DieselTech Report post Posted March 26, 2024 (edited) Guys & gals I'm curious if any of you know what clone model of sewing machine this would be? It says it's a large shuttle bobbin model if that makes a difference in identifying. Is there a abundance of presser feet for this model? To me it looks like a cobra 26 or a consew 227r. Does anybody got any insight on this style/model of sewing machine? I would like to set this up for 138 thread only. Thanks. Edited March 26, 2024 by DieselTech Quote Share this post Link to post Share on other sites
dikman Report post Posted March 26, 2024 I'd say it's a clone of a Pfaff 335 (the 335 in the model number is a giveaway). It's also a binder, so if you want to use it as a "normal" machine you will have to change the feet and the needle plate (and possibly feed dog?). It also probably has the backwards/forwards feed dog, not the usual oscillating feed dog. Kwok Hing should have some feet, plates etc, they did for my old-casting 335. Quote Share this post Link to post Share on other sites
DieselTech Report post Posted March 27, 2024 2 hours ago, dikman said: I'd say it's a clone of a Pfaff 335 (the 335 in the model number is a giveaway). It's also a binder, so if you want to use it as a "normal" machine you will have to change the feet and the needle plate (and possibly feed dog?). It also probably has the backwards/forwards feed dog, not the usual oscillating feed dog. Kwok Hing should have some feet, plates etc, they did for my old-casting 335. Ok thanks. What is this pfaff 335 like compared to a cobra class 26 or consew 227r? What is the cobra class 26 machine based off of? Thanks. Quote Share this post Link to post Share on other sites
kgg Report post Posted March 27, 2024 3 hours ago, DieselTech said: What is the cobra class 26 machine based off of? The Cobra 26 I think is sort of a clone of the Juki LS-1341 but with a Alder hook/ bobbin assembly. The 335 based machines are less capable then either the Cobra 26 or the Consew 227R. kgg Quote Share this post Link to post Share on other sites
DieselTech Report post Posted March 27, 2024 2 hours ago, kgg said: The Cobra 26 I think is sort of a clone of the Juki LS-1341 but with a Alder hook/ bobbin assembly. The 335 based machines are less capable then either the Cobra 26 or the Consew 227R. kgg Thanks kgg. I just recently spent $4000 on a cobra class 4, & now I'm trying to cheap out on a smaller machine. Something I can set up with 138 thread & not break the bank. Quote Share this post Link to post Share on other sites
dikman Report post Posted March 27, 2024 This machine is designed primarily as a binder, only get this if you specifically want a binder. I suggest you keep looking. Quote Share this post Link to post Share on other sites
kgg Report post Posted March 27, 2024 4 hours ago, DieselTech said: I'm trying to cheap out on a smaller machine. Something I can set up with 138 thread & not break the bank. Like @dikman has suggested I would suggest you look at Class 341 machines for cylinder arms: New: Class 341 clone machines ----- Cowboy CB341, Techsew 2750, Kobe LS-1341 Used: Juki LS-341, Juki LS-1341 or clones kgg Quote Share this post Link to post Share on other sites
Wizcrafts Report post Posted March 27, 2024 14 hours ago, DieselTech said: Thanks kgg. I just recently spent $4000 on a cobra class 4, & now I'm trying to cheap out on a smaller machine. Something I can set up with 138 thread & not break the bank. I wrote a blog article a few years ago that can save you tons of money. You just need to dumb down your Cobra Class 4. This doesn't require any new hardware; just some careful adjustments and the use of the narrow slotted throat plate you probably got with your Cobra Class 4, and some thin system 7x3, or 7x4 needles from @CowboyBob. There are two members of LWN who make narrow feed dog/throat plate sets and even narrow presser foot sets. Here is the narrow set that was first made by our member, @RockyAussie - in Australia. Here are some narrow throat plate/feed dog sets that are made in the USA: https://heprecision.com/ - by our member: @Patrick1. Thank me later! Quote Share this post Link to post Share on other sites
DieselTech Report post Posted March 27, 2024 1 hour ago, Wizcrafts said: I wrote a blog article a few years ago that can save you tons of money. You just need to dumb down your Cobra Class 4. This doesn't require any new hardware; just some careful adjustments and the use of the narrow slotted throat plate you probably got with your Cobra Class 4, and some thin system 7x3, or 7x4 needles from @CowboyBob. There are two members of LWN who make narrow feed dog/throat plate sets and even narrow presser foot sets. Here is the narrow set that was first made by our member, @RockyAussie - in Australia. Here are some narrow throat plate/feed dog sets that are made in the USA: https://heprecision.com/ - by our member: @Patrick1. Thank me later! Thanks. @Wizcrafts I did buy all the narrow needle plates & feed dogs from @Patrick1 except for the #20 plate & feed dog. I was hoping maybe I could just swap between the #23 & #25 plates & make a few minor adjustments to swap between 138 & 277 thread. I've read about a few members saying they got their class 4 machines setup, where all they do is a needle & thread change to swap thread sizes. I have been trying to find articles on here about adjustments from 1 thread to the next on the cobra class 4, but I havent had much luck. Thanks for the link. I will take any advice given. Quote Share this post Link to post Share on other sites
AlZilla Report post Posted March 28, 2024 17 hours ago, DieselTech said: Thanks kgg. I just recently spent $4000 on a cobra class 4, & now I'm trying to cheap out on a smaller machine. Something I can set up with 138 thread & not break the bank. I have a 111W153 set up with 138. I have my eye out for something with reverse but in the meantime, it serves my needs. Quote Share this post Link to post Share on other sites
