  • Replies 21
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
You can get a nice edge on the rotary blades with this sharpener.
For all the use my 60mm knife gets I can buy over 60 blades for the price of that sharpener (£8 per 10). That will last me several years
  • 2 weeks later...
On 7/12/2024 at 5:44 PM, fredk said:
I don't bother sharpening the 60mm blade in my knife
a. I'm rotten at sharpening
b.a new blade is fairly cheap
  c. those blades are wicked sharp, and the risk of bleeding all over your workbench is fairly high!
Utility knives are much easier to sharpen, but rotary blades I'd just replace, and I don't use them nearly as often as my utility knife.
  • 2 months later...
I put the blade on a bolt and tighten a nut against it and put it in a drill and spin it on the edge of a stone. Works pretty good once you find the right angle.
That is an excellent idea. I may try it
  • 11 months later...
I know this is a year old, but I use the $20 rotary cutter sharpener from Wawak to extend the blade life https://www.wawak.com/cutting-measuring/rotary-cutting-tools/rotary-blades/tri-sharp-dual-rotary-blade-sharpener/
That is a reasonable price
Similar to how I do it. I machined an arbor for the 60mm blades which I spin in a lathe and sharpen using a post grinder. I use a very fine grit stone which is followed up with a leather strop. I have about 20 blades and I sharpen a batch when about 1/2 of them need sharpening. Yeah, I know these blades are not pricey but my Dutch genetics won't allow me to waste money.
Leather work machines I own: Thor 1341, Thor 441, LSZ-1 clone, 801 bell skiver,  Tinker's Delight Shoe Patcher. (Tippmann Boss was re-homed.)
  • 3 weeks later...
:lol:
