I have seen some plans posted in past but the links are all gone.  Looking to build a stiching horse - need some plans to work off of.  Any help appreciated.
Quite a few on here have made their own and I don't think they used plans (I didn't). The basic concept is pretty simple, just look at a few photos and decide what type you want to build. If you want to build one of those old-time types that you sit on then that is a different kettle of fish as they are a bit more complex (but still doable).
If you buy this book. There is 4-6 pages with every measurement, nut, bolt, screw needed to make a stitching pony.
I have a PDF of plans I found somewhere online, just for occasions like this, where somebody is looking for plans:
https://djole.altervista.org/djole/Publications/Leather/S/StitchingHorse.pdf
I used the plans in an old book called "farm woodwork": https://ia802605.us.archive.org/32/items/farmwoodwork00roeh/farmwoodwork00roeh.pdf
You can see the final result of my build here:
The only thing I am not so happy about is that I made the strap for tightening the clamp out of some too soft veg tan leather. I should have used something better for making the strap. It resulted in that the holes started to tear in the strap when I used it. I have later repaired it with an old piece of strap from a saddle.
The stitching horse work very well and the instructions are easy to follow.
Have fun building whatever model you choose.
41 minutes ago, Northmount said:
The link kept timing out on me.  I knew I had a copy so went looking for it.  Here it is, small download for you all.  @rdahlinspeedboy77
Farm Woodwork Stitching Horse.pdfFetching info...
Super :-)
I think I have the pdf somewhere as well, but at the moment we are on the ship, so even thinking of attaching a file is like asking for trouble.
Brgds Jonas
2 hours ago, ChristianPo said:
First post here:)
A german guy built a small and simple one which I used as an instruction for my own built. Many drawings, photos and even a video here: https://www.rabomslederkiste.de/naehpony-wie-wird-es-gebaut-und-worauf-ist-zu-achten/
Greets, Christian
That's a pony not a horse.
I built this pony with scrap laying around the garage.  Works quite well.
https://www.instructables.com/Simple-and-Cheap-Stitching-Pony/
Or look at this:
http://rogueleather.com/2010/11/project-stitching-horse/
There is a set of plans here:
I added notched aluminum plates to my Weaver stitching horse, based on a suggestion for sewing straps in the Stohlman hand sewing book.  I find this very handy for clamping odd shapes, such as sewing a buckle and fixed loop on the end of a strap, or sewing the edge of a raised leather piece.  The space between the tabs works like an ordinary clamp but I often suspend the work between the tabs when I have different thicknesses and odd shapes.
thanks for the recommendation - will look for this book !
If you wanted me to I could copy them & send the stitching horse plans.
