Everything posted by Dwight
Rhodesian Style For A Glock
Dwight replied to brinyar's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Brinyar, . . . thanks for posting your new holster. I really like that design, . . . as it is both esthetically pleasing and functional. I''ve got a small holster to make that will really look good in that style, . . . and had been "brainstorming" how I was going to make it. Your pattern solved my dilemma, . . . if you don't mind my using it. May God bless, Dwight -
Edge Beveler Not Giving The Desired Edge
Dwight replied to SimonJester753's topic in How Do I Do That?
Simon, . . . I had an older #4 edger that was so dull it would just simply not cut. I bought a new one. Then I got the idea that I could probably sharpen it if I tried, . . . and I am thoroughly pleased with the outcome. I took a 3/16 inch dowel, . . . about 18 inches long, . . . cut the heads off some paneling nails, . . . drilled holes in the dowel for the nails, . . . and nailed the dowel to a board that had a small groove (to keep the dowel straight), . . . and then countersunk the nails so they didn't stick out. I then covered the dowel in valve grinding compound, . . . medium grit, . . . and began stroking my edger BACKWARDS along the dowel for about 75 strokes, . . . beign careful to gently rock the tool in about a 30 degree arc, counterclockwise as I pulled it toward me with my right hand. Afterwards, . . . I put a piece of 8 oz leather that had been edged with my sharp #4 edger on both sides, . . . into another grooved board, . . . leaving it stick up about 1/8 inch and loaded it up with jeweler's rouge, . . . and about 25 strokes later, . . . I have one SHARP edger that actually does a ROUND edging that is really nice for the CCW belts I make in my shop. May God bless, Dwight -
Keep an eye on Ebay, . . . very occasionally one will go for less than 900. Take a look on Craigslist, too, . . . stuff pops up there that you wouldn't normally expect. May God bless, Dwight
Velcro: Technique To Hand Stitch Onto Leather
Dwight replied to swivelsphinx's topic in How Do I Do That?
I have used Velcro on a couple projects, . . . always use Weldwood contact cement to get it in place and keep it there while I sew it. I use my Tippmann Boss, sew it about 1/8 inch in from the edge, all the way around. If it is a big piece (more than 2 inches wide, . . . I also do a corner to corner type "X" to secure the center also. You might try a sewing awl, for just one piece of Velcro, I would probably do that myself. May God bless, Dwight -
I did a couple of production runs this spring and summer to get ahead of my anticipated sales, . . . it has not panned out as well as I wanted it to do so far, . . . but that is just a product of the market, . . . and why so many bigger outfits can and do employ "market research" people. I'm getting ready for another small production run, . . . more as samples than as actuall sellable products, . . . and will use them as examples on displays at some local gun shops. But for the majority of my customers: custom, one at a time. That reminds me, . . . got to get to work on the OWB for the Keltec .32 ordered yesterday, . . . May God bless, Dwight
Most of the folks I've talked to here on the internet (myself included) use Durometer 40, gum rubber, . . . it can be purchased from McMaster-Carr industrial sales. It is sold in 1 inch thick x 12 inch wide pieces, . . . cut off a roll. Enough to do most handguns will cost you close to $150. You do NOT use the real gun with this rubber, . . . you use only dummy guns. Foam rubber simply is not stiff enough to give you the impression you are looking for. May God bless, Dwight
Single Six Dummy Gun?
Dwight replied to Bronson's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Bronson, . . . there are some really authentic looking "would be" guns out there on the market. They used to run in the 60 - 80 $ range, . . . folks used them for display, parades, etc. I saw one once where they put the gun, a sheriff's badge, and an old pair of handcuffs in a frame, mounted over black velvet, . . . honestly I could not distinctivly point out that the gun was a fake, . . . it was that good a replica. I found one place for you: http://www.cowboyprops.com/ but you would do well to get measurements of their wares and compare them to the real thing. Course, . . . there is also a Uberti Cattleman .45 LC on Gunbroker for $255, . . . you would have a perfect mold, . . . plus something to have fun with when you aren't working May God bless, Dwight -
One thing you could do, . . . go to a local building supply, . . . try one of the "bargain" outlets, . . . buy the cheapest of their "click together" flooring they have, . . . enough to cover the room. You have to leave 1/4 inch or so all around it, . . . you cover that crack with the blue tape used by painters for edging, . . . and you duct tape the doorway edge to the door threshold. You also need to get the foam for putting under it, . . . don't skimp on this. Here in central Ohio, . . . you could get it for less than $200, . . . and it will not only protect the carpet, . . . but it is super easy to clean up, . . . chairs roll easy on it, . . . and you can put it down in an afternoon. Spills shouldn't go through it if you get to wiping it up quickly, . . . Then, when you get ready to leave, . . . pull it up, . . . put it in your truck, . . . take it to the next place. My leather work shop is my desk in our great room. We have linoleum floors (that'll change in the not too distant future too, to most likely the above mentioned click flooring). I do my sanding in the mud room (with a small vacuum on the sander), . . . my staining and finishing is also done in the mud room, . . . and my only inconvenience is the "grab and hide" when unexpected company starts down our 600 foot driveway. May God bless, Dwight
