ScottWolf
Everything posted by ScottWolf
Lexol Replacement
ScottWolf replied to Sham's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
If you look at the MSDS, section 3 gives you a clue as to what the ingredients are. Lexol is 80% water 5-10% NFO and the remaining ingredients are emulsifiers and preservatives/fragrance. Since oil and water dont mix, you need an emulsifier to hold the two together. In this case it is an oil suspended in water. You can buy an emulsifier to do this for you off of Amazon, etc. A quick Duck search will tell you which ones you can use. They come in wax flakes, which will give you a whitish creamy paste or you can get it in a liquid form for an all liquid product. Polysorbate 20 (wax or liquid) is a good emulsifier to start your DIY project with to make whichever form you want it in. If you don't want to go down the DIY path, you can buy a similar liquid ( or cream) version of lexol from a company called Griffin leather conditioner. It's primarily a NFO product and will accomplish the same end. The MSDS for their products can be seen here: https://gbcontents.com/ -
Here is a post I made that addresses your needs and explains on how to make it yourself.
It's not about the eating of it as much as it is about how it reacts with other ingredients. There is a reason why there is a preponderance of leather care and conditioner products that use beeswax and its by products in its formulation among the other ingredients that are mentioned in previous posts in this thread.
I am assuming that this is a paste or similar to a grease/creamy paste and not a solid given that it only has tallow and NFO in it? If so, how are you keeping the two substances from separating? Beeswax is a good ingredient to use with NFO , as it retards the NFO from oxidizing ( some people erroneously use the word rancid to describe oxidization). It has been my experience that leather will squeak when it is unable to slide smoothly. If your product is too tacky, it is because the ratios are off and you could have too much beeswax in it. When the ratios are done correctly, the beeswax doesnt create a sticky/tacky feel when it is applied and it won't cause squeaking. I would suggest trying some beeswax as it will give you a semi solid product that is less messy than a grease/creme and it'll keep your ingredients mixed and slow oxidization.
Glad you found the information useful to you. By all means, make as many variations as you want and see how they perform on your leather. I don't think the tallow version will soften the seat too much. It would take an excessive amount to do that IMO. As for cleaning, a pH balanced soap is preferred, as leather is acidic and most soaps are alkaline. Something like Dawn , which is low on the pH scale, can be used safely. I am not a fan of glycerine soap, but I know some people use it religiously on veg tan/horse tack.
Glad to hear this post helped you out. Olive and coconut oil will darken leather significantly. Its great for old dark colored pieces, as it brings it back nicely. But if you put it on a beige/camel or veg tan piece of leather, it darkens it a lot. If you use the ingredients I listed in the recipe post, you'll find that it doesnt darken the piece too much. Any conditioner will initially darken a piece but after its absorbed in the color usually lightens up. Tallow is great for dry pieces or to just to keep a soft supple piece going. The batch I made using tallow has become my go to tin for general conditioning. The batch I made with mineral oil in it is more of a finishing product, as the mineral oil adds a bit of sheen and makes the leather pop. I only see water being used in liquid and or lotion types of conditioner, such as Lexol as an example. 80% is water, 5-10% is neatsfoot oil and the rest is emulsifiers,preservatives and or stabilizers. If you want a semi solid balm, there is no need to add water, as then you'd need to add an emulsifier to keep the water and your oils from separating.
Take a look at Colorado leather balm or Smith's leather balm, as each is an all natural product and are both made in the USA. If you want even more control of what you use, check out the DIY recipe I posted on how to make your own leather conditioner using all natural products.
If you do a small test batch in a 2 or 4 oz tin and mix in the ingredients,you will get a visual reference as to how much of either Vitamin E or citronella is intermixed with the other ingredients. You dont need a lot of either for it to be effective when the ratio you are working against is 1 part beeswax. By starting at .5 for each just as a test, which is half of the ratio you are working against, you will get a good idea as to whether it is enough or too much. If it is too much you will end up with a final product that is more like a cream and or so soft that it will never be firm/hard . I think you are over thinking this, as it's not exact, as your ingredients might differ from mine in how they interact with one another and or from batch to batch. This can become more apparent if you decide to add essential oils in it for smell, as 5 drops might be enough in one batch to get the desired smell and when you open a new/different bottle of essential oil, 5 drops may not be enough. To put this in perspective, look at a commercially available products MSDS and you will see a percentage of the ingredients. Very often you will see ingredients like you listed and more, and they will typically say +/- 5 percent, sometime +/- 10% but typically for only one of those ingredients. Meaning very little of those ingredients is actually used in the make up of that product. In most cases of liquid conditioners its typical to see 50-80% is water, followed by a small percentage of chemical stabilizers/preservatives and or emulsifiers and then lower percentages of the actual conditioning ingredient(s).
