Everything posted by ABHandmade
Long Wallet
ABHandmade replied to kyrrk's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
Thank you for information. I think about to use a magnetic clasp, but the fear of harming the client by destroying his cards always stops me.- 23 replies
- longwallet
- handmade
(and 2 more)
Long Wallet
Very nice wallet! I wanted to ask whether the use of a magnetic fastener does harm the cards with magnetic stripe?- 23 replies
- longwallet
- handmade
(and 2 more)
It seems to me that photography and painting may well exist together. That is, creating your own art work in one case does not exclude the use of ready-made templates from the Internet in another. And vice versa. PS. By the way, photography is also considered an art
It looks very stylish and it feels like a little piece of the soul is put into each work!
Thank you for such a high evaluation of my work., Brian! Andrey.
Unfortunately, I could not find in Ukraine a Varathane Diamond Wood Finish. For the test, I bought an acrylic spray in the nearest DIY shop in the middle price category. Here such: Manufacturer MOTIP DUPLI GROUP (Europe). Price in Ukraine for 400 ml - $4. I suspect that any universal acrylic lacquer would give a similar effect. YinTx I too fear that using only a spray lacquer may not give the proper water resistance effect. Therefore I applied first, as usual, finish Appretto Mild (Kenda Farben), which gave waterproofing properties and a glossy surface. And then, exclusively for decorative purposes, applied a little matte spray.
Nice girls!
report on the work done I tried the acrylic spray. The result completely suits me. Before: After: The difference in color is the unhealthy desire of my camera to make a color correction Many thanks to all!
Thank you! My work has many flaws - if see at a professional look. But I hope that thanks to the information in this forum, the advice of the masters and the strong desire for to do more, I can achieve better results. I use a hand stitching and in this work I first time tried zig-zag .. I was very worried that it would not nicely. Before that, I used only a flat recessed seam .
I did not notice. Thank you for drawing my attention to this! I'll probably make an order and compare the results of everything that I was advised in this thread
Thank you, Charon. Unfortunately, I could not find the finish you mentioned in Ukraine. And if i order it, the price, including delivery, will probably be prohibitive. But in any case, your information is useful. While I'll try to use acrylic lacquer in the spray. I hope the result does not disappoint me
Eric, thank you very much for your advice!
Mike, many thanks for the help. I understand, it is necessary to take a polyurethane lacquer.
Medusa themed holster WIP
ABHandmade replied to immiketoo's topic in Gun Holsters, Rifle Slings and Knife Sheathes
It is exactly that I do not see any obvious traces of the leather cut and caused my admiration for your professionalism. -
Clearly expressed - no. But on the runes there is clearly a very smooth difference in heights, which is usually achievable only in the case when the leather is not cut. I wanted to check if my guess is correct. -
This is all my bad English I was really interested in whether the beveling was used without a cut. Because I did not see the traces of a cut on the runes. Mike confirmed that this is the case. Thank you! -
Very beautiful cuts and beveling I admire and understand how much I still have to study and train. -
Mike, did I understand correctly that you use in this work a beveler without carving? And I join Gary in the question of leather. Looks very good! Andrey. -
Thank you! The reason for my request - I just had not yet been able to see the effect of UV on the leather. I will definitely do the proposed experiment - with the finish and without. I'm very interested in how much the finish affects the process.
If this does not make it difficult for you, can I ask you to post a photo with a changed by UV leather?
I for such purposes use a fine art brush to apply finish on the plots that should not be painted. After complete drying of the finish with the same fine art brush, I pass dye along the contact line. The amount of dye on the brush should be kept to a minimum so that it does not move into the thickness of the area covered by the finish.
Is there a finish (such as Resolene) that gives a matte surface? Or, in other words, how to get a waterproof matte surface? I would be grateful for any information on this matter.
