Hardware still stocks that pattern of stone, so I will be able to fill in the area with matching stones once it's levelled off. 7:30 am and it's up to 70 F already. Need to finish brekky and get out there and do some digging before it gets too damn hot... The humidex is already 84 degrees, and tomorrow is going to be even hotter with a high of 32 C/90 F! My tenant is fortunate his current day job is working in a nice air-conditioned house! (Which is why I'm pitching in to do whatever I can to fix the plumbing problem.)
  5. My tenant has now uncovered the sewer line that was underneath the concrete slabs. As Frodo will tell you, the main line for a house sewer should be 4 inches in diameter. The line coming from the upstairs apartment in the house is the standard 4 inches. It then drains into a 3 inch diameter pipe, which is what is going into the septic tank. Jeez, how to guarantee flow problems... Installing the correct size of line is going to mean bashing a larger hole in the foundation of the house, and doing the same to the septic tank... Frodo, is that even possible? I'm assuming the original opening into the tank must have been 4 inches in diameter, because that's the standard size. As a friend who's going through some renos on a house with a lot of D.I.Y. 'improvements' has said, 'this is not so much D.I.Y. as it is D.I. WHY??? Trying to keep my sense of humour intact...
  6. Frodo, there's a square spot on the end of a septic tank where the sewer line goes in. I assume the concrete is thinner in that spot. All he did was move the line from the middle of that spot to an inch or so lower. Everything was carefully sealed up with cement, and left for a couple of days to make sure there were NO LEAKS. This had to be done because that end of the tank was slightly higher than the outflow end, due to some settling over the years. It did help, because there were no more sewage backups for a year and a half. I plan to check this area when the line is replaced to make sure the tank hasn't settled any further. (Crosses fingers!) Or may be the tank didn't settle, maybe it was just the sewage line, which has now settled even further, causing the current problems. We'll figure it out - I know how to use a level and plumb bob!
  7. So, I got the last of the big chunks of cement into the trailer this morning, then my tenant took it to the dump. Even though it's free to dump, they had him weigh coming in and going out. The cement weighed 2,425 lbs. Wow. And all of it loaded into the trailer by Yours Truly... I have to say I'm kinda impressed with myself, especially considering what I went through last year! Not a lot being accomplished out there today. The humidex is about 37 C which is about 98 F! By the time W. got back from emptying the trailer, he was just about cooked!
  8. Have no fear, Chuck! My tenant is an contractor with many years experience. And even I know that a sewer line has to be properly bedded, with gravel or some other substrate around it to keep it at the right angle. The soil her is very sandy, so have to make sure the line has a solid base that won't sink again. Have some limestone chips that should do the job, and keep things flowing in the right direction. Since it's the tenant's sewer line that has the problem, that provides additional motivation for him to get it right!
  9. Thank you!! Great little video!
  10. No kidding... I certainly hope the tank is fine. A couple of years ago, my neighbours had to have their entire septic system replaced, after it failed inspection when they were selling their house. It cost them $20,000. . I'm a pensioner, and so far this year, between my animals needing vet care, plumbing problems, and having to install a heat exchanger to keep my tenants from dying of heat stroke*, I've had over $7,500 in unexpected expenses! *The genius who designed the apartment over the garage didn't bother to put in a cold air return, which means the apartment is freezing in winter, and too hot in summer...
  11. For me, the best proof the problem is the sewer line, not the tank, is that the sewer line from my side of the house has been problem free. If the problem really were the tank, it would be backing up too. Guess I should have picked another title for the thread, but I originally thought the problem might be the tank!
