Everything posted by RockyAussie
Best I can tell 2.8 point is just under 1mm and from my experience 1.2mm is a good minimum width for clear stamping but this depends on the overall stamp somewhat. Thinner at the end of lines and in some texts it can still work fine.
That is a nice looking glasses case. The edging could have been a little better but I have seen plenty a lot worse. I would not think of making it for under $60.00au which would be about 35 euro. Patterning time will often take longer than the actual job and I do use Autocad and a laser and 3D printing regularly as well. For me I would still be losing at $60.00au but the next time I would be in front.
Sewing machine stitches slanted-CB4500
RockyAussie replied to Crest's topic in Leather Sewing Machines
If the part you are sewing tappers thinner toward the edge it will often want to feed out away from that edge depending on what feet you are running as well. -
As @AlZilla mentioned above the needle tip shape type can give an angled stitch such as an LR which gives a saddle stitch look. A TRI point needle will give a straight stitch if that is what you want. If you are having to hold the job inward as you go you overcome this fairly well with a guide that is angled slightly closer at the back behind where the needle is. This video I ade some time back shows how you can pretty much set up a guide that does not require you to hold it at all. -
Vilh. Pedersen 282 clicker press manual
RockyAussie replied to RockyAussie's topic in Leather Machinery
Thanks you for that Jonas, I had found that as well and sent him a message but unfortunately he has not been on LW since May this year. I may try and contact Seick as you suggested and see how that goes. I would really like to know what oil grade it takes at least. I was hoping that someone from Denmark or near to there may know something but no luck as yet. Thanks again for trying. Brgds Brian -
Does anybody have one of these that could advise me what grade of oil it should use? -
Tall Post Sewing Machines?
RockyAussie replied to Cumberland Highpower's topic in Leather Sewing Machines
Mine is not great compared to most of my other machines for sitting at but I use an adjustable high stool which is close to standing height. That means the knees are not a problem as they barely go in under. I have an adler post as well that is set on an angle like the picture posted by @nylonRigging but that is how I bought it set up. I would be somewhat concerned about how the oil falls down and through on the tall post to do that without checking every oil hole for proper lubrication. -
This following link shows the tall post machine I have. Note that the max thread size is 138. The needle goes into the right side which is good for allowing wide products that can be held out in the open left side if that makes sense. -
The foot is held in place with a tapered pin same as the FAV and Fortuna machines. The 1mm washer was needed to allow the sliding lock in thing to position better for holding and angle adjustments.
help choosing first leather sewing machine
RockyAussie replied to TakashiOkada's topic in Leather Sewing Machines
That would be my choice and is the same as mine which can do about 90% of the work I do at Wild Harry. Note that the feet available on this machine have the same as the old Singer 111W machines which covers about anything you could ever want. Also note that this is for the head only and you may want to get a table and servo motor from them as well perhaps. Do not get the U shaped table as they get in the way too much as shown in the following video which is a different machine but shows the same problem - -
I believe that neither of those machines would be ideal for the work you are wanting to do. Check out this video I did awhile ago as it will point out some of the features for you to consider. I do not know what machines you have there in your world but a google search for a 246 cylinder arm machine should bring up a few to pick from. Note that they are generally not very expensive normally. -
They seem not to move at all for quite a few turn which is why they normally supply a winding handle I guess. 20 turns will hardly seem much.
Yes there is. I gave up trying to use the revolving type years ago and now use a diamond tipped dressing tool. This picture is one I found on Amazon which looks a bit like mine. They work a lot better and way quicker so be careful not to go in to hard with it.
It looks like you have the bell too far forward and it is under the presser foot which will stop it from working. Also I think I see a large chip out of your blade which will need to be sharpened out. Follow through the steps in this video I made and note the distance from the presser foot to the bell edge is adjusted correctly and then again after you have sharpened the chip out.
My Vilh Pedersen 282 clicker press is not working much good and I need some pics that show off the Hydraulic system. If anybody has a manual please let me know.
