Everything posted by Pintodeluxe
Singer 111w155 question about needles
Pintodeluxe replied to huckleberrymoonshine's topic in Leather Sewing Machines
Nope. 135x16 are leather point needles. 137X17 needles are for cloth or vinyl. Otherwise, they're a direct swap. Best of luck. -
Nuclear steampunk. Love it!
- 11 replies
- agedleather
- handmade
(and 4 more)
I have a Sailrite Leatherwork, as well as a Juki LU-563 and Consew 226. The Leatherwork has a servo and even has a little speed reducer! The tiny table is so cute, and can fit virtually anywhere. Does it sew leather? Sure. The main limitations I've found is the foot lift is only 3/8", and it can sew about 5/16" of compressed leather. The foot steppage isn't very high compared to the full industrials. But it does have fairly smooth knurled feet so it won't mark leather. I use it on upholstery leather, where it does just fine. It wouldn't take many layers of veg tanned leather to be too thick to sew. It definitely beats a home sewing machine, and might fit the bill for someone making belts, wallets or luggage tags in a limited space. Cheers
Pfaff 145-h3-6/C LMNP, Good for leatherwork?
Pintodeluxe replied to Rickyjd5's topic in Leather Sewing Machines
It is a good machine, as long as the small G style bobbin and standard height foot lift aren't limitations for what you do. I consider 138 at the upper limit of machines in this class, and they often sew better with 92 weight thread, even when properly tuned. An H4 version of this machine would get you high lift, with a 190 system needle. That would enable you to sew thicker leather. A 545 version of this machine would get you a large M style bobbin. The price is right on this one though, so if the condition is okay, it might be the one. One thing I notice about the Pfaff walking foot machines in general, is the springs and controls are very stiff. Some people don't like that. I almost made a 545 H4 my primary machine, but went with a Juki LU-563 converted to a 190 needle system instead. No regrets, but the Pfaff would have been fine too. -
If the 226 is like the Juki 562/563 then it depends on the year it was made. Some versions I've had, I noticed an oiling port by the handwheel for manual lubrication. Other versions of the same model # have sealed ball bearings. I've bee happier with the manual lube versions, as they seem quieter.
Pfaff 1245 timing belt replacement?
Pintodeluxe replied to andy184's topic in Leather Sewing Machines
1+ well said. Much agreed! -
I've had digital servos that were super slow-sewing, and other digital servos that were jumpy. I agree with Wiz that the analog are more predictable, and easier to sew slowly with. The analog servos do truly seem to be all the same. Rex, Family, Hi-Tech and other brands all seem to re-badge the same motor as their own. Try one. Worst case scenario... it's still not slow enough for you and you can add a speed reducer at a later date. I added a box style speed reducer with an analog servo and it is perfect for me. I could have gotten away with the servo only, but the reducer adds power and further reduces speed.
Juki LU-563 or Seiko STH 8bld-3
Pintodeluxe replied to MCFromCanada's topic in Leather Sewing Machines
Yes, I bought both machines. I only kept the Juki LU-563 though. My reasons were this... 1. I prefer top loading bobbin. 2. The 563 features a huge U style bobbin. It's quite a bit bigger than an M style bobbin. These are just my personal preferences, and the Seiko is a good machine too. The Early 206rb, 206rb-1, 206rb-2 are good machines too. -
Consew 226R-2 manuals and questions??
Pintodeluxe replied to LanceR's topic in Leather Sewing Machines
You'll be able to sew 3/8" thick material, whether that be fabric or leather. It's a good machine. Get a Family style servo with single knob adjustment. They're sold under many names, but the servos with a single knob are easy to set up. The electronic servos with two or more buttons to set are a real pain. The only advantage they have is they can run a needle position sensor, but I don't use one. If the basic Family style servo with small 45mm pulley is slow enough for you, you'll be all set. If you need slower, add a box style speed reducer. That's the setup I have on my Juki LU-563. My first machine was a 226 with servo and small motor pulley, and that worked great too. -
What is the right bobbin thread tension?
