ojd
Everything posted by ojd
Ah, it was cow camp saddlery! Sometimes you just need to let the mind wander to remember things.
Hi, few months ago I found thru this forum a site selling good modern looking chaps and chinks patterns. But I can't for my life find it now. It wasn't klendas it was something else. (Obviously not tandys either). Can anybody please help me suggest which site it was? Maybe something with cowboy, mountain or something else in the same.
Looks like an interlock topstitch on a shuttle stitch seam. Common on old jersey sportswear, but in that application you have a spreader thread on top If you look closely it looks as if there are loops on the wrong side typical of chainsewing machines. Union special made feed up the arm machines for top stitching seams like this, i.e. needle plates, feed dogs and presser feet for shaping the seam allowance like this. Never seen it in leather though but the machines are more than capable of garment weight leather.
In those small concentrations (i.e. 5%) it is not harmful. It is harmful to some chrometanned. Not veg tan.
Its for wax container on machine. I do't like nears foot oil. Or any oil on leather.
Hi. I tried buying wax solution to no avail (without ordering from the US). I would like to avoid solvents so I did a 5 minute google "research". It turned out borax can emulsify beeswax. Since I have no impulse control whatsoever I made some emulsion. I'm gonna test it in my machine later. A bit thicker than water, like cream. What I did was: -one part bees wax -one part 10% (by weight) borax solution. I used tap water, probably better with distilled. Heat both, until the wax has melted in a water bath. Recipe said to 70 degrees centigrade (no idea what that is in freedom units™️) but my wax melted at 78 degrees. In a third likewise heated container mix the two under vigorous stirring. Keep stirring until 40 degrees centigrade. Obviously it's an emulsion, just gotta test if it's good as a wax. Please try and see if it works for you.
Yes, needle feed. Also has a little extra guide bar below the needle plate which pushes on the needle. The bobins are like a small thread spool. Two discs on a hollow axle. I can make a video when I get the time. Max. Stitch length is rather short, about 6-7 mm. Foot lift is good tho.
Yes, excellent. Thanks to the manual I managed to get mine up and running. Or, maybe more like I prioritised it. Now I need a supply of needles. I'm running low on 45 degree cutting point needles. Attached a photo of my machine. (Annoying file size limit, we're not living in the age of fax modems anymore). Not my fudgy looking weld on the cracked base! I can do it better than that!
@samadlingtonleather Yes please do that. Sent you a pm with my mail
Wizcrafts, all your positive response in virtually EVERY thread on needle and awl machine is about to hurt my economy, my relation and my peace of mind.
Thank you for answers. I will try. I have an australian stock saddle with a attachment thingy for a crupper. I think it will help my saddle from creeping forward during steep descents. Yes, I also need to awl it and restuff it.
Hello, I'm looking for patterns for a crupper. Does anyone have one?
I'm still trying to find a manual for BUSM pilot sewing machine. Anyone?
Singer industrial has most manuals and part lists online.
I operate and manage a knitting mill as my 'day job', we use a lot of binders for various seaming operations on knitted apparel. From my experience, there is no field where the old saying 'you get what you pay for' is more true than binders. The amount of time I've spent desperately trying to file, bend and braze bad binders is something I would like not to Think off. We only buy suisei (japan) or rimoldi (italy) these days. Make sure you buy the right 'gauge' for what you're gonna sew. Otherwise the tape will cause a drag, and you will get a really bad finish. On Machines for knits there is almost Always a differential that you can adjust to somewhat counter the drag from the tape, but it can't rectify even modest faults caused by bad binders. We buy some from college sewing machine parts as mentioned above. They're a real gem for sure. We also deal a bit with local machine dealers, not really good prices, but we get binders that do exactly what we want them to do, and they can be used 12+ hours a day without moving around, causing drags, or even worse, production stops. We also want to have local machine businesses around, so by buying locally we're voting with our wallets. Long time ago when I started out I bought a few cheap binders without really knowing what I was gonna use them for, they're all scrapped now. No use. If you're sewing as a hobby, by all means, go ahead and buy a few cheap ones to figure out your needs, but if you're serious and wanna do it as a business, I can't see any other way than forking out for professional Tools. We have made a few ourselves, but to be honest, it's cheaper to have them custom made than to make them ourselves, at least for us. (My browser keeps capitalising random Words, sorry for that)
Wow. Where is this beast located?
Hello. Following a conversation I had with the proprietor, australian publishing house the rams skull press has recently released a small book/booklet on collar making, called "Collar making the traditional way" by Ron Edwards. The information therein had previously been available in some other book, but is now available in a single little volume. I got it yesterday in the mail. The literature on collar making is very scarce, Haslucks book harness making being the only one I know of in English. And as correct as it might have been it does lack a lot both in information and how it is presented. Looking thru Haslucks bibliography it is quite evident that he either was a dilettant or just an editor. I mean seriously, motor cycle building, plumbing, electroplating and harness making, the feller must have been a jack of all trades.. Anyway, the Edwards book is good, albeit very thin. But it does cover tools, materials, patterns for various parts (only for one size horse), techniques, general tips and a few recipes for leather treatment goos (the latter seems to be taken from hasluck). I sort of researched the subject myself by Reading thru hasluck, looking at photos and videos, pestering collar makers with stupid questions, and of course making one. This book answered a lot of the questions I had, and confirmed some of my thoughts on how to do things. So for me it was a very good read. The illustrations are fantastic. Note, this book is about making collars built up with long straw, not the chaff filled, seamed up jobs that is common in the US. Overall I would give the book a solid 5 out of 5. If you're worried about postage from oz, have a look at the stock saddle book and how to make a saddle tree (which is the only written account i have found on how to make a english-ish tree), lower postage per book if you order a few... No affiliation with the rams skull press, just a happy customer.
Wood stain for leather.
ojd replied to Clintock's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
Hi, a bit late maybe but I'd like to share an experience with wood stain on leather. I live rurally and always try to support local businesses. I very seldom buy stuff over the net. Mostly books though (abebooks or amazon). I can't get leather dye/stain locally so I thought I'd give wood stain a try. My local paint shop (very old school, they sell all the good stuff and are very friendly and will get most things others do not carry at all, like borax and shellac flakes) had a wood stain which comes in powder form in small satchels. I had a look at the msds and it turns out to be sodium chloride (table salt) and azo dyes. Which can be used for leather. The instructions said the powder should be dissolved in boiling water, or for stubborn woods, 50% water and 50% ethanol. Had a look at the fieblings dye msds and it's mostly alcohols plus a mixture of azo and methine dyes. Hmm worth a shot. Turns out it works fine. The leather sucks it up fine. That the dye can rub off might be an issue, so it needs sealing with wax/oil but otherwise it works ok. Works well on edges to. Conclusion, try to find as pure dye as possible, without any additives. Azo dyes works. -
The second Picture shows an English cart harness, made for single axle carts. I kind of like the idea of the shaft loop strap on the saddle, I have a lot of hilly terrain. Funny thing about that dee, I didn't know they were made, but they ought to be made again. It can't be that hard to weld together. Thank you very much for the information on traces. Hopefully I can find some photos. Also, I found the book you were talking about, the one I linked to above was the English version. I found the american one at a much better price. Cheers
I will write a longer answer when I'm in front of the computer. But had a look at the book. A bit expensive, eh?