From my initial post, here are the general ratios to start with: There is no way to tell you specifically how many drops of an ingredient or how much vitamin E, etc to put in there. You can put in as much or as little as you want to get the desired end product. The thing you do need to keep in mind is that the more "oils" you add to the recipe, the softer the end product is going to be. So it will go from a solid/balm to a cream unless you increase the ingredients that give it it's firmness, like beeswax.Carnauba,etc, proportionality as you add more ingredients that are oils. So if you increase the number of parts of oils by say 50%, you need to increase the amount of beeswax by at least 50% or more depending on what you want the end product to be (solid/soft/balm) just for starters and see what it produces in a small batch. if it comes out the way you want it, make it in a larger batch, using the newly adjusted ratios.
Just an update to this thread. I've continued to try different combinations of ingredients using the a fore mentioned ratios. Ingredients such as avocado oil, sunflower oil, Palm oil, etc. I've found that some of the combinations have different affects on the leather, be it the shine, color or suppleness that it produces. So even if you've found a combination of ingredients that works for you, try experimenting with the amounts of a given ingredient to start, and see if it improves the performance of your conditioner. I now have a series of differing conditioners that I use in steps for a given piece of leather and not just one by itself. This has proven helpful in bringing back very dry or poorly cared for pieces in stages.
Glad to see you got it under control and it worked out.
I know people use and some swear by NFO, but the simple fact is that you can never really get it all out of the leather. Which is why learned people caution others from using it excessively, as the long term effects of it is when it eventually oxidizes in the leather is that stiff,greyish/white color leather turns over time when not cared for. Which is why I don't think you will have very much luck with continuing to wash/bathe the pieces. Have you tried applying a beeswax based product as I suggested earlier to it yet?
Before you start removing rivets, try applying a beeswax based leather conditioner to the grain side and rub it in over several applications. You'll likely still gets some rub off as you do this but the introduction of the beeswax in the conditioner should help reduce the rub off and seal the grain side from the NFO migration. Once you do that, let it sit for a day or so to soak in. After which, you can go back and touch up color if need be and then do your resolene sealer.
The flesh side (back side) will typically will always penetrate/soak up what ever is placed on it , sometimes crazy quick too depending on the piece of leather,than the grain side. I learned this the hard way when I accidentally touched a dye dauber to the backside of a piece that was already dyed a different color and the accidental color was already on the surface as soon as it happened. If the NFO has soaked through evenly and there isnt any discoloration of your dye job, you can opt to let it dry and see if the color remains consistent and hasn't lightened or become splotchy. The other option is to rub/buff the piece down with a rag, to remove the NFO that's has migrated to the surface, which will likely remove some of your dye job in the process. In which case you can allow the piece to dry for a day and then re-dye/touch up the piece to restore the depth of color you want.
Howdo you tell if it chrome tanned or oil tanned
ScottWolf replied to Bert03241's topic in All About Leather
"Oil tanned" is term used for leather that has been tanned and then impregnated with oils as part of the tanning and dyeing process. It isn't actually part of the tanning though, it is done post tanning and it does affect the leather in that it is softer, has somewhat of a pull up and is easier to break in, which is why you see boots and other footwear being marketed as using "oil tanned" leather, as the addition of more oils makes it a durable and somewhat water resistant leather. Redwings boots are marketed this way. In the end, it is chrome tanned leather with the additional Oil process that makes it oil tanned leather. If you burn a piece of chrome tanned leather, it will smolder and continue to burn after the heat is removed and will also produce a greenish blue smudge mark if you run it across a piece of paper. Veg tan wont really burn at all and will stop when the heat is removed and will leave a black smudge when rubbed against a piece of paper. -
Ask and you shall or receive, or Search and you shall find.
