BilyRoberto Report post Posted November 9, 2023 Hi all, I have started recently on the leatherwork, and I am using an standard cigarette lighter to cut the thread. By doing this the ending is not nice. What tool and technique do you suggest me to use to make these endings neat? Thank you Quote Share this post Link to post Share on other sites
Mablung Report post Posted November 9, 2023 Use scissors to cut the thread (extra points if you use snippers with finely-edged blades to create a clean cut to prevent fraying---I just use regular old scissors, though), down to about 1/8" length. Then use the lighter to melt the end and press the melted bit down into the other stitches. With a little practice, it's pretty easy to do very cleanly. Quote Share this post Link to post Share on other sites
SpruceMoose Report post Posted November 9, 2023 1 hour ago, Mablung said: Use scissors to cut the thread (extra points if you use snippers with finely-edged blades to create a clean cut to prevent fraying---I just use regular old scissors, though), down to about 1/8" length. Then use the lighter to melt the end and press the melted bit down into the other stitches. With a little practice, it's pretty easy to do very cleanly. This is what i do as well, but I use a blunt tip awl to press the still hot end down into the hole. One can also buy a cheap little pronged thread burner thingy, but i think a lighter and awl works fine. I assume withe the prong tool one could easily burn off the stitching when trying to burn the ends off into the hole. Quote Share this post Link to post Share on other sites
Littlef Report post Posted November 9, 2023 I just cut it off with scissors and burn it with a lighter. I've thought about getting one of the thread burners. Thread burners are not expensive, but I'm not convinced its gonna make an improvement enough to separate me from some cash. Quote Share this post Link to post Share on other sites
dikman Report post Posted November 9, 2023 Yep, cut and burn. Quote Share this post Link to post Share on other sites
tsunkasapa Report post Posted November 10, 2023 You do not say whether you are hand or machine stitching. Two totally different critters. Quote Share this post Link to post Share on other sites
fredk Report post Posted November 10, 2023 Hand sewing; sometimes I cut and burn but mostly I cut the thread tight to the item. I usually give my items a coat of soft wax mix which I polish in. The sewn threads get this too. Also, with some heavy thread I try to bring the end of the thread up between the layers, cut neat, tuck the end down and glue the edge, locking the thread in Quote Share this post Link to post Share on other sites
BilyRoberto Report post Posted November 27, 2023 On 11/10/2023 at 1:55 AM, tsunkasapa said: You do not say whether you are hand or machine stitching. Two totally different critters. Both! Nevertheless we aim to focus on hand. Quote Share this post Link to post Share on other sites
tsunkasapa Report post Posted November 27, 2023 2 hours ago, BilyRoberto said: Both! Nevertheless we aim to focus on hand. In that case, back stitch 2-3 stitches and cut flush with the surface, no flame needed. Quote Share this post Link to post Share on other sites
bladegrinder Report post Posted November 28, 2023 I use one of those battery thread burners, you have to be careful with it or you'll leave black burn marks on the leather if you hit it. while melting down the end I kind of wipe it onto the stitch next to it. I use nylon thread so it ends up being fused, nylon to nylon. might be overkill compared to a lighter but that's what I use. runs on one AA battery and goes thru them pretty quick. Quote Share this post Link to post Share on other sites
chuck123wapati Report post Posted November 28, 2023 nail clippers and no burn. pull the stitch up tight and snip it close. Quote Share this post Link to post Share on other sites
deboardp Report post Posted February 17, 2024 (edited) On 11/27/2023 at 6:46 PM, tsunkasapa said: In that case, back stitch 2-3 stitches and cut flush with the surface, no flame needed. I can't backstitch with my Cobra Class 26 - it goes sideways on me. 3 layers of veg tan, but I can spin the work 180 with the needle down and then do 2-3 stitches. Edited February 17, 2024 by deboardp Quote Share this post Link to post Share on other sites
tsunkasapa Report post Posted February 17, 2024 3 hours ago, deboardp said: I can't backstitch with my Cobra Class 26 - it goes sideways on me. 3 layers of veg tan, but I can spin the work 180 with the needle down and then do 2-3 stitches. I only hand stitch. I have a machine that I have never used...other than a place to stack stuff. Quote Share this post Link to post Share on other sites
toxo Report post Posted February 17, 2024 On 11/10/2023 at 1:02 AM, fredk said: Also, with some heavy thread I try to bring the end of the thread up between the layers, cut neat, tuck the end down and glue the edge, locking the thread in If being ultra picky there's no reason why this technique can't be used when machine sewing. Just leave enough thread to put a needle on. Quote Share this post Link to post Share on other sites
