1hp
Contributing Member
Everything posted by 1hp
  1. the "Machinery's Handbook" has enough info on threads to make your head explode.
  2. maybe this helps: TORO3000_3200_4000seriesOperatorsManualVerSeptember2014.pdf
  3. you can remove pins from connectors without cutting the wires. https://www.cycleterminal.com/terminal-extraction-procedure.html
  4. It's too nice to use.
  5. there are at least two sizes of 4 wire plugs. bought the wrong one first. this instruction sheet may help: Servo Motor Technician User Manual(v3.7 L-Type 4-Bar for ShuangZheng).pdf
  6. 7" from the hinge on my 206rb5
  7. ask here: https://www.facebook.com/groups/101589880193668
  8. this works for me: https://heprecision.com/shop/ols/products/narrow-presser-foot-set-stainless-tight-radius
  9. these work pretty well. https://durston.com/product/ring-shank-bender/
  10. my mother once put a needle through her thumb nail. very gnarly. i always wear safety glasses while using a machine. never know where broken needles might go.
  11. this guy makes some excellent parts: https://heprecision.com/shop/ols/products?page=1
  12. better to get your last machine first.
  13. these are oil wicks for Consew 206: https://parts.jacksew.com/oil-wick-consew-18110/?searchid=227348&search_query=18110
  14. on my 206rb5, the reverse lever shaft is on the right side of the head. there is a hole near your bobbin winder in a similar spot.
  15. looks similar to the original motor on my 206rb5. Consew_CS-1001 (1).pdf Motors-Con-Serv1000.pdf
  16. on my Cobra 4, they are 11/64-40. got some on ebay.
  17. tig weld with nickel rod. pre-heat & post heat. cool slowly in insulation. we do this alot at work.
  18. if you highlight text & right click, chrome has translate in menu.
  19. Check out Bruce Johnson's web page
  20. $15 a foot at McMaster-Carr.
  21. 1hp
    made loop stick
    nice. this is 6061 aluminum.
  22. made loop stick as seen in J.H. Leather video: amazing leatherworking skills on display in her videos! it is 1"x1/2". taper is 8" long. 3/16" to 1/2". cut piece on table saw, tapered on mill & rounded edges on router table with 1/32" radius round ov
  23. @brucejohnson sells bleed knot tool.
  24. nice to have extra feed dogs to experiment on.
