Members Hildebrand Posted October 3, 2022 Members Report Posted October 3, 2022 I was just wondering what weight of poly maul everyone is using to stamp with? I have the Tandy rawhide mallet but I think especially for basketstamping I would like something heavier. I usually have to hit the stamp more than once even with the leather cased well. Thank you, Todd Quote
CFM tsunkasapa Posted October 3, 2022 CFM Report Posted October 3, 2022 I've never been a fan of the mauls. I have poly mallets in two weights, as well as three sizes of rawhide. If I need something with more UMPH I have a 1lb dead blow hammer from Harbor Freight. Quote
Members Hildebrand Posted October 3, 2022 Author Members Report Posted October 3, 2022 @tsunkasapa what weight are the poly mallets you are using. Quote
Moderator bruce johnson Posted October 3, 2022 Moderator Report Posted October 3, 2022 Currently I've got a series of articles going in ShopTalk magazine about upgrading from the entry leather tools and make-do tools most of us started with. Since the striking tool section is already published I am comfortable with sharing my experience and insight. I think everybody needs a 1# maul as the first upgrade for striking tools. Most stamping can be done with that one pound weight. You can choke up or hold the head for light work. A few people will find they want something lighter for small face stamps like bar grounders, seeders and figure carving and for them the next one is a 12 ounce. Most people find they want a larger one for larger geometrics and flower centers though. That's where a 1-1/2 or 2 pounder would be that next purchase. When I was doing a lot of stamping, I looked for one hit wonders. You hit a stamp four ways with too light a maul or mallet, you just took four times longer to finish. Too heavy and you waste more energy holding it back. One controlled hit with the right size maul and go on. i used 1, 1-1/2, 2, and 2-1/2 mostly. If 12 ouncers were readily available, I'd have foregone lunch for a few weeks and that 12 ounce would have been in my lineup even in my black hole period of life. My 3# was for concho punches and that was about it. Not all mauls are the same and there are several good makers. There are at least three or four different head materials used. Different makers have different balance points. Handle shapes and materials are all over the map. Straight vs tapered is another consideration. For me in my progression - head material that transfers the force without being slippery and wears well. A little head-heavy for more of a deadfall effect and less swinging and extra arm force behind it. leather handles have more grip for me. A tapering butt on the handle gives me more rebound action when I am rocking wrist stamping like a teeter-totter. Tapered head so I can rest my elbow on the bench or keep it lower at my side if I'm not resting it. These are the reasons I used mauls from a particular maker when they became available and sell them now. Quote
CFM tsunkasapa Posted October 4, 2022 CFM Report Posted October 4, 2022 16 hours ago, Hildebrand said: @tsunkasapa what weight are the poly mallets you are using. Never weighed them, just a smallish one and a bigger one. The only time I ever worried about weight was with my framing hammers. Quote
Members FrenchMich Posted October 4, 2022 Members Report Posted October 4, 2022 I use several Mauls (I find easier than mallet, you don't need to direct the strike, it's always well oriented and the movement of the forearm is more ergonomic) I have one barry king lightweight, one from skindhuset (505 gr ; 1,11 lbs I like it, the typing is nice ), a big one (2 lbs) for big jobs and the king of mauls (for me) the Wayne Jueschke taper 1 lb. It's the ideal balance and ideal weight for froral carving. So, all that to say you, after more of twenty years of leather work my opinion is the good weight is around of 0.8 and 1 lbs. Mich' Quote
Members Gezzer Posted October 4, 2022 Members Report Posted October 4, 2022 Ya'll got me to wondering , well I now know my maul weighs 11.5 oz according to my scale . @tsunkasapa I am with you on the framing hammers Quote
