CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. NO,don't ever take it apart,just oil everything & use it.It will loosen up as you use it.
  2. When you thread the lower disc you need to go past the little oval window @ the 10:00 position.
  3. This shaft has a clamp on the other end that you need to loosen only when your setting the needlebar to match the feed dog.Otherwise it should be tight & only move when you turn the handwheel.There's a hole on the backside of the casting to access the big screw on the clamp.
  4. Yes,it looks like a 562 take up lever the 563 is longer.How does it sew?I doubt it will make much difference.
  5. He means he held the button down (make sure the button is in the notch) while turning the handwheel towards you & when it broke lose it made a noise.
  6. The leather your sewing has to be thick enough to hide the knot,try 2 or3 layers.
  7. Hey TJ,always remember to stop & start with the takeup lever all the way up,in the pic above it is down & that is why you have extra threads from the bobbin because when you stop with it all the way up it releases it from the hook.
  8. Here's how to adjust needle to shuttle clearance 441 needle to shuttle clearance adjustment.pdf 441 Engineers manual.pdf
  9. Many walking foot machines have a bracket the adjust for left & right movement of the whole needlebar assembly.See the attached pic there are 2-screws behind it to loosen & hold it against the bracket & re-tighten if you need to.
  10. If you moved the hook to the left you "might" have too little clearance between the tab on the hook base & the cutout underneath the needle plate,you can either open up the cutout on the needle plate or move it slightly to the right.
  11. I think the clutch is kicked out,take the bobbin out,try pushing on the stitch length button ,turn the handwheel backwards until it goes into the slot,while holding the button down push the handwheel backwards until you hear a click or until it just won't turn anymore.This "should" get the clutch re-engaged.
  12. Put the screw for the eccentric, marked S on the eccentric into the slot (or V on the shaft)once you get it pushed to the left where it belongs & tighten the screw should get it feeding again.
  13. @gordonl We stock these from size #19-#27
  14. @AlZilla That guy in Toledo has them!
  15. $75.00 w/shpg.the shaft can be hard to get out you need to sand it lightly as it gets rust & dirt on it.Then oil it so it slides out easier.
  16. Turn it all the way one way,run it ,then turn it all the way the other,it should eventually go more & more each time.
  17. @friquant The new stitch length cam I have in stock uses allen screws to the shaft.the others are still slotted.
  18. I'll agree with @kgg the brush motor is the one to go with we might have 2 out of 1,000 go bad where we had 3 out of 10 of the brushless type go bad & gave up on them.
  19. There's 2 ways to fix it,replace it OR try sewing & using it w/o locking it up should make the part rock in the grooves to get it to free up,you need to tighten the smaller screw since that is what connects the stitch cam to the shaft.
  20. There's a wingnut adjustment on the back side you need to move to the "H" side.This will make the foot lift higher when it walks.
  21. The easiest way to check the hook timing on this type of machine is if you drew an imaginary line from the center of the bobbncase to the center of the front needleplate screw the point of the hook should be directly under it when the needlebar is all the way down.
  22. Grab theneedlebar & push it front to back to check for play,make sure the hook tip is good & that the bobbincase isn't too loose.Then some samples of what you want to sew along with some thread ( in case they don't have any) & see if it will sew your material ok.These are great machines just keep it oiled good & all the parts are still available.
  23. So is the long groove of the needle facing the front?Do you have a manual for it?
  24. I hate to ask,but are you sure your turning it the right way?
  25. Yes,when it kicks out it will hit there until it gets re-engaged.It's not going in the groove because your not pushing the handwheel backwards with enough force WHILE holding the button down.Since you don't want to do what I'm telling you you can get a wide screwdriver put on the lower part of the left pin & top of the right pin give it a twist (clockwise)& it'll pop back in the groove.
