DanishMan
Everything posted by DanishMan
I think you are right. So the foot lift on the older 335's must have been heavier, than the later ones.
Hi Shoepatcher I might consider som parts from China, but I prefer older original parts, if I can find them. But right now China is closed due to corona. Brgds Danishman
Dear Friends I have a question about the old PFAFF 335 presser foot lift. On most 335 there is some kind of mechanism to minimise the power needed on the foot pedal. On the older machines, there is no such mechanism. In stead a chain is going from the tip of the lifting arm through a hole in a corner of the machine base. My question is if, any of these machines have had knee lift - or if the only presser foot lifting is via the foot pedal, which requires more power, than those with the power exchange. Take care DanishMan
Hi Iron You are welcome. I am not progressing that quick - at least not until now, where I am laid off due to corona. I would like the paint to harden for a few weeks, before I continue the work. I am also about to finish a PFAFF 545, and I am about to receive an old PFAFF 145 from Germany (black one). So all in all, I have enough to do. Cheers DanishMan
Fortunately I had an old PFAFF 27, which I was parting out. I could use the bracket from that one. However the screws were stupendously tight - heating etc had no effect, so I had to drill out the screws at the end.
As mentioned in the beginning, the machine was incomplete. As most of you know, PFAFF parts are extremely expensive to get. The plan is to find the missing parts down the road. While taking the machine apart, I found the "tilting bracket" to be broken in the corner.
After dissambly, I used my bench grinder to remove the paint. While the grey hammorite was easy to remove, the primer was very sticky. I used about 4 hours to get the job finished. Then I primed the parts with hammorite primer, using a brush. I had thinned the paint slightly and the result turned out to be quite good. For the colour, I had initially decided on hammorite silver grey, which is a bit off from the original colour. Again using a brush, the result turned out to be less good. I had thinned the paint, but the cover became too thick............. Change of plans. I decided to paint the machine black instead. As the 335 B17 comes in both black and grey, I figured this to be the best solution. Using a hammorite spray, the result became very good. The trick is to spray every 10-15 minutes - wet on wet.
Thank you for you inputs Cheers
Dear friends I am going to paint a PFAFF 335, that I bought recently. Pretty shitty conditions. Can anyone hear maybe reveal, what the PFAFF colour is called, when using hammerite paint? Brgds DanishMan
I recently bought a PFAFF 335 in Bulgaria. It was also damaged in transport. The stitch regulator being torn off. It is fairly simple to remove that one. I will see, if I can make a video. Cheers DanishMan
pfaff 345 2 new old pfaff 345 in the house...
DanishMan replied to BoRo's topic in Leather Sewing Machines
I actually think I have a binding bracket somewhere -
Next thing will be to grind down the machine on the outside for painting.
Today I took the machine apart. Four extremely tight screws underneath - one of which had to be drilled out in order to remove it. And then two pins holding the machine together, but two small wedges did the job. Then a thorough cleaning before using plenty of WD40
Hi Mike That is actually my thought as well. I will also drill two more holes in the side in order to fit "foot lift" Cheers DanishMan
All in all the machine is in much worse condition, than expected. The ruined needle bar rocker assembly alone is a set back. The plan is to grind the machine down and paint it. And then over time, to find the missing parts.
Removal of the shaft was a bit easier, than I expected. I have taken a few machines apart before, and I have found the bewel gear to be very difficult to remove. Fortunately I have a main shaft from a PFAFF 142, which I can use.
To be able to remove the main shaft, every thing in the front had to be removed. I learned, that the needle frame assembly was more or less broken in two peaces. Weird how this happened. Possibly a shipping damage, as the machine was not properly packed - still weird. In the shipping process the presser bar regulating assembly had also broken off - and the stitch length lever. In order to remove the main shaft, I had to cut off the two outer centimeters of the shaft. And then as the main shaft was rusty inside the machine, I had to grind as much rust off to enable the shaft to be removed.
When I saw pictures of the machine before buying it, I suspected main shaft to be bend at the handle wheel. I was right, and the main shaft has to be removed and replaced. For that reason, everything in the front of the machine has to be removed. Small things reveal, that the machine has been repaired with whatever they had. One example is the side cover. The original screw has broke or gone missing at some point. Problem solved by inserting a nut from the inside and attaching a bolt on the outside. The threading most likely ruined
Today I started to look at the PFAFF 335, that I had shipped from Bulgaria two weeks ago. I knew, that the machine was in a sorry state from the look of it. Scratches all over and un-complete. However, as the machine was only 80 USD (including shipping), I could always part it out - the needle bar rocker assembly alone would be worth 80 USD.
In need of Pfaff 545 Safety Clutch Parts
DanishMan replied to 40tude's topic in Leather Sewing Machines
https://picclick.de/Pfaff-141-145-bis-545-Industrie-Nähmaschine-233355622443.html -
I have bought items from Kramboxx in Germany. He has always been quick to respond and very friendly. Good prices. https://picclick.de/seller/kramboxx -
I got it shipped. The machine was in bad shape, so I took the chance. It was not packed very well, and it sustained a few damagages more. Still a good price, and in case I can not fix it for some reason, I got several parts - like the needle rocker assembly. The most critical part is the main shaft, which I suspect to be slightly bend. I noticed it before shipping, and I asked the guy to take off the hand wheel. Had the hand wheel been on, it would probably have broken off during shipping. However, I took a PFAFF 142 apart a few months ago, and I can likely use the main shaft from that. The machine is scratched, and I probably have to paint it. I know a guy, who has original PFAFF paint, so that will also work out.. Brgds Danishman
