Members dikman Posted February 3 Members Report Posted February 3 (edited) I've made a couple of head knives from a circular saw blade and while they work they're fairly big (plus I need to grind the bevels down a bit more). So I thought "why not make a smaller half head knife?". A guy on youtube called Red Beard made one and kindly made the pattern available so I pinched it. Looking around for a bit of steel I found a panel saw I'd bought for $2 but it wouldn't cut straight and I couldn't be bothered resetting and sharpening the teeth so I just hung it in the forge. I tried a centre punch on it, which it promptly blunted! Hmm, might have possibilities. I made an assumption that the Chinese factory would likely have used a simple carbon steel, with no differential hardening for the teeth, to make it cheaply. So I cut a little piece off annealed it and then heated it to non-magnetic and quenched in water. Bingo, the file skated across it, looked like I was on a winner. I cut the shape out with an angle grinder, annealed it and ground to shape on the belt grinder, then heated and quenched in oil. To temper it I ran a gas torch carefully along the edge to just get a tinge of colour, good enough for this experiment. The deer antler proved problematic as when I started grinding it became apparent there was going to be a lot of pith showing. At that point I decided not try and make it perfect, just functional. I wanted it to rest against the palm of the hand so that ruled out fitting an end cap. The blade was carefully sharpened on the belt grinder, then a paper wheel and finally a strop. I have some leather from an old saddle so it's dirty and stiff but it cut it without too much trouble and breezed through softer veg tan. There's still quite a bit of the saw left so I might have another go once I can figure out how to better utilise the antler that I have. Edited February 3 by dikman gramma Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members DieselTech Posted February 3 Members Report Posted February 3 Looks great. Nice craftsmanship. Quote
Members Gezzer Posted February 3 Members Report Posted February 3 That looks like it would fit the hand VERY NICELY !!!!!!!!!!! Quote
Members dikman Posted February 3 Author Members Report Posted February 3 Thanks guys. The craftmanship isn't that good on the handle (fortunately you can't see it ) next time should be better as I'll give more thought to the antler. I wanted this to fit INTO the palm as it makes it easier to push and control, and with a stumpy handle I can also hold it like a stabbing implement and cut by pulling it towards me. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members TomE Posted February 3 Members Report Posted February 3 Looks like a handy knife for tight places. Keep us posted. Quote
kgg Posted February 3 Report Posted February 3 10 hours ago, dikman said: I've made a couple of head knives from a circular saw blade Very nicely done and a great use for those old circular saw blades. What did you use to cut out the shape of the old saw blade? kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
toxo Posted February 3 Report Posted February 3 10 hours ago, dikman said: Showing some skills there dikman, well done. I find the term "head knife" confusing. When following a pattern I find it difficult to use any knife that I have to drag apart from a fine pointed utility type because my hand seems to get in the way. I note that some people hold them like a dagger and drag them. Doesn't work for me. I do have a quarter round one that I quite like because it has quite a lot of blade after the curve so I can push it and still clearly see the line. Not so good in tight corners but I have other knives for that. Well done again. I always think antler/bone/horn handles look great. Quote
Members SUP Posted February 3 Members Report Posted February 3 (edited) Wow! That looks appealing and fits so well in your hand. I'm sure it makes working with it much more comfortable! And love that handle. Edited February 3 by SUP Quote Learning is a life-long journey.
CFM chuck123wapati Posted February 3 CFM Report Posted February 3 dandy lil knife!! I like it alot. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members Mulesaw Posted February 3 Members Report Posted February 3 Antler and copper rivets look SO good in my opinion, and the size and shape of the blade seems to really complement the entire knife. Well done!! Quote
Members dikman Posted February 3 Author Members Report Posted February 3 9 hours ago, kgg said: Very nicely done and a great use for those old circular saw blades. What did you use to cut out the shape of the old saw blade? kgg Angle grinder with a cut-off wheel. Toxo, I agree, head knife seems an odd term, given the shape of the blade. I've also seen this particular shape referred to as a bird's-head knife, which seems more fitting. It's a funny thing to use as I thought it would work by pulling towards me and using the large curved part but it just doesn't like to cut using it like that, very strange. It works better by using the pointed section. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members jcuk Posted February 4 Members Report Posted February 4 11 hours ago, dikman said: Angle grinder with a cut-off wheel. Toxo, I agree, head knife seems an odd term, given the shape of the blade. I've also seen this particular shape referred to as a bird's-head knife, which seems more fitting. It's a funny thing to use as I thought it would work by pulling towards me and using the large curved part but it just doesn't like to cut using it like that, very strange. It works better by using the pointed section. Nice work on your knife, its also called a single head knife which seems more apt to me when you look at a double head knife they are different to a round knife. Hope this helps JCUK Quote
Members dikman Posted February 4 Author Members Report Posted February 4 Single head knife - yeah, I can live with that. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
BruceGibson Posted February 4 Report Posted February 4 Very nice job! I'm a bit of a round knife/head knife junkie, so I can read this stuff all day. Quote "Don't squat with your spurs on." www.GibsonLeather.com
Members dikman Posted February 5 Author Members Report Posted February 5 Thanks mate, when I started leatherwork and came across head/round knives I thought what a strange shape for a knife. Then it slowly got weirder as I kept coming across all manner of variations in their design. Fascinating. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members dikman Posted February 5 Author Members Report Posted February 5 Bruce, I google-searched head knife and then round knife then clicked on images - it's amazing the variations out there! It's given me a couple of ideas.......which raises the question just how many round knives does a person need? Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Contributing Member fredk Posted February 6 Contributing Member Report Posted February 6 (edited) 5 hours ago, dikman said: .......which raises the question just how many round knives does a person need? One can never have enuf. One each of different styles for the different cuts Loverly craftsmanship on the birds head knife Edited February 6 by fredk Quote Al speling misteaks aer all mi own werk..