Looking back with a Google search I found where I had covered most of this before which this link will show - https://leatherworker.net/forum/topic/74966-skiving-foot-roller-adaptation/ A google search shows many places where you can buy the foot if if search for Skiver machine feet. This is one of the links - https://www.aliexpress.com/item/1005007201599493.html?UTABTest=aliabtest116529_13360&src=google&albch=shopping&acnt=742-864-1166&slnk=&plac=&mtctp=&albbt=Google_7_shopping&gclsrc=aw.ds&albagn=888888&ds_e_adid=&ds_e_matchtype=&ds_e_device=c&ds_e_network=x&ds_e_product_group_id=&ds_e_product_id=en1005007201599493&ds_e_product_merchant_id=737156300&ds_e_product_country=AU&ds_e_product_language=en&ds_e_product_channel=online&ds_e_product_store_id=&ds_url_v=2&albcp=21819463808&albag=&isSmbAutoCall=false&needSmbHouyi=false&gad_source=1&gad_campaignid=21819486122&gclid=Cj0KCQjwmK_CBhCEARIsAMKwcD7-i82gtRujZKf-0mTTOoPLs1oluw2sHNuCF5m-3G7DXzDKElWbywoaAj1oEALw_wcB&aff_fcid=b0641e9eba1743978ba53a9cf2920541-1749867580452-01047-UneMJZVf&aff_fsk=UneMJZVf&aff_platform=aaf&sk=UneMJZVf&aff_trace_key=b0641e9eba1743978ba53a9cf2920541-1749867580452-01047-UneMJZVf&terminal_id=08d6618945bb478d98d0dbef180895e0&OLP=1108200108_f_group4&o_s_id=1108200108&afSmartRedirect=n
Hi @Trox, yes that is one of my skiving machjines in the video. @TomE has shown a link above that looks to be the same wide guide that I use. Unfortunately the roller foot is not the same as the one in the video but I have recommended the one he has in the link many times. For a long time now that one never seems to be in stock anymore. I will have a search to find the one I used in that video and get back to you tomorrow all going well. In other videos of mine you can see a different one that I made myself. It still gets the most use of them all. Basically it is a 50mm foot cut back and a hard concrete nail used for the brass roller to spin on. I will do some pictures to show that better tomorrow as well.
A big congratulations on getting your first industrial machine. I look forward to seeing some pics of your bags and purses as you go.
Albeko 83S splitting machine band knife size?
RockyAussie replied to snisson's topic in Leather Machinery
Same as the 83K I have. -
In the past I have sometimes polished the tips of my needles to not be so sharp to help stop them cutting threads so much when back stitching or going over threads already in place. On this particular job I was aiming to make a belt that could be worn both inside and out so I wanted to be sure to have a needle sharp enough to not pucker on the bobbin side. The stitching was done on my Cowboy 4500 with a new 160/23 LR Schmitz needle and 138 poly bonded thread. The stitching went very well all the way from the start up to the last four stitches. This resulted in 3 different threads being cut right through as shown in the pics below. My Cowboy machine knows a few new #%^& words now and like my machine I just never stop learning. I started the stitching at the top of this join went around until I got to the bottom to over stitch and the swearing began. Double needles needed to fix came out alright in the end.
Zipper tabs on a pouch, why might one make a "split" zipper tab?
RockyAussie replied to AEBL's topic in Sewing Leather
Those are my thoughts as well but the rest of the work looks high quality. -
Very good effort. I have yet to do the style of gusset myself but I will have to give it a try sometime. Does your Adler 69 allow you to get around the gusset sides better than the Global 1335? I am curious if the Global 1335 machine has a reciprocating feed dog or does the feed dog only move back and forward like the Adler69?
Possible to Repair Acrylic Window in Wallet?
RockyAussie replied to Hardrada's topic in Leatherwork Conversation
I think you already know the answer to this so the quicker you just do it the quicker you can put it to rest. Sorry friend. Beautiful work though. -
Common Issues in Hot Stamping – Let's Share and Solve Together
RockyAussie replied to Jinglin's topic in How Do I Do That?
Thank you for the reply. I get asked a lot about stamps on a couple of Facebook forums that I moderate on in Australia so it is always handy to be able to offer up alternative answers. I supply a lot of molds and other stuff to other leather workers in my country. I have been using hot and foil stamping now for many years so I don't have many problems stamping the bags so long as the leather is suitable and the stamp is not too busy. Stamps that have a lot of large flat areas in them can be a problem so I advise customers of this and sometimes alter the artwork to work better.- 3 replies
- hotstamping
- hotstampingtips
(and 1 more)
I have just checked out your website and am wondering if the $ dollars shown are USA dollars? I am in Australia. The brass letter stamp sets look interesting. Also I think you can put a hot link to the JingLin business from the profile settings on here.- 3 replies
- hotstamping
- hotstampingtips
(and 1 more)