Pintodeluxe replied to Gymnast's topic in Leather Sewing Machines
I like low tension sewing, so I set my bobbin tension fairly light. Like pulling dental floss from its container, or maybe a little more tension than that. That way you won't have to use tons of upper tension to balance the stitch.- 28 replies
- thread tension
- lower thread tension
(and 1 more)
Matching forward and reverse on Juki lu-563
Pintodeluxe replied to MarB's topic in Leather Sewing Machines
I would adjust the topside mechanism first. Try adjusting the stops on the right side of the machine to set reverse lever travel. Knocking the pin out would be a last resort. Definitely don't use brute force with a hammer. That's just a game to see which part breaks first, and nobody wins that game. -
Pulling my hair out over tension issues with Consew 206rb
Pintodeluxe replied to Lokahi's topic in Leather Sewing Machines
When getting an upholstery class machine set up and running, use 92 weight thread and a #20 needle. Chisel point / leather needles will result in a cleaner exit hole, but round point are fine for initial testing. Realize that 138 thread is the limit for this machine. To sew 138 with leather, you'll need a #23 needle. Please post pictures of your thread path from the thread stand all the way to the needle. Please switch to 92 weight thread and a #20 needle for testing. Adjust tension for that setup and report back. -
Still having same problem please help
Pintodeluxe replied to bigsig11010's topic in Leather Sewing Machines
Did the sewing mechanic get it sewing right? Does it sew well with 92 weight thread too and bottom? Is that white thread the same stuff you were having trouble with? Sometimes when troubleshooting a machine problem, the best thing I have done is ditch problem thread. Sun Guard thread never worked for me at all, for instance. I tossed it in the trash and my problem went away. -
Pfaff 545 H4 needle selection and timing
Pintodeluxe replied to destes's topic in Leather Sewing Machines
I like 190 system needles better anyway. Since your H4 was designed to use these longer needles, you definitely made the right decision. Someone probably ran out of long needles, and adjusted the needle bar to use the needles they had in stock. I switched my Juki 563 to accept 190 needles, and I like the setup a lot better. It sews through thicker material without any interference between the feet and needle bar. -
I like a size 19 or 20 with 92 weight thread. Increase upper tension or investigate if your tension assembly is worn out. I've had tension discs on older machines that literally had grooves worn in them. To the point that no adjusting would produce adequate upper tension. If that's the case, replace the upper tension assembly. Remove the bobbin case. There should be two tiny screws and a semicircular retainer. Check for work or bent tension tab. Replace bobbin case as needed. If everything looks good on the bobbin case, try decreasing bobbin tension. -
Seiko stw 8 / consew 225 what to adjust?
Try putting something in the machine that you'd actually sew and play around a little more. Maybe two layers of that leather. Increase upper tension for sure, but you may have to adjust the bobbin tension as well. Also a #23 needle may help you sew 138 thread in leather. Best of luck with it. -
I had a Consew 227 that looked similar. It had incredibly high lift and would sew through anything. I used it to repair bags on my tractor bagger with no trouble (heavy nylon material plus thick plastic). Ultimately, the lack of reverse was the big limiting factor. I'd get another one if it had reverse.
When a woodworker does leather work. Just a tip.
Pintodeluxe replied to mike02130's topic in Leather Tools
I use woodworking tools quite often for upholstery work. Yesterday I skived piping strips with an oscillating belt sander, and cut foam with a band saw. Your tip is a good one, and another great example of WW tools used for leather. Your project looks very nice by the way. -
Servo motor install on brother machine
Pintodeluxe replied to rivercityleather's topic in Leather Sewing Machines
I've had all variants mentioned and here is my experience with it. A 550 watt Family / Tech sew style servo does pretty well if you swap the motor pulley. They often come with a 75mm pulley, and you can easily swap them for a 45mm pulley from eBay. Not quite stitch by stitch, but close. To that setup I've added a box style speed reducer which allows you to crawl stitch by stitch. Or you can sew at normal speeds. The benefit of the speed reducer is it allows you to crank up the power on the servo motor. Plus it acts as a torque multiplier. The downside of a speed reducer is the extra mechanical drag if you do handwheel occasionally. Even with the pedal slightly depressed (to release the cork brake) you'll feel more passive resistance to rotating the hand wheel. As far as the needle positioner, you need a servo with a digital display panel to run a positioner. I dislike those motors and they're a pain to set, compared to a simple dial. I like a needle positioner for high speed non-walking foot machines. But I find no use for them with leather. Like others here, I recommend starting with a Family / Tech Sew style servo with a single mechanical dial to adjust speed. Add a speed reducer later if needed. You'll likely be happy without one. Especially if you pop for a small pulley. Last time I looked they were about $2. Best of luck with it. -
Wow, that's surprising. My 226 didn't even like 138 thread too well.
Yes, they both have slotted wing nuts to adjust stepping height. The Juki is a top loader, and the Seiko is a side loader. I'm clumsy with my left hand under the table, so I prefer a top loader for my main machine. You can get used to using either. -
Uwe, That's a thing of beauty. I had no idea a 225 could sew 207 thread. What modifications did you make? Thanks
Yes the discs under the white knob. If they are old and have grooves worn in them, the upper tension will be erratic. This can cause intermittent loops on the under side of the fabric.
I've had both models, and can say they're both good machines. I prefer the huge U style top loading bobbin on the Juki 563. The stated capacity is about 3/8" of leather stock. Of course my Juki is far from stock. I switched it to longer 190 system needles and added a box style speed reducer and servo. I think it would see through plywood now. I wouldn't use either machine with any thread heavier than 138. Even that may take modifications to sew consistently well. I almost always use 92 thread and those upholstery class machines are happy all day. -
Timing slightly off and worn tension discs are likely culprits.