Cell phone case clip
ScottWolf replied to DirtyDusty's topic in Purses, Wallets, Belts and Miscellaneous Pocket Items
These are probably the best clips out there at the moment for retention and durability. They come in multiple sizes and lengths and you can mount them to anything fairly easily. https://discreetcarryconcepts.com/HLR-Discreet-Gear-Clips™-c26960683 -
An update to this post on a slightly different list of ingredients and some results. Since posting the original recipe and variations of ingredients one can use, I've been using the following ingredients with very good results, especially for very dry and or damaged leather items. The idea is to replace some of the ingredients that are lost over time, age, and neglect to basically re-fatliquor the leather. I've used it on very old and stiff leather as well as normal healthy leather with good results. This also remains true to an all natural ingredient recipe. Ingredients used are: Beeswax, Lanolin, Tallow (beef), vitamin E. The Tallow I used is derived from 100% pure high end Waygu beef and has a soft buttery consistency and no odor to speak of. The brand I used is from South Chicago packing and is food grade. I use the Vitamin E in the mix, as it is an antioxidant and retards any of the ingredients used from oxidizing ( some refer to this as going rancid). The Lanolin and Beeswax is self explanatory in its usefulness and in adding stability to the product. So I used this recipe to test out the effectiveness of having added the tallow in the mix to see how well it works at fatliquoring already processed/finished leather. Specifically, very stiff and old, dried out leather that had been exposed to the elements as well as sweat.After making it, it resembled my previous picture in this thread where I used lanolin, in its appearance and consistency. Mixture ratios were consistent with the ones I posted in the original post. Here is what I have found to date. After having applied it to the very dry and stiff leather and letting it sit a day or two between multiple applications, the leather had softened up and was no longer stiff and could be bent/flexed without the fear of breaking/cracking the leather. On sections where the surface grain had already cracked and was hard, it was now soft to the touch and pliable. The leather also looked healthier and returned to its natural depth of color. The leather was no longer cardboard stiff or brittle and was soft workable leather. I also applied it to still flexible leather as a typical conditioner would be used on a leather item and found that it works just as well at bringing out a vibrant and healthy looking end result. The addition of the tallow as an ingredient, definitely makes a difference in how this conditioner recipe works compared to the others already mentioned in this thread. It may not be a conditioner that you'd use all of the time, but it is ideal to have a tin for those pieces of leather that require more than the usual conditioner ingredients.
LARD
ScottWolf replied to Alexis1234's topic in Dyes, Antiques, Stains, Glues, Waxes, Finishes and Conditioners.
So the short answer is yes, lard and even Tallow are good for leather. In fact, tallow and even lard is often used in the tanning and finishing process, it's called "fatliquoring". Lard however is typically derived from pigs. Tallow is rendered from cattle. When rendered properly, both are shelf stable , require no refrigeration and won't go rancid(oxidize is what people are really referring to when they use the word rancid with leather). Outside of a tannery, most uses of tallow is found in conditioning products with other ingredients, like beeswax, Lanolin, and usually vitamin E(this is what retards any risk of any ingredient oxidizing in a product). Using it alone, without other mixed ingredients and applying it directly to finished leather may not be the best way to use it effectively. Here is an example of a leather conditioning product that utilizes Tallow in its ingredients. https://coloradoleatherbalm.com -
Is this water damaged satchel beyond repair?
ScottWolf replied to Noydini's topic in Leatherwork Conversation
Noydini, I'll offer up some advice in addition to what others have already mentioned. CLEANING: Saddle soap has been mentioned but that is a generic term and what one saddle soap has in it can and does differ from brand to brand. In your case, an older, damaged and stiff piece of leather needs to be brought back slowly over time. A simple damp cloth wipe down should proceed anything. Get the surface dust and grime off and then actually clean it. This can be done with something as simple as Dawn dishwashing soap, a soft brush and or a rag. Dawn is pH friendly to leather and won't dry the leather out any more than it already is. You want to avoid drying already damaged leather out even more during the cleaning.Multiple gentle cleanings may be needed. It's really important that during this cleaning and subsequent handling that you don't bend or flex any of the stiff leather pieces/portions of the bag while cleaning and later on, conditioning, until such a time as the leather becomes pliable again. Granted there will be some movement but don't try and overly bend/flex portions of the bag while cleaning it initially. Once you've wiped it down and have moved on to washing it, wetting the leather will cause the leather fibers to swell and regain some flexibility while they are wet. This would be then time to carefully reshape or remove any creases on/in the bag. Once you've cleaned it, allow it to air dry at room temp, don't use heat, natural or otherwise, you don't want to damage the leather any further. The leather will become stiff again after drying out, but it should now be less brittle for a day or two