Danotriglide
#5 edge beveler/rounder
Good morning everybody!
Just getting back into leather working and trying to get my tools. Usually I just go to Tandy’s but I’ve moved and the nearest store is over 80 some miles away so I’ve turned to Amazon. But…..twice now I’ve ordered a #5 edge tool to round the edges of my project and twice now I get a tool that doesn’t have a radius cut it’s square and it skives. Hobby lobby has some but only small ones like #2&#3. Online at Tandy they show no #5’s. Anybody know where I can get a #5 edge tool that has a radius?
Thanks!
Edited by Danotriglide
Add pics
cant you just take one you bought and make one? mine have all converted to round through routine sharpening.
OR . . . you can take the thing from Tandy . . . a small chainsaw file . . . and make a rounded one.
May God bless,
Dwight
For a good one there's Barry King and Ron's Tools.  Both in USA.
5 hours ago, Danotriglide said:
Thanks everybody!
Actually I found one at Wally World, just have to wait and see if it’s round. If not I’ll file it round I guess.
Dano
And I forgot . . . when you do that . . . take a piece of 9/10 oz and squeeze it up about 1/8 of an inch above two pieces of a board . . . like a hamburger slipping out the side of a bun.
Take the corners off both sides of that piece of leather first . . . make the piece about a foot or so long.
Then take your jeweler's rouge . . . and get a really good coat on the leather . . . start stroking your beveler backwards from the way you normally use it.
That will both polish the heck out of the rounded tool you just made . . . and will sharpen it right good and sharp.
I sharpen all of mine on such a rig.
May God bless,
Dwight
I thought there were 2 different tools an edge bevler. and a keen edge bevler.
It's really easy to transform a straight beveler into a rounded beveler, I did it the other day and it took me 10 minutes.
Nice tip on using twine coated with rouge.  Will give that a try for stropping inside the curve.
So you did this with just a twine and rouge or file it first and clean it up with cord/rouge? My last ordered said it “rounded edges” but it too was square. I’m about to give up and go crazy…….
Thanks,
Dano
Thanks,
Dano
The square ones will still give you a round edge after you burnish it.
Thanks,
Dano
hey hey, no no I didn't do it with just the string and green clay, I did most of the work with the file and only then finished with sandpaper and string.
On 12/4/2022 at 12:14 AM, Danotriglide said:
Also….which side did you work? Left or right in my picture?
Thanks,
Dano
in the back of the tool: L
Edited by paloma
Yes, but depending on the use it can take years.
Thank you Paloma for the pics, I figured this is how you did it. I’ve tried but for some reason I can’t get the angle just right and can’t get it sharp enough to cut clean. I’ll keep picking at it I guess.
Thanks again!
Dano
yes you have to persevere and with a good round soft file it should happen.
No, if you moisten the edge and use a round profile burnisher, you will get a round edge.
I found this video helpful.  Also, there are the stropping "boards" from Wuta and others.
Multi-functional Polishing Board Sharpening Strop Tool | WUTA
yes, also but the subject of the thread is :#5 edge beveler/rounder
The POINT is you don't need a round beveler to get a round edge.
Yes, maybe, but I was just answering the question about the thread by giving a tip.
