Members PAMuzzle Posted February 24, 2024 Author Members Report Posted February 24, 2024 16 hours ago, DieselTech said: If they are going to fly with the case/boxes, wont drilling holes mess the pressure system the box was designed for doing. Plus it just introduces a place for water to get into the box/case & takes away from it being a water tight case/box. Exactly what I was thinking. Quote
Members PAMuzzle Posted February 24, 2024 Author Members Report Posted February 24, 2024 Thanks all. I don’t want to drill through for rivets. I will try to get a piece of polypropylene and try gluing. Quote
toxo Posted February 24, 2024 Report Posted February 24, 2024 20 minutes ago, PAMuzzle said: Exactly what I was thinking. Not to influence your thinking but aircraft and boats have been riveted together for quite a while now. Quote
Members DieselTech Posted February 24, 2024 Members Report Posted February 24, 2024 The only reason I suggested not to drill any holes in it is, I know how expensive the pelican style boxes/cases can be. & to me drilling holes in the box just ruins the integrity of the box/case. Quote
Members purplefox66 Posted February 24, 2024 Members Report Posted February 24, 2024 But using rivets is okay Quote
Members dikman Posted February 24, 2024 Members Report Posted February 24, 2024 Personally I wouldn't want to drill holes in those cases unless it was a last resort, but it is probably the only way of making a permanent attachment. Gluing pp-type plastics is a real pain as not much will stick to it, you would normally have to use some sort of solvent-type glue but that doesn't tend to work too well with leather (other than contact cement). Barge cement will work, but the question is how long will it stay attached. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Contributing Member fredk Posted February 24, 2024 Contributing Member Report Posted February 24, 2024 I wouldn't attempt to cover those boxes but I'd use double-side sticky tape. I have sheets of double-sided sticky which stick stronger than any glue and it is water proof Quote Al speling misteaks aer all mi own werk..
