Members Bawarrior Posted May 4, 2022 Members Report Posted May 4, 2022 I'm doing a case for phone, and need some input on dyes or stains for this project Quote
Members Hags Posted May 4, 2022 Members Report Posted May 4, 2022 Not sure what the issue is. Some clarity would help. Other than that, fiebings pro dye, light or dark brown.?? Quote
Members DJole Posted May 4, 2022 Members Report Posted May 4, 2022 Maybe Angelus has a color you like? https://cdn.shopify.com/s/files/1/0265/7379/files/Color_Chart_Leather_Dyes_FINAL_8-25_045620ee-4788-481b-acc7-d48d85e74022.pdf?v=1640643954 Quote
Members Bawarrior Posted May 4, 2022 Author Members Report Posted May 4, 2022 On 5/4/2022 at 3:35 AM, Hags said: Not sure what the issue is. Some clarity would help. Other than that, fiebings pro dye, light or dark brown.?? Expand I really have not been able to pick a color, so I thought I'd ask for thoughts. Quote
Contributing Member fredk Posted May 4, 2022 Contributing Member Report Posted May 4, 2022 Medium tan brown on all then use acrylic paints to paint in the portrait then several coats of 'Mop & Glow' floor varnish to seal it all Quote
Members Bert03241 Posted May 5, 2022 Members Report Posted May 5, 2022 I found Mop & Glow tends to crack when worked. Quote
Members Hags Posted May 5, 2022 Members Report Posted May 5, 2022 I like the paint options. I use them here and there. I also use resolene 50/50 mix with water for my holsters. I would oil liberally at the fold and let dry before sewing and finishing to help with flexibility. Quote
Members PastorBob Posted May 5, 2022 Members Report Posted May 5, 2022 I would just antique it to show off those carved lines you so carefully created. Quote
Members Bawarrior Posted May 5, 2022 Author Members Report Posted May 5, 2022 Thanks so much, you guys have some good ideas. Quote
Members Bert03241 Posted May 5, 2022 Members Report Posted May 5, 2022 should this be moved to How do I do That? Quote
Members Bawarrior Posted May 5, 2022 Author Members Report Posted May 5, 2022 Nope, I'm good now, but thanks. Already have started will post again when finished. Thanks again Quote
Contributing Member fredk Posted May 6, 2022 Contributing Member Report Posted May 6, 2022 On 5/5/2022 at 2:36 AM, Bert03241 said: I found Mop & Glow tends to crack when worked. Expand I'm beginning to realise or find out that 'Mop & Glo' is different in our different countries Here it is as thin as water and leather needs about 3 coats to bring up a shine, 1 coat will seal dye ok though. Whereas it seems that in the US 'M&G' is much thicker and needs thinning down Quote
Members Bert03241 Posted May 7, 2022 Members Report Posted May 7, 2022 Your correct if I thin it 50/50 its much better Quote
CFM chuck123wapati Posted May 14, 2022 CFM Report Posted May 14, 2022 On 5/14/2022 at 1:44 PM, Bawarrior said: Expand I love it!! looks great friend. Quote
Members Bert03241 Posted May 14, 2022 Members Report Posted May 14, 2022 Holy crap that came out awesomeReally nice job Quote
Members AlamoJoe2002 Posted May 14, 2022 Members Report Posted May 14, 2022 BaWarrior, looks great. What type of closure devise did you use to secure the flap? Joe Quote
Members rleather Posted May 14, 2022 Members Report Posted May 14, 2022 It really turned out quite well. I can only imagine how awesome it is going to look when it starts to patina. Quote
Members johnnydb Posted May 14, 2022 Members Report Posted May 14, 2022 It's awesome work. No doubt about that. If I were you, I'd repeat it several times.... Then try creating an oil finish. Where you take neatsfoot oil and a small amount of regular Fiebings dye (not pro dye) and mix them. Something like 97% oil to 3% dye. Subsequent coats makes it darker...wait for each coat to dry before adding another. Or maybe like others have suggested with the acrylic paints. Or maybe slightly adjusting and decorating the flap to become a hat for the gentleman you so wonderfully created. I think you are on to something...the next ones will be much much faster to make and have better finishes...even though you have done a superb job on this one. I can see this selling well. Give it a shot...you got the talent. Quote
Members Bawarrior Posted May 14, 2022 Author Members Report Posted May 14, 2022 (edited) Thanks to all of you, much appreciated. I use magnets. Johanna, Leatherworker.net is so awesome with so many great people. So helpful, so much beautiful work to see. This is so inspiring and fun to see others work and be able to post. Edited May 14, 2022 by Bawarrior Add more Quote
Members battlemunky Posted May 14, 2022 Members Report Posted May 14, 2022 That turned out quite well! Quote
Members Bawarrior Posted May 15, 2022 Author Members Report Posted May 15, 2022 Thanks again guy, much appreciated. Hey Chuck, good to here from you. Quote
Members Bawarrior Posted May 16, 2022 Author Members Report Posted May 16, 2022 I used Atom wax leather balm for my final finish Quote
Members Bawarrior Posted June 19, 2022 Author Members Report Posted June 19, 2022 On 5/16/2022 at 11:29 PM, Bawarrior said: I used Atom wax leather balm for my final finish Expand I did go an carve the face again after it was all finished. I think it really helped. Quote