  12. The plumber knows where the problem is - it's in the sewer line that goes from the east side of the house (laundry, tenant's apartment over the garage) and joins into the main house line just before going into the tank. There's an area in that line that must have sunk down over the years, and the camera showed the line is completely full of water for a distance of about 10 ft. The water clears up before the camera reached the junction with the other line. When the septic tank was pumped out, we took all 3 covers off it, so we got a really good look at it, and the guy doing the pumping said it looked okay. There were no blockages and no leaks. And it hadn't been pumped out in more than 2 years, so of COURSE it was quite full. The tank has a very slight slope towards the weeping bed end, so it should be fine unless it settles further. We can check on that when replacing the sewer pipe. If the tank has a problem it's at THAT end, not the weeping bed. But the main problem is definitely the sewer pipe, as the camera confirmed. The sewer line has been working fine since the plumber snaked it out. He say he thinks we have about a month before it clogs up again. I'm not so sure about that, and want to get it replaced ASAP!
  13. Stolen from the Tandy FB group...
  14. I live in a small town that has municipal water, but no sewage service. Everyone is dependent on a septic tank. Last year, the sewage line leading to my tenant's upstairs apartment backed up twice. A friend of mine thought he'd fixed it - it looked like the back of the septic tank had sunk down over the years, causing the sewage to have to flow uphill. He dug out the line, disconnected it, and replaced it lower down on the tank. That worked okay until about a month ago, when my tenants reported it was backing up again and there was water all over the laundry room, garage and lower hallway. I called a septic service, and they did an emergency pump out of the tank, for about double what it would have cost if I'd had it done during regular business hours. Although the tank was very full it didn't fix the problem. The next day, I had a plumber come out and snake the line. He said he thought there was a problem with the drain, and part of it must have sunk down. I wasn't happy to hear this, as some time after the drain line was put in place, some idiot poured 4 big concrete slabs over top of it. Fixing the drain was going to be a huge job! 20 days after the snake out, the drain clogged again. Called the plumber, and this time, after snaking the line, he put a camera down, and confirmed the line was full of water/sewage for about a 10 ft. section, 20 feet out from the house. There was nothing I could do but bite the bullet, and take up those damn concrete slabs! So, I rented a jackhammer on the weekend, and my tenant, with help from his son, went to work on it. Two trailer loads of concrete have gone to the dump already, and this is what's left to do. The other picture shows what I've accomplished so far today and yesterday. The dirt next to the patio is from where my tenant dug down beside the foundation trying to find the drain. We eventually figured out the drain exits the house somewhere underneath the door to the patio. We just haven't found the time/energy to fill the hole in yet! Oh, and you see the tank at the far right of the second picture? That's my oil tank. It looks like the sewage line goes underneath the tank, which is going to be REALLY fun... The tank is up off the ground about a foot and a half, so maybe it won't be TOO bad to fix...
  15. Thank you! Wow, his tools are works of art!
  16. JayEl, I asked someone about using petal lifters recently, and they said they DO cut the leather. It helps that the leather they use is top grade Herman Oak, but they also said they practiced a lot first to make sure they didn't accidentally tear the leather instead of cutting it.
  17. I couldn't find any tools by Ed. Anyone have the link? All I found were obituaries!!
  18. Lovely! What do you use to undercut the leaves?
  19. That's some very nice tooling! So there are no initials, names or numbers anywhere that might identify the makers?
  20. jowen, uploading videos off site usually results in links that don't work anymore after several years. Do you have Windows Paint on your computer? It's a standard feature on all Microsoft computers. It should be there even if you've never used it. If so, it's dead simple to resize the picture yourself. Open it in Paint, and you will see a tab that says "Resize picture'. Click on that then select either percentage or pixels. I do pixels, and pick a size that's around 500 pixels. If you resize the one dimension, the other will automatically resize to keep the picture in correct proportion. If you want to keep the original photo, you must give the new one a new name. Select 'save as' in the 'File' menu and give it a new title. Then you should be able to post the new picture here!
  21. Now you're talking fishing gear! https://www.purefishing.com/pages/shakespeare
  22. I need to take some photos. Will get back to you on this!
  23. I am curious to know how you got the very dark background in the journal cover. Did you treat the whole piece with antique, or did you just paint the background with dye, using a small brush? I never seem to be able to get such good contrast using antique, even if I use several coats of resist on my carving!
