Everything posted by RockyAussie
Mostly your top tension looks to be too tight. Try turning back anticlockwise about 1/2 turn. It also looks a bit intermittent which could mean that the needle size should be a smaller size for that weight leather. What size thread and what size needle are you using here? Also are you using a leather point needle?
The most important thing is having it set up right and very very sharp. This video I made should be of help -
Pros And Cons: Cylinder Vs Post Vs Flat Bed
RockyAussie replied to MartyS's topic in Leather Sewing Machines
If it is of any help this video is a tall post machine I use when making some of our bags - -
I think you may find that the main problem you are having is caused by the top thread cones not being the right type for running vertically as you have them. Most leather workers would use cones with a splay at the bottom which stops the thread from getting hooked up as it pulls off of the cone at the bottom. Also most will use either a bonded nylon or bonded Polyester thread which will behave a lot better going the through the tension guides.
I have in the past made several different size punches like this myself. I do find a bolt slightly smaller than the hole and wrap some tape around it to keep it firmly held in place for being hit with a mallet or hammer but loose enough to remove and get out the waste occasionally. I generally make up a mild metal shape about the same as the inside hole of the punch I am making and after a bit of shaping use it to refine the end shape of the punch. I make quite a few from stainless tube which works pretty well.
Best I can tell 2.8 point is just under 1mm and from my experience 1.2mm is a good minimum width for clear stamping but this depends on the overall stamp somewhat. Thinner at the end of lines and in some texts it can still work fine.
That is a nice looking glasses case. The edging could have been a little better but I have seen plenty a lot worse. I would not think of making it for under $60.00au which would be about 35 euro. Patterning time will often take longer than the actual job and I do use Autocad and a laser and 3D printing regularly as well. For me I would still be losing at $60.00au but the next time I would be in front.
Sewing machine stitches slanted-CB4500
RockyAussie replied to Crest's topic in Leather Sewing Machines
If the part you are sewing tappers thinner toward the edge it will often want to feed out away from that edge depending on what feet you are running as well. -
As @AlZilla mentioned above the needle tip shape type can give an angled stitch such as an LR which gives a saddle stitch look. A TRI point needle will give a straight stitch if that is what you want. If you are having to hold the job inward as you go you overcome this fairly well with a guide that is angled slightly closer at the back behind where the needle is. This video I ade some time back shows how you can pretty much set up a guide that does not require you to hold it at all. -
Vilh. Pedersen 282 clicker press manual
RockyAussie replied to RockyAussie's topic in Leather Machinery
Thanks you for that Jonas, I had found that as well and sent him a message but unfortunately he has not been on LW since May this year. I may try and contact Seick as you suggested and see how that goes. I would really like to know what oil grade it takes at least. I was hoping that someone from Denmark or near to there may know something but no luck as yet. Thanks again for trying. Brgds Brian -
Does anybody have one of these that could advise me what grade of oil it should use? -
Tall Post Sewing Machines?
RockyAussie replied to Cumberland Highpower's topic in Leather Sewing Machines
Mine is not great compared to most of my other machines for sitting at but I use an adjustable high stool which is close to standing height. That means the knees are not a problem as they barely go in under. I have an adler post as well that is set on an angle like the picture posted by @nylonRigging but that is how I bought it set up. I would be somewhat concerned about how the oil falls down and through on the tall post to do that without checking every oil hole for proper lubrication. -
This following link shows the tall post machine I have. Note that the max thread size is 138. The needle goes into the right side which is good for allowing wide products that can be held out in the open left side if that makes sense. -
The foot is held in place with a tapered pin same as the FAV and Fortuna machines. The 1mm washer was needed to allow the sliding lock in thing to position better for holding and angle adjustments.
help choosing first leather sewing machine
RockyAussie replied to TakashiOkada's topic in Leather Sewing Machines
That would be my choice and is the same as mine which can do about 90% of the work I do at Wild Harry. Note that the feet available on this machine have the same as the old Singer 111W machines which covers about anything you could ever want. Also note that this is for the head only and you may want to get a table and servo motor from them as well perhaps. Do not get the U shaped table as they get in the way too much as shown in the following video which is a different machine but shows the same problem - -
I believe that neither of those machines would be ideal for the work you are wanting to do. Check out this video I did awhile ago as it will point out some of the features for you to consider. I do not know what machines you have there in your world but a google search for a 246 cylinder arm machine should bring up a few to pick from. Note that they are generally not very expensive normally. -
They seem not to move at all for quite a few turn which is why they normally supply a winding handle I guess. 20 turns will hardly seem much.
Yes there is. I gave up trying to use the revolving type years ago and now use a diamond tipped dressing tool. This picture is one I found on Amazon which looks a bit like mine. They work a lot better and way quicker so be careful not to go in to hard with it.
It looks like you have the bell too far forward and it is under the presser foot which will stop it from working. Also I think I see a large chip out of your blade which will need to be sharpened out. Follow through the steps in this video I made and note the distance from the presser foot to the bell edge is adjusted correctly and then again after you have sharpened the chip out.
My Vilh Pedersen 282 clicker press is not working much good and I need some pics that show off the Hydraulic system. If anybody has a manual please let me know.
Looking back with a Google search I found where I had covered most of this before which this link will show - https://leatherworker.net/forum/topic/74966-skiving-foot-roller-adaptation/ A google search shows many places where you can buy the foot if if search for Skiver machine feet. This is one of the links - https://www.aliexpress.com/item/1005007201599493.html?UTABTest=aliabtest116529_13360&src=google&albch=shopping&acnt=742-864-1166&slnk=&plac=&mtctp=&albbt=Google_7_shopping&gclsrc=aw.ds&albagn=888888&ds_e_adid=&ds_e_matchtype=&ds_e_device=c&ds_e_network=x&ds_e_product_group_id=&ds_e_product_id=en1005007201599493&ds_e_product_merchant_id=737156300&ds_e_product_country=AU&ds_e_product_language=en&ds_e_product_channel=online&ds_e_product_store_id=&ds_url_v=2&albcp=21819463808&albag=&isSmbAutoCall=false&needSmbHouyi=false&gad_source=1&gad_campaignid=21819486122&gclid=Cj0KCQjwmK_CBhCEARIsAMKwcD7-i82gtRujZKf-0mTTOoPLs1oluw2sHNuCF5m-3G7DXzDKElWbywoaAj1oEALw_wcB&aff_fcid=b0641e9eba1743978ba53a9cf2920541-1749867580452-01047-UneMJZVf&aff_fsk=UneMJZVf&aff_platform=aaf&sk=UneMJZVf&aff_trace_key=b0641e9eba1743978ba53a9cf2920541-1749867580452-01047-UneMJZVf&terminal_id=08d6618945bb478d98d0dbef180895e0&OLP=1108200108_f_group4&o_s_id=1108200108&afSmartRedirect=n
Hi @Trox, yes that is one of my skiving machjines in the video. @TomE has shown a link above that looks to be the same wide guide that I use. Unfortunately the roller foot is not the same as the one in the video but I have recommended the one he has in the link many times. For a long time now that one never seems to be in stock anymore. I will have a search to find the one I used in that video and get back to you tomorrow all going well. In other videos of mine you can see a different one that I made myself. It still gets the most use of them all. Basically it is a 50mm foot cut back and a hard concrete nail used for the brass roller to spin on. I will do some pictures to show that better tomorrow as well.
A big congratulations on getting your first industrial machine. I look forward to seeing some pics of your bags and purses as you go.
