CowboyBob
Contributing Member
Everything posted by CowboyBob
  1. @JukiFan There are quite a few reasons for skipping but one very overlooked one is a wore our needlebar,from tightening the needle set screw over many years the hole gets enlongated to the left side forcing the needle to set @ an angle so the thicker your sewing as the needle goes in it will pull it away from the hook causing skipping.The test is loosen the needle set screw & note how far it moves left to right.
  2. I've worked on 1,000's of stuck machines over the years & this is what I do.Mixup alittle used motor oil & diesel fuel 1/2& 1/2 lube both bushings every couple hrs with a couple of drops & tap on the bar with a solid piece of metal drive pin as big or bigger than the pressure bar using a hammer(light to medium taps) & eventually it'll break loose.
  3. How much play does the arm have that the opener fastens to?BTW it only needs to barely open just alittle,you could be trying for too much.
  4. Here's a manual for a machine like a 337 205RB-1.pdf
  5. Usually the smallest you can use for 138 is size140
  6. Thread underneath the base(on the left) instead on going between it.
  7. Only the 16-188 has the foot that pulls,the 16-141 has a spring loaded foot.Also convert the machine to use the 135x16 for leather,it measure approx 1 & 3/4" long & probably has already been converted.
  8. It mounts in one of these three holes already drilled & tapped in the bed, usually it will be the front one.
  9. Yes,same length.
  10. You have a belt pulley,feed cam & needlebar crank to take all the screws out of & then you have to get in there & clean the 50 yr old crud off of the shaft so it will slide out the tight tolerances that these parts are in.I usually slide shaft in & out,clean,slide,clean,cuss!
  11. This one is as close as you can get for one.Your model is a copy of the Singer 111w except your has reverse. 111w Navy Repair manual.pdf
  12. Great looking work.We have used the 1.5 amp 9000 rpm version of this motor on Singer 29 patchers in the past & they work pretty good.You have to use a stronger foot pedal with it as the motor will fry a standard pedal.
  13. When we sell one of these we always buff off the feet if they are sewing leather & do the same on the Consew's too.They don't mark then.AFAIK there are no smooth feed dogs for them.
  14. Be real lucky to sew 3/8"leather on this model,it is more suitable for vinyl & canvas than leather.
  15. Singer never made service manuals for any of their machines,if you need service they would send their factory trained techs to you.So the closest you can get is thei one for a similar Juki 158. Juki 158 operators manual.pdf
  16. NO,don't ever take it apart,just oil everything & use it.It will loosen up as you use it.
  17. When you thread the lower disc you need to go past the little oval window @ the 10:00 position.
  18. This shaft has a clamp on the other end that you need to loosen only when your setting the needlebar to match the feed dog.Otherwise it should be tight & only move when you turn the handwheel.There's a hole on the backside of the casting to access the big screw on the clamp.
  19. Yes,it looks like a 562 take up lever the 563 is longer.How does it sew?I doubt it will make much difference.
  20. He means he held the button down (make sure the button is in the notch) while turning the handwheel towards you & when it broke lose it made a noise.
  21. The leather your sewing has to be thick enough to hide the knot,try 2 or3 layers.
  22. Hey TJ,always remember to stop & start with the takeup lever all the way up,in the pic above it is down & that is why you have extra threads from the bobbin because when you stop with it all the way up it releases it from the hook.
  23. Here's how to adjust needle to shuttle clearance 441 needle to shuttle clearance adjustment.pdf 441 Engineers manual.pdf
  24. Many walking foot machines have a bracket the adjust for left & right movement of the whole needlebar assembly.See the attached pic there are 2-screws behind it to loosen & hold it against the bracket & re-tighten if you need to.
  25. If you moved the hook to the left you "might" have too little clearance between the tab on the hook base & the cutout underneath the needle plate,you can either open up the cutout on the needle plate or move it slightly to the right.
