Dwight
Everything posted by Dwight
  1. The "trick" is that the pouch is sewn like you said, inside out, . . . then the liner is slipped into it (probably by a machine that forces it seriously back into the recesses of the bag and fills in the voids, . . . the liner also probably swabbed with a quick drying glue, . . . and last but not least, . . . it is stitched around the mouth. I don't understand why you want to turn yours inside out, . . . but if you do, . . . the liner is smaller than the outside, . . . so the outside will krinkle when you do. Otherwise you would need to cut the stitches at the mouth and fish the liner out, . . . then turn the bag inside out to get to the stitches. May God bless, Dwight
  2. Hey, Steveh, thanks for the information. I've got a buddy who has several horses & saddles, . . . I never really thought of him, . . . but I think I'll mosey over his way, . . . take my measuring stick, . . . and put his info together with yours, . . . may get something really promising going that way. Next question: does anyone out there have any "how to" videos or books for sale? May God bless, Dwight
  3. I am 6 ft 1 inch, weigh in at about 195, and I would like to make myself a saddle. Having said that, . . . I have read until I am OD'd on words, . . . trying to figure out what it is that I am looking for, . . . so I just decided to put it to the experts. I don't know anything at all about "sizes" of saddles, . . . but I know what I like, . . . and it would be an older style where the horn is bare metal, . . . and the seat back is more straight up than most saddles found in the saddle shops these days. The stirrups are also leather covered. This would be for a 15 hand quarter mare. Question 1: What do I call that type of saddle? Question 2: Where can I get "plans" for such a saddle? Any help would be appreciated. May God bless, Dwight
  4. Brinyar, . . . thanks for posting your new holster. I really like that design, . . . as it is both esthetically pleasing and functional. I''ve got a small holster to make that will really look good in that style, . . . and had been "brainstorming" how I was going to make it. Your pattern solved my dilemma, . . . if you don't mind my using it. May God bless, Dwight
  5. Simon, . . . I had an older #4 edger that was so dull it would just simply not cut. I bought a new one. Then I got the idea that I could probably sharpen it if I tried, . . . and I am thoroughly pleased with the outcome. I took a 3/16 inch dowel, . . . about 18 inches long, . . . cut the heads off some paneling nails, . . . drilled holes in the dowel for the nails, . . . and nailed the dowel to a board that had a small groove (to keep the dowel straight), . . . and then countersunk the nails so they didn't stick out. I then covered the dowel in valve grinding compound, . . . medium grit, . . . and began stroking my edger BACKWARDS along the dowel for about 75 strokes, . . . beign careful to gently rock the tool in about a 30 degree arc, counterclockwise as I pulled it toward me with my right hand. Afterwards, . . . I put a piece of 8 oz leather that had been edged with my sharp #4 edger on both sides, . . . into another grooved board, . . . leaving it stick up about 1/8 inch and loaded it up with jeweler's rouge, . . . and about 25 strokes later, . . . I have one SHARP edger that actually does a ROUND edging that is really nice for the CCW belts I make in my shop. May God bless, Dwight
  6. Keep an eye on Ebay, . . . very occasionally one will go for less than 900. Take a look on Craigslist, too, . . . stuff pops up there that you wouldn't normally expect. May God bless, Dwight
  7. I have used Velcro on a couple projects, . . . always use Weldwood contact cement to get it in place and keep it there while I sew it. I use my Tippmann Boss, sew it about 1/8 inch in from the edge, all the way around. If it is a big piece (more than 2 inches wide, . . . I also do a corner to corner type "X" to secure the center also. You might try a sewing awl, for just one piece of Velcro, I would probably do that myself. May God bless, Dwight
  8. I did a couple of production runs this spring and summer to get ahead of my anticipated sales, . . . it has not panned out as well as I wanted it to do so far, . . . but that is just a product of the market, . . . and why so many bigger outfits can and do employ "market research" people. I'm getting ready for another small production run, . . . more as samples than as actuall sellable products, . . . and will use them as examples on displays at some local gun shops. But for the majority of my customers: custom, one at a time. That reminds me, . . . got to get to work on the OWB for the Keltec .32 ordered yesterday, . . . May God bless, Dwight
  9. Most of the folks I've talked to here on the internet (myself included) use Durometer 40, gum rubber, . . . it can be purchased from McMaster-Carr industrial sales. It is sold in 1 inch thick x 12 inch wide pieces, . . . cut off a roll. Enough to do most handguns will cost you close to $150. You do NOT use the real gun with this rubber, . . . you use only dummy guns. Foam rubber simply is not stiff enough to give you the impression you are looking for. May God bless, Dwight
