Michiel
Everything posted by Michiel
Pros And Cons: Cylinder Vs Post Vs Flat Bed
Michiel replied to MartyS's topic in Leather Sewing Machines
I have an adler 68 and 168 which are older versions of the machine you posted. (Postbed but not as high as the one on your photo) i think it will be great for bags -
Picture is from an old topic on lwn not my machine, not my picture (and now i notice it is not threaded right,so do not thread your machine this way! But check if the spring is working well)
The small spring in the middle of this picture was not working properly and that caused the under thread being pulled at the wrong moment and that was why the under thread went out of his designated place…(on my machine) It happened mostly when sewing backwards (and not always)
I have had similar issues with a adler 69 (which is very like your machine) in my case my check-spring which was not working properly , after i fixed that it was solved
Adler 67-gk373 upper tension assembly replacement
Michiel replied to Numby's topic in Leather Sewing Machines
No, sorry later i found an adler assembly and changed it. the paff assembly did fitt but i had to modify it a little bit -
Adler 69 should be the same and i once made an tension assembly of an pfaff 145 fit onan adler 67 Adler 67 68 69 167 168 and 169 all have the same tension assembly -
Hook to Needle Distance: A Compromise
Michiel replied to friquant's topic in Leather Sewing Machines
I would try too see what’s happening when actualy sewing with tread and material (leather, canvas or what you are using) It can be hard to see, but if you can, and turn the machine by hand, you can see what is the problem if the machine forms a good loop in the thread the hook needle distance is not that important but if your thread is bad or the timing wrong you might get this. with some machines you can see it by sewing on the edge of your project and open the slide right of the needle sometimes you have to look from the underside. use a flashlight! -
help from the masters..... Is the machine fixable?
Michiel replied to MattiJoy2's topic in Leather Sewing Machines
I have seen adlers with a crack that stil worked. (For a long time) i would like to see a picture, but in generall i think: “if its not broken, don’t fix it” (if you have someone who thinks he can weld it, you might consider to buy it and start using it) -
Just a guess: Have you tried pushing the button you use to set the stitch length?
Did you see this recent thread? Is contains find the service manual This looks fine to me
According to the manual they are both for foot pressure. i think the small one is ment for fine tuning
- 3 replies
- sewing machine
- adler
(and 3 more)
Searching for an odd machine oil. Assistance.
Michiel replied to HondoMan's topic in Leather Sewing Machines
If it is sold as sewing machine oil your machine will be fine -
I hope I am clear enough my (technical) English is not good
Here you find the partbooks https://www.college-sewing.co.uk/parts-books/durkopp-adler-sewing-machine-parts-books.html but i think you have a change your barrel hook race is threaded on the backside and you can make your adjustment by making turns anti clockwise
I might be wrong but i think i have had a 166 where one can turn the race for the barrelhook to move it front and backwards you could try that….
I think i had some help from the service manual for the adler 366 when I worked on my adler 166
Hook setup is the same as adler 205-102 adler 266 and adler 366 (Part 266 15 on this one) I think the hookdriver act as an needle guard
If I remember correctly, the distance is set with shims
Turns out its an german language only version (I am sorry) But You might be able to translate it online if you sent a pm with your email adres i can sent it by email (i think i do have a service manual for the adler 167 in english, you might be able to use that as well)
- 8 replies
- timing
- adler169-373
(and 1 more)
I do have a service manual (it did help me with my 169) maybe a moderator can help me to post it because its bigger than 1.46 mb
- 8 replies
- timing
- adler169-373
(and 1 more)
Do you have a service manual? In my experience, it's best to do all the settings in the order described if you really want the machine adjusted properly Michiel
- 8 replies
- timing
- adler169-373
(and 1 more)