after. This is when you want to start conditions it, so it doesn't become brittle again. CONDITIONING: The key with old and dried out leather is that it lacks the fat and oils that were put into it during tanning that act as lubricants between the leather fibers. You want to slowly over days, maybe even longer, re introduce those fats and oils into the leather and allow it to absorb in and re lubricate the leather fibers. So several applications of one or more leather conditioners will be needed. I know neatsfoot oil has been mentioned already, but I would caution against using it on your bag initially, as there are better alternatives out there that will do what your leather needs, and thats re introduce fats/oils into the leather. There are several commercially available products out there that use natural ingredients, many/most also used during the tanning and finishing process. Products that use ingredients like Cod liver oil, castor oil, lanolin, tallow, beeswax, etc(just a few examples, not all encompassing ) or a combination of them will reintroduce the fats that the leather needs to become lubricated and soft again. Once the leather is soft, pliable and supple again, then I'd consider using something like neatsfoot on it, but not before then. I see you are in the UK, but I'd imagine you can obtain or make something similar to this commercial product, which has ingredients your leather will need to become soft again. See the ingredients list in the FAQ's section in the link below. This is just one example product of many that can be used that have the fats and oils in them that your dried out leather will need to bring it back to life. Hope this helps and check back in with your progress, as it looks like it is a nice bag and worth restoring. https://coloradoleatherbalm.com/pages/frequently-asked-questions -
It shouldn't cause it to rub off, as I often use this as a sealer to items I have dyed, but using Fiebings/Angelus dyes. Just be sure to wipe down/buff the stained pieces with a soft rag/t-shirt to remove excess stain as much as possible, then apply the conditioner. You may get a little rub off/color at first on the rag, but nothing to be concerned about.
Dude, ease off on the caffeine or whatever has you so amped. I was just asking what you use for conditioning, since it appeared you were attentive to what's in the products you use. And face it, it's weird that you'd participate in a thread on conditioner, yet guard what you use like its a secret you are afraid to reveal. CONTEXT. I assumed everyone would be able to gather that from my initial post, as I even explained the circumstances, but "there is always one" as we say in the military. Taking something out of context, like you just did in your statement above, is why people in leather forums keep parroting misinformation about "going rancid". Yes, as I stated,BY THEMSELVES, substances can go rancid, that can be quantified by the substances Iodine Value, which by itself, doesn't disqualify a substance's use in a product. The two most widely used substances used in leather crafting , generally speaking, that is routinely used by itself is Neatsfoot oil and to a lesser degree, EVOO ( Extra Virgin Olive Oil). The saving grace , and what offsets being used by themselves, is that most people use it sparingly/responsibly and also use other conditioning products on the leather, as well as take care of it. I think we both know what purposes MSDS serve. I think its you playing games here now. And by aggregate, I simply meant gather various MSDS of conditiong products , with the same/identical substances in them, to illustrate what ever point you were trying to make in asking if I had an MSDS for the products I make at home. So, with all that out of the way, care to share with us what conditioning products you use besides neatsfoot oil? No strings attached, I promise.
Chuck, thank you for that little peek into your personal life as a plant manager.Not sure what relevance it brings to this conversation or the question I asked you initially though. I didn't miss it or ignore your point, as you didn't answer the question I asked prior to that. I don't know why you are being so elusive about what conditioners you choose to use on ANY of the types of leather you are referring to. It's simple, do you use any commercial leather conditioning products, and if so, which ones by name? I just find it strange that you are intentionally going out of your way to avoid directly answering a simple question. Makes one wonder. Do I have a MSDS? That's some serious deflection friend. You know I don't have an MSDS. But seeing how you were a plant manager and had a book of MSDS, you know I don't need one, as I am not selling anything I make, it's all for my personal use. But if you want to be pedantic, I could make one through aggregation, given that everything I use is natural and also commonly listed in the MSDS's of most commercially available products. Items like Beeswax, Carnauba, Sweet almond oil, Vitamin E, Coco butter, Shea Butter, Lanolin and just about anything else that is natural and not a petroleum product and or a chemical alternative to a natural product. That includes the food grade D-Limonene I use in one of my recipes, as it is listed in the Code of Federal Regulations as GRAS (Generally Recognized As Safe) and states as much on the actual MSDS I have for it. The only real concern is that it is a flammable liquid and something to keep in mind when making the conditioner. So what I think you are trying to get at is, Yes, I do know what is in my DIY leather conditioning products and so should everyone else, whether they buy their conditioner commercially or make it themselves. So, which commercial leather conditioning products do you use Chuck?