  10. Bronson, . . . there are some really authentic looking "would be" guns out there on the market. They used to run in the 60 - 80 $ range, . . . folks used them for display, parades, etc. I saw one once where they put the gun, a sheriff's badge, and an old pair of handcuffs in a frame, mounted over black velvet, . . . honestly I could not distinctivly point out that the gun was a fake, . . . it was that good a replica. I found one place for you: http://www.cowboyprops.com/ but you would do well to get measurements of their wares and compare them to the real thing. Course, . . . there is also a Uberti Cattleman .45 LC on Gunbroker for $255, . . . you would have a perfect mold, . . . plus something to have fun with when you aren't working May God bless, Dwight
  11. One thing you could do, . . . go to a local building supply, . . . try one of the "bargain" outlets, . . . buy the cheapest of their "click together" flooring they have, . . . enough to cover the room. You have to leave 1/4 inch or so all around it, . . . you cover that crack with the blue tape used by painters for edging, . . . and you duct tape the doorway edge to the door threshold. You also need to get the foam for putting under it, . . . don't skimp on this. Here in central Ohio, . . . you could get it for less than $200, . . . and it will not only protect the carpet, . . . but it is super easy to clean up, . . . chairs roll easy on it, . . . and you can put it down in an afternoon. Spills shouldn't go through it if you get to wiping it up quickly, . . . Then, when you get ready to leave, . . . pull it up, . . . put it in your truck, . . . take it to the next place. My leather work shop is my desk in our great room. We have linoleum floors (that'll change in the not too distant future too, to most likely the above mentioned click flooring). I do my sanding in the mud room (with a small vacuum on the sander), . . . my staining and finishing is also done in the mud room, . . . and my only inconvenience is the "grab and hide" when unexpected company starts down our 600 foot driveway. May God bless, Dwight
  12. I'm not sure I can explain this well enough, . . . but if it were mine, . . . for my bike, . . . I'd do a little bit more braiding (see middle photo) on the inside of the lever where your hands do not touch, . . . bringing that out past the knob. I would then very carefully pull all the strands together with the lever in a padded vise, . . . taking care to see that the strands aren't just a gob, . . . but pulled together in a logical sequence, . . . and I would then use black waxed linen or black waxed polyester thread, . . . and use a "Whipping" technique that is usually used to secure the ends of ropes. I would "whip" it for about an inch or so, . . . then get on the internet and learn how to do a turk's head type knot. You can do a small turk's head over the whipping to cover it, . . . and another at the other end of the lever. Do them with a spool of black leather lace from Tandy's. That will let the rest of the strands hang down from your handlebars and look cool parked, . . . and beat the heck out of your bare arms as you tool down the asphalt at 60 By the way, . . . get a 1/2 or 5/8 inch dowel and practice your turk's head, . . . and don't scream/cuss/cry about the first one, . . . it'll be ugly, lopsided, and a few other things. But a little practice and you will like it. May God bless, Dwight
  13. I years gone by, . . . reel covers were more like reel boxes. We just sold one at our church yard sale over the weekend, with a 50 year old Shakespeare bait casting reel. It was about 5 inches long, 3 inches high, and 3 inches wide. It was shaped like an unside down "U", . . . and the bottom 2 inches of the walls were perfectly straight up and down. There were only three pieces to the whole project, . . . one piece was the top and the walls, . . . the second piece made up both ends and the bottom, . . . the third piece was a strap which went to a brass ball button to keep the open end closed. The ends were formed to the shape of the "U" with extra so the one end could be sewn to the top and sides, and the other end would be the cap that opened and closed. The bottom of the sides were sewn to the second piece of leather. It looked like about 8 or 9 oz leather, . . . wish I had taken a picture of it now, . . . didn't think of it at the time. May God bless, Dwight
  14. Thanks, skippy, . . . I guess I need to find a book on braiding or something like that. I do appreciate the return post, though, . . . May God bless, Dwight
  15. Is it IWB or OWB, . . . "behind the hip" or Cross Draw, . . . all of that makes a huge difference in how to make that puppy. May God bless, Dwight
  16. You may want to re think spending your money for their bone folder. The tools you need are easily made or "liberated" from other sources. One of the most used is the rounded end of a "sharpie" pen, . . . it will bone areas around the trigger guard, barrel, shroud, etc. . . . a flat bladed scredriver that has the corners VERY SMOOTHLY SANDED OFF to make a rounded spoon, then bent over at about a 30 degree angle, . . . a 1/8 and a 1/4 inch ball bearing brazed onto opposite ends of a rod. Mold the weapon as best you can with your fingers and thumbs (cut them fingernails off close) then go to the boning with the tools. There are no books, no broshures, no videos that I know of, . . . but practice and trial and error will soon educate you. One of the guys that I met on another site swears by his butter knife for boning out the ejection ports on 1911's, . . . use what you got. The key, . . . most important point about the tool: it must be smoother than old Kruschev's bald head, . . . no scratches, dinks, etc. May God bless, Dwight
