I've google it every which way but loose and can't find instructions on how to put the larger hand wheel on the singer 99.:dunno: does anyone have instructions on how to do this. thanks
I am assuming you mean the original sized hand-wheel that came on the machine. This video should help with the removal and insulation:
kgg
Moved your post to leather sewing machines.
kgg
Well no, actually looking to replace the  original hand wheel with the larger spoked hand wheel. Maybe the process is the same, but I'm worried about the bobbin rewind assembly , don't know it that is the same set up with the larger hand wheel. Don't want to take it all apart and find out its not the same.
I changed mine. I found that I have to change the bobbin winder set up as well. I've not bothered to do that yet
is the change over to the lrg wheel easy and can it work ok with out the bobbin winder change, just buy pre wound bobbins
Edited by Bert03241
Get a small screw (10/32) 1" long with a nut & wind bobbins with a drill.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
yes and yes. The bobbin winder wheel has no place to run on
Use another machine to fill the bobbins
20 hours ago, Bert03241 said:
Well no, actually looking to replace the  original hand wheel with the larger spoked hand wheel.....
FWIW:  Use a 9-spoke balance wheel for your conversion.  In my experience, most (if not all) 6-spoke balance wheels don’t work on the 99 because the hub is longer.
CD in Oklahoma
"I sew, I sew, so it's off to work I go....."
My sewing machines:
Adler 205-370 (Hand Crank), Adler 205-64 (Hand Crank), Consew 226 (Clutch/Speed Reducer), Singer 111G156 (Hand Crank or Clutch), Singer 111W153 (Clutch), Singer 20U33 (Clutch), Singer 78-3 Needlefeed (Treadle), Singer 20U (Treadle), Singer 29K70 (x2) (Both Treadle/Hand Crank), Singer 96-40 w/Darning Foot (Treadle), Singer 31-15 w/Roller Foot (Treadle), Singer 31-15 (Hand Crank), Singer 16-41 (Treadle), Singer 66-1 (Treadle/Hand Crank), Singer 201K4 (Treadle/Hand Crank), Singer 216G Zigzag (Treadle/Hand Crank), Singer 319W (Treadle)
OK I have the 9 spoke wheel so I can do the change over and it will work OK? with out the bobbin .?  So if I follow that video I'll be OK ????