I'm not sure I can explain this well enough, . . . but if it were mine, . . . for my bike, . . . I'd do a little bit more braiding (see middle photo) on the inside of the lever where your hands do not touch, . . . bringing that out past the knob. I would then very carefully pull all the strands together with the lever in a padded vise, . . . taking care to see that the strands aren't just a gob, . . . but pulled together in a logical sequence, . . . and I would then use black waxed linen or black waxed polyester thread, . . . and use a "Whipping" technique that is usually used to secure the ends of ropes. I would "whip" it for about an inch or so, . . . then get on the internet and learn how to do a turk's head type knot. You can do a small turk's head over the whipping to cover it, . . . and another at the other end of the lever. Do them with a spool of black leather lace from Tandy's. That will let the rest of the strands hang down from your handlebars and look cool parked, . . . and beat the heck out of your bare arms as you tool down the asphalt at 60 By the way, . . . get a 1/2 or 5/8 inch dowel and practice your turk's head, . . . and don't scream/cuss/cry about the first one, . . . it'll be ugly, lopsided, and a few other things. But a little practice and you will like it. May God bless, Dwight
I years gone by, . . . reel covers were more like reel boxes. We just sold one at our church yard sale over the weekend, with a 50 year old Shakespeare bait casting reel. It was about 5 inches long, 3 inches high, and 3 inches wide. It was shaped like an unside down "U", . . . and the bottom 2 inches of the walls were perfectly straight up and down. There were only three pieces to the whole project, . . . one piece was the top and the walls, . . . the second piece made up both ends and the bottom, . . . the third piece was a strap which went to a brass ball button to keep the open end closed. The ends were formed to the shape of the "U" with extra so the one end could be sewn to the top and sides, and the other end would be the cap that opened and closed. The bottom of the sides were sewn to the second piece of leather. It looked like about 8 or 9 oz leather, . . . wish I had taken a picture of it now, . . . didn't think of it at the time. May God bless, Dwight
Thanks, skippy, . . . I guess I need to find a book on braiding or something like that. I do appreciate the return post, though, . . . May God bless, Dwight
Spring Steel For Summer Special Style Holster?
Dwight replied to RWP's topic in Gun Holsters, Rifle Slings and Knife Sheathes
You may want to re think spending your money for their bone folder. The tools you need are easily made or "liberated" from other sources. One of the most used is the rounded end of a "sharpie" pen, . . . it will bone areas around the trigger guard, barrel, shroud, etc. . . . a flat bladed scredriver that has the corners VERY SMOOTHLY SANDED OFF to make a rounded spoon, then bent over at about a 30 degree angle, . . . a 1/8 and a 1/4 inch ball bearing brazed onto opposite ends of a rod. Mold the weapon as best you can with your fingers and thumbs (cut them fingernails off close) then go to the boning with the tools. There are no books, no broshures, no videos that I know of, . . . but practice and trial and error will soon educate you. One of the guys that I met on another site swears by his butter knife for boning out the ejection ports on 1911's, . . . use what you got. The key, . . . most important point about the tool: it must be smoother than old Kruschev's bald head, . . . no scratches, dinks, etc. May God bless, Dwight -
I'm not sure where you got the "spring steel needed" information, . . . 'taint necessary. Properly molded, . . . properly finished, . . . properly sewn, . . . it'll hold open. The "best method of actually molding the front of the holster to where it shows the slide line.........." comes from a pile of scrap leather you form into holsters and practice boning and molding them. They're also good for giving to your friends and shooting buddies, . . . they'll sometimes trade for a box of shells or something. May God bless, Dwight -
1) If you have another person to help you, . . . they turn the crank handle, . . . you feed the leather. 2) Make sure it is bolted down securely to a surface that will not move. Any slight movement is aggravated over the length of your strap. 3) Be careful not to try to make too deep an impression, . . . I just about ruined a verrrrrrrrry expensive belt I was making for a customer by wanting a "full and deep" impression. I got away with it that time, . . . won't try it again. May God bless, Dwight
I Messed Up - Cowboy Holster
Dwight replied to Thong's topic in Gun Holsters, Rifle Slings and Knife Sheathes
You didn't say how thick the leather is, . . . if it is less than 10 oz, . . . use it for the liner, . . . cut another piece (correct this time) for the outside, and it will look like you intended to make a fully lined holster, . . . just like John Bianchi used to make Seriously, . . . the two pieces will need to be contact cemented together, . . . the edges sanded, . . . burnished, . . . then sew all the edges together except for the bottom edge, . . . then finish it out just like it was only one piece of leather. You and I will be the only ones who knows what happened, . . . and I promise not to tell. For what it is worth, . . . that is the way I make all my western holsters, . . . no single layers for me. May God bless, Dwight -