  17. I'm not sure where you got the "spring steel needed" information, . . . 'taint necessary. Properly molded, . . . properly finished, . . . properly sewn, . . . it'll hold open. The "best method of actually molding the front of the holster to where it shows the slide line.........." comes from a pile of scrap leather you form into holsters and practice boning and molding them. They're also good for giving to your friends and shooting buddies, . . . they'll sometimes trade for a box of shells or something. May God bless, Dwight
  18. 1) If you have another person to help you, . . . they turn the crank handle, . . . you feed the leather. 2) Make sure it is bolted down securely to a surface that will not move. Any slight movement is aggravated over the length of your strap. 3) Be careful not to try to make too deep an impression, . . . I just about ruined a verrrrrrrrry expensive belt I was making for a customer by wanting a "full and deep" impression. I got away with it that time, . . . won't try it again. May God bless, Dwight
  19. You didn't say how thick the leather is, . . . if it is less than 10 oz, . . . use it for the liner, . . . cut another piece (correct this time) for the outside, and it will look like you intended to make a fully lined holster, . . . just like John Bianchi used to make Seriously, . . . the two pieces will need to be contact cemented together, . . . the edges sanded, . . . burnished, . . . then sew all the edges together except for the bottom edge, . . . then finish it out just like it was only one piece of leather. You and I will be the only ones who knows what happened, . . . and I promise not to tell. For what it is worth, . . . that is the way I make all my western holsters, . . . no single layers for me. May God bless, Dwight
  20. And if it turns out that your order was for the color, . . . have fun is all I can say. I did a really beautiful OWB pancake for a 1911 some months back and since it was a piece just for stock, . . . I bought a bottle of Fiebings "Cordovan" to do one to match a pair of favorite shoes I owned many years back (I was kinda feeling nostalgic,.............). It turned out a really dark orchid, . . . and at the last gun show it made, . . . well, . . . let's just say that it was picked up several times, . . . laid back down, . . . and the folks kinda walked off snickering. I donated it to a local gun related charity auction. May God bless, Dwight
  21. Another fine job, . . . but then we didn't expect any thing else. Looks like your apprentice is coming along fine, too, . . . at least thinking about jobs, . . . getting the right mind set. May God bless, Dwight
  22. I'm looking for some kind of pattern, . . . a friend asked me to make him a 6 footer, . . . but I've never braided anything other than my wife's hair a time or two. Where do I start? May God bless, Dwight
  23. Yep, . . . got that one right, . . . When I read the post, . . . I envisioned gregintenn sewing each loop together as it came through the hole, . . . just goes to prove that even without glasses it sometimes isn't easy to read what is written. Stitching on each end could be most appropriate, . . . depending on what look was desired. May God bless, Dwight
  24. I would not have the faintest idea of why you would do that, . . . unless you fear the whole thing unraveling or something. If it is properly done, . . . the nearest a stitch should come to the loops would be the stitching along the top of the belt. I also make my gunbelts double layer, usually 7/8 leather, contact cemented together, and the loops only go through the outside piece, . . . leaving the liner completely smooth and clean. The loops are also cemented, . . . and don't move, . . . period. May God bless, Dwight
  25. I much prefer Will Ghormley's suggestion: you use a bag punch to make an oblong oval shaped hole, the loop comes up through that hole, then back down through that same hole, . . . making a loop that holds a cartridge. Make another bag punch hole, . . . pull the strap up through it and back down again through the same hole, . . . you now have two cartridge loops. Use 4/5 oz leather for your loops, . . . cut all your holes first, . . . they are spaced at the diameter of the cartridge plus two thicknesses of leather. When you start looping, you need a half box of the ammo it will carry. Put the first loop in, pull it tight around the cartridge, . . . put in the second loop, . . . pull it tight around the cartridge. Don't start this process until you have fully soaked that piece of strap leather in very warm water. Leave the cartridges in the loops until you have finished all the looping. I usually leave them in for another half hour or so, as I am in no hurry when we have gotten this far. It makes a really tight cartridge belt, . . . and the owner can flex it to suit his own taste of how easy he wants his cartridges to come out by simply twisting the cartridge in the loop a bit until it gets where HE wants the flexibility to be. Anchor each end of the strap with a rivet. Oh, . . . yeah, . . . in case you haven't figured it out, . . . not one stitch in this whole process. May God bless, Dwight
