bladegrinder Report post Posted March 28, 2024 Just finished this pancake holster for a .40 Smith & Wesson Shield. 8-9 oz Herman Oak Quote Share this post Link to post Share on other sites
purplefox66 Report post Posted March 28, 2024 That is a very nice holster Quote Share this post Link to post Share on other sites
DieselTech Report post Posted March 29, 2024 That is Sexy! Nice work. Looks great! May I ask if a pattern was used? If so who's pattern. Thanks. Quote Share this post Link to post Share on other sites
bladegrinder Report post Posted March 29, 2024 1 hour ago, purplefox66 said: That is a very nice holster Thanks purplefox! 30 minutes ago, DieselTech said: That is Sexy! Nice work. Looks great! May I ask if a pattern was used? If so who's pattern. Thanks. Thanks Diesel, I drew up the pattern for it. Quote Share this post Link to post Share on other sites
Littlef Report post Posted March 29, 2024 That is nice! Quote Share this post Link to post Share on other sites
DieselTech Report post Posted March 29, 2024 1 hour ago, bladegrinder said: Thanks purplefox! Thanks Diesel, I drew up the pattern for it. Thanks. So is it lined with something like calf skin or something else. Thanks. Appreciate the info. Quote Share this post Link to post Share on other sites
bladegrinder Report post Posted March 29, 2024 No lining, just 8-9 oz. Herman Oak. it could be lined, just by using maybe 6-7 oz. with the liner to make it 8-9. I started making holsters using 6-7 because that's what I had on hand for my knife sheaths and it works but I think 8-9 is just right for holsters. I wet mold my holsters then put them in a PID controlled toaster oven on top of a piece of thin card board at 150 for half an hour, then flip it for another half hour and on and on till it's close to good and dry but not to much, not making jerky here. take it out and let it rest and dry till the next day. Quote Share this post Link to post Share on other sites
DieselTech Report post Posted March 29, 2024 4 minutes ago, bladegrinder said: No lining, just 8-9 oz. Herman Oak. it could be lined, just by using maybe 6-7 oz. with the liner to make it 8-9. I started making holsters using 6-7 because that's what I had on hand for my knife sheaths and it works but I think 8-9 is just right for holsters. I wet mold my holsters then put them in a PID controlled toaster oven on top of a piece of thin card board at 150 for half an hour, then flip it for another half hour and on and on till it's close to good and dry but not to much, not making jerky here. take it out and let it rest and dry till the next day. Thanks for the info. Yeah I might make a drying cabinet with a few low wattage bulbs wired inside it. Quote Share this post Link to post Share on other sites
bladegrinder Report post Posted March 29, 2024 I've never used anything like that, I use the PID oven I have for tempering knife blades, it holds a temperature within + - 3 degrees. at 150 for a couple hours it really hardens up the leather, when you put the gun in it almost snaps in place. Quote Share this post Link to post Share on other sites
Hags Report post Posted March 29, 2024 Very nice work! Quote Share this post Link to post Share on other sites
bladegrinder Report post Posted March 29, 2024 Thanks Hags! Quote Share this post Link to post Share on other sites
DieselTech Report post Posted March 29, 2024 28 minutes ago, bladegrinder said: I've never used anything like that, I use the PID oven I have for tempering knife blades, it holds a temperature within + - 3 degrees. at 150 for a couple hours it really hardens up the leather, when you put the gun in it almost snaps in place. Yeah I want to make a PID knife oven as well, just had not really had the funds. Them good PID controllers are not cheap. Quote Share this post Link to post Share on other sites
usmc0341 Report post Posted March 29, 2024 Beautiful holster! Quote Share this post Link to post Share on other sites
Bert03241 Report post Posted March 30, 2024 I just use a cheap Walmart toaster oven. It works just fine, low heat for an hour or so. No problems .Perfect control of the heat is not necessary. These toaster oven hold the temp pretty close to 150 Quote Share this post Link to post Share on other sites
bladegrinder Report post Posted March 30, 2024 The one I have had a minimum 30 degree swing depending on the outside air temp before I wired it with a PID. I’m guessing any oven would do but this was set up primarily for tempering hardened knife blades, which require pretty accurate temperatures. When I gutted this thing out I found the temperature sensor wasn’t even in the oven, it was just behind the controls. frankly I have no idea how they thought that was going to regulate the temp at all, it was exposed to ambient air. Quote Share this post Link to post Share on other sites
Bert03241 Report post Posted March 30, 2024 What can I say ,I've done dozens of knife sheaths and holsters never had a problem. Just use low heat setting . Quote Share this post Link to post Share on other sites
bladegrinder Report post Posted March 30, 2024 Never said there was a right way or wrong way, just the way I do it. A light box would probably work to, just take longer I suppose. Quote Share this post Link to post Share on other sites
Chipster99 Report post Posted March 31, 2024 That’s a beauty for sure! Quote Share this post Link to post Share on other sites
AlZilla Report post Posted March 31, 2024 Very skilled stitch work. I recall you saying you used a Cobra Class 4 - it looks like at the beginning of your stitch line you must start with 2 or 3 stitches backtacking to the beginning? Both ends appear to be double sewn, if you started at the beginning, backtacked and then went forward again, you'd have a bulky triple stitch. Am I seeing it right? Quote Share this post Link to post Share on other sites
bladegrinder Report post Posted March 31, 2024 I back stitch two stitches then switch to forward, continue to the end, then back stitch two stitches, there’s no triple stitch. Quote Share this post Link to post Share on other sites
bladegrinder Report post Posted March 31, 2024 I just carefully measure my stitch spacing so I know where the first back stitch will end up, put a tiny start mark on the leather and drop the needle on it, then back two then forward. Quote Share this post Link to post Share on other sites
AlZilla Report post Posted March 31, 2024 2 hours ago, bladegrinder said: I just carefully measure my stitch spacing so I know where the first back stitch will end up, put a tiny start mark on the leather and drop the needle on it, then back two then forward. The varying stitch length is the challenge for me. Practice, practice practice... Quote Share this post Link to post Share on other sites
Frodo Report post Posted March 31, 2024 2 hours ago, Frodo said: IMG_0340.heicUnavailable Looking for the same ole same ole or different ? You said maybe make other things like pouches, let’s combine those 2. a knife sheath with wet stone pouch IMG_0059.heicUnavailable Quote Share this post Link to post Share on other sites
dikman Report post Posted March 31, 2024 On 3/29/2024 at 1:42 PM, DieselTech said: Yeah I want to make a PID knife oven as well, just had not really had the funds. Them good PID controllers are not cheap. Cheaper if you make your own, I've built three so far. Lots of information on the castboolits forum. Quote Share this post Link to post Share on other sites
DieselTech Report post Posted March 31, 2024 18 minutes ago, dikman said: Cheaper if you make your own, I've built three so far. Lots of information on the castboolits forum. Thanks. I'll check it out. I havent been to their site in a while anywho. Quote Share this post Link to post Share on other sites