And if it turns out that your order was for the color, . . . have fun is all I can say. I did a really beautiful OWB pancake for a 1911 some months back and since it was a piece just for stock, . . . I bought a bottle of Fiebings "Cordovan" to do one to match a pair of favorite shoes I owned many years back (I was kinda feeling nostalgic,.............). It turned out a really dark orchid, . . . and at the last gun show it made, . . . well, . . . let's just say that it was picked up several times, . . . laid back down, . . . and the folks kinda walked off snickering. I donated it to a local gun related charity auction. May God bless, Dwight
Fathers Day Gift Set
Dwight replied to Lobo's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Another fine job, . . . but then we didn't expect any thing else. Looks like your apprentice is coming along fine, too, . . . at least thinking about jobs, . . . getting the right mind set. May God bless, Dwight -
I'm looking for some kind of pattern, . . . a friend asked me to make him a 6 footer, . . . but I've never braided anything other than my wife's hair a time or two. Where do I start? May God bless, Dwight
Cartridge Loop Question
Dwight replied to gregintenn's topic in Gun Holsters, Rifle Slings and Knife Sheathes
Yep, . . . got that one right, . . . When I read the post, . . . I envisioned gregintenn sewing each loop together as it came through the hole, . . . just goes to prove that even without glasses it sometimes isn't easy to read what is written. Stitching on each end could be most appropriate, . . . depending on what look was desired. May God bless, Dwight -
I would not have the faintest idea of why you would do that, . . . unless you fear the whole thing unraveling or something. If it is properly done, . . . the nearest a stitch should come to the loops would be the stitching along the top of the belt. I also make my gunbelts double layer, usually 7/8 leather, contact cemented together, and the loops only go through the outside piece, . . . leaving the liner completely smooth and clean. The loops are also cemented, . . . and don't move, . . . period. May God bless, Dwight -
I much prefer Will Ghormley's suggestion: you use a bag punch to make an oblong oval shaped hole, the loop comes up through that hole, then back down through that same hole, . . . making a loop that holds a cartridge. Make another bag punch hole, . . . pull the strap up through it and back down again through the same hole, . . . you now have two cartridge loops. Use 4/5 oz leather for your loops, . . . cut all your holes first, . . . they are spaced at the diameter of the cartridge plus two thicknesses of leather. When you start looping, you need a half box of the ammo it will carry. Put the first loop in, pull it tight around the cartridge, . . . put in the second loop, . . . pull it tight around the cartridge. Don't start this process until you have fully soaked that piece of strap leather in very warm water. Leave the cartridges in the loops until you have finished all the looping. I usually leave them in for another half hour or so, as I am in no hurry when we have gotten this far. It makes a really tight cartridge belt, . . . and the owner can flex it to suit his own taste of how easy he wants his cartridges to come out by simply twisting the cartridge in the loop a bit until it gets where HE wants the flexibility to be. Anchor each end of the strap with a rivet. Oh, . . . yeah, . . . in case you haven't figured it out, . . . not one stitch in this whole process. May God bless, Dwight -
Ranger Belt Questions
Dwight replied to dmr400's topic in Gun Holsters, Rifle Slings and Knife Sheathes
DMR, . . . sorry it took so long, . . . but here is the information you wanted. Holler back if you have any questions. I also will not let a ranger belt out that is not stitched 360 (just my way of doing things), and I stitch em at about 3/16" from the edge, . . . using a stitch grover on both sides. Dan, . . . billets are only one layer, . . . but I am careful to select it away from the hard edges of a hide as well as away from the soft underbelly. Have fun guys, . . . May God bless, Dwight -
Must be something in the air, . . . looking for another "pattern" help. Got a call from a customer who wants a 6 foot "Lash Larue" type bull whip. I've never made such an animal, and while I could probably muddle through it, just wondering if anyone has a "pattern" for it. Sure would appreciate it if you have one you would care to share. I'm thinking of about a 12 inch long, 1 inch diameter wooden dowel handle, with the leather laced together around it, . . . all one piece going out to the whip part, . . . split, tapered, and woven (6 braid), with a 1 by 6 "cracker" on the end. I'd finish it out with woven rosettes around the base and top of the handle, with a 12 inch pair of thongs hanging down. Any help would be greatly appreciated, . . . just one thing more, . . . this will be more decorative than anything else, . . . but should be useable if needed. May God bless, Dwight
Thanks, guys, . . . I had envisioned doing both things, . . . but with the price of 13-15 oz leather, . . . I kinda thought it best to get an opinion from someone who has "been there, . . . done that". I really like the idea of doing Kevin's idea, I'm just wondering how many times I'll have to change the blade in my strap cutter before I get done with the thing Anyway, . . . haven't gotten the call, . . . but I'm ready if she does. May God bless, Dwight
