Been thinking bout getting one of these. Do they heat up instantly? Have a soldering iron that does that but far too bulky. Is there a preference? Longer lasting battery etc?
I think the thread zapper ll is the better of the models offered. I heard the tips can eventually burn up. But replacement tips are available.
I just bought one. The tip takes about 5 second to heat up but it really never gets as hot as a soldering iron, just hot enuff to melt the thread. Its light-weight and handy. I intend to try it on my model aeroplanes as well, for trimming the rigging
I’ve been using a zapper that my doctor uses for skin tags.  Heats up instantly and works like a charm.  I can’t find this exact product online, but if you search medical skin tag remover you’ll find them.
Learnleather.com
As fredk stated, it takes only a few seconds to heat up.
Others have mentioned having to replace the tip, but I have had mine for four years now and am still using the same tip.
Here is a link to another thread discussing the battery to use. It seems the type of battery used has a significant impact on longevity.
  On 6/9/2024 at 6:20 PM, fredk said:
I just bought one. The tip takes about 5 second to heat up but it really never gets as hot as a soldering iron, just hot enuff to melt the thread.     . . .
Expand
I just checked the battery I used to check that the zapper is working; its only about 75%, not full strength. That will make a difference to the time to heat and the heat
  • CFM
I'll revise my earlier statement; With a fresh battery heat-up was instant and the tip went red hot.  Perhaps its hot enuff to melt solder.  The unit comes with a protective cover which covers the tip and the switch as well and prevents it being accidentally pressed
Edited by fredk
I used a thread zapper but ran out of spare tips, they are fragile. Happened upon a post where a gutta percha cutter used in dental work was being used to melt the thread. I bought one off of Amazon for about $20 and so far happy with it. The tips are beefier compared to the thread zapper I have.
Edited by CdK
Leather work machines I own: Thor 1341, Thor 441, LSZ-1 clone, 801 bell skiver,  Tinker's Delight Shoe Patcher. (Tippmann Boss was re-homed.)
Expand
I use the ThreadZap II to burn/trim all of my thread. They eat up AAs pretty quickly but the convenience is worth it. I find that mine heat up almost instantly to hot enough to trim any sewing thread I use.
As others have said the tips are pretty fragile and they WILL eventually burn up but they're cheap enough and easy to replace from Amazon.
I use the Thread zap too but I got mine from Temu. It's one third the price for the same thing but it takes about 8-10 days to arrive. It's working fine and mine came with a spare tip.
I always compare products and prices between Amazon and Temu. More and more Temu items seem to be appearing on Amazon at  inflated prices.
Edited by SUP
Learning is a life-long journey.
Expand
@ArkieNewbieI needed to add, the gutta percha cutter comes with a base in which it recharges in. Win-win as batteries have become expensive.
I stitch several holsters at a time.  So I have a soldering iron plugged up on the nightstand while I stitch.  Got tired of fighting with the zappers and switched to the soldering iron.  If I was only doing one, the zapper might be better.  But sitting down and stitching 3-4 at a time, the soldering iron wins.