Contributing Member fredk Posted October 5, 2022 Contributing Member Report Posted October 5, 2022 I found my poly mallet was too light so recently I invested in a 24oz dead-blow mallet. I've not used it much but it has made a difference Quote
Members FrenchMich Posted October 5, 2022 Members Report Posted October 5, 2022 24 Oz, it's already heavy for floral carving. For me, 20 Oz it should be better. However, it's Ok for geometric stamp like medium Basket stamp. Quote
Doc Reaper Posted October 6, 2022 Report Posted October 6, 2022 I have 8oz for tooling, I have a Tandy rawhide weighted (16oz) hammer that I’ve hade for 15 years. It was difficult to hit flat items square, the impact would be deflected if impact wasn’t spot on. then I invested in the tapered cylinder type hammer/maul and it was far easier to use than the conventional hammer type. Of the cylinder types I have weights from 5oz up to 18oz, I mostly use the one pound for stamping letters and such. As said in previous notes I choke up in different places on the handle for the desired impact. And what a hammer can’t do the one ton arbor press catches. And if the arbor press isn’t enough I use the 20 ton pneumatic hydraulic press. So I have all bases covered when it comes to stamping Quote
CFM Frodo Posted January 19, 2024 CFM Report Posted January 19, 2024 I use 2 deadfalls one is a 20 oz ball peen with a 6” handle the other is used straight up and down it is a Dpin off of a bulldozer or hid bucket 7” long the face is 1 3/4”. Quote
Members DieselTech Posted January 19, 2024 Members Report Posted January 19, 2024 I have & use 3 poly round mauls, 12oz for beveling, 16oz for most basketweave & border stamps, then I got a 24oz for my makers stamp & large geometric stamps. Wish I could find a 12oz leather stacked handle poly maul. Preferably a taper head. 28 minutes ago, Frodo said: I use 2 deadfalls one is a 20 oz ball peen with a 6” handle the other is used straight up and down it is a Dpin off of a bulldozer or hid bucket 7” long the face is 1 3/4”. Frodo is that handle in your ball peen, made out of deer antler? Thanks. Quote
CFM Frodo Posted January 19, 2024 CFM Report Posted January 19, 2024 Just now, Frodo said: Elk. Chuck sent it to me my awl and burnish tool Quote
Members jrdunn Posted January 19, 2024 Members Report Posted January 19, 2024 1 hour ago, DieselTech said: I have & use 3 poly round mauls, 12oz for beveling, 16oz for most basketweave & border stamps, then I got a 24oz for my makers stamp & large geometric stamps. Wish I could find a 12oz leather stacked handle poly maul. Preferably a taper head. Frodo is that handle in your ball peen, made out of deer antler? Thanks. Like this one? Thanks to @bruce johnson https://brucejohnsonleather.com/leather-tools-sale/new-wayne-jueschke-mauls-string-cutters-and-riveters/ Quote
Members DieselTech Posted January 19, 2024 Members Report Posted January 19, 2024 4 minutes ago, jrdunn said: Like this one? Thanks to @bruce johnson https://brucejohnsonleather.com/leather-tools-sale/new-wayne-jueschke-mauls-string-cutters-and-riveters/ Thanks I appreciate the link. Exactly what I'm looking for. 21 minutes ago, Frodo said: Them look great Frodo. Nice work on the tools. Love em. Thanks. Quote
CFM Frodo Posted January 20, 2024 CFM Report Posted January 20, 2024 @DieselTech Chuck made those for me i made the blades in this picture a cutter a skiver a mini round knife Quote
Members DieselTech Posted January 20, 2024 Members Report Posted January 20, 2024 2 minutes ago, Frodo said: @DieselTech Chuck made those for me i made the blades in this picture a cutter a skiver a mini round knife Ok thanks Frodo. Nice collection of fine looking tools there. Thanks for sharing them. Quote
Members MarshalWill Posted January 20, 2024 Members Report Posted January 20, 2024 (edited) I like mallet heads for stamping. Never got used to a round maul. The weights I like are mostly an 4 oz one I made from UHMW and a 10 oz one I bought for larger stamps. For very large stamps like a maker's stamp, I use my drill press to make an impression or, on occasion, a 28 oz Barry King mallet. For BW, like you were asking, I use the 10 oz one. In the photo: the 28 oz BK mallet, the 10 oz mallet and the 4 oz one. Edited January 20, 2024 by MarshalWill error Quote
