Members Edsbear Posted January 8 Members Report Posted January 8 Hi, I have a Brother LS-B837 industrial machine and added a sevo motor which is great apart from when starting to sew, the motor doesn't come in slow and smooth like the old clutch motor used to. When its running its slow enough but would like a smooth start instead of it jumping straight into the slowest speed which is quite slow. Does anyone know of a mod that will acheive a smooth slow start like a clutched motor does Thanks Quote
Members fibersport Posted January 8 Members Report Posted January 8 1) change the motor pulley to the smallest you can find, usually 45mm 2) go with a larger pulley substituted for the handwheel 3) speed reducer 4) I tried 1 and 3 above, ended up getting a different servo motor that would start at 50 rpmand not 200 or 300, game changer - Quote
Members Edsbear Posted January 8 Author Members Report Posted January 8 Thanks for the info, does your new motor creep in like a clutch motor Quote
kgg Posted January 8 Report Posted January 8 (edited) 2 hours ago, Edsbear said: When its running its slow enough but would like a smooth start instead of it jumping straight into the slowest speed The main difference is a clutch motor is running at full rpm's (1450 or 1750) as soon as you turn the power on and like a manual transmission in a vehicle you ease the on clutch. The servo motors don't spin until you depress the "go" pedal. All servo motors have a "startup jump" with the brushless typically having a more noticeable "jump" then the brushed servo motors. You can reduce this somewhat by reducing the pulley on the servo motor, installing a speed reducer and buying a better quality servo motor. Typically the more internal coils the servo motor has the less "jump" experienced but check the startup rating of the servo motor a lot of the cheaper ones have a 500 rpm rating. kgg Edited January 8 by kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Members Constabulary Posted January 8 Members Report Posted January 8 (edited) believe it or not - I run a JACK 563 servo (actually 2 of em) for many years and just recently I bought a fxcking cheap Chinese servo (for under 70€ few month ago incl shipping) and it behaves and performs way batter than the Jack - not kidding. It starts at 200 rpm and I can dial down to 100 but than it makes strange sounds. https://de.aliexpress.com/item/1005007257363563.html price on my side of the pond is 88.99€ now incl shipping (Warehouse in Germany). The Jack quality is better, thats for sure but this cheap sucker just performs better. I however have added a speed reducer too, better too slow than too fast and you still have enough end speed. But to each his own... Edited January 8 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
AlZilla Posted January 8 Report Posted January 8 I have read on here that the brushed servos start from zero and have better low end torque. Verify this for yourself! I have a few brushless servos, one of which starts at 100 rpms. With a 45mm motor pulley, a 6"/2" speed reducer and the stock 3.5" machine pulley, I have a bottom end of 11 stitches per minute. You'd never really sew that low but it gives me a slow start with good control and torque. Still, the brushless motors increase in increments of 100 rpms, whereas the brushed versions apparently increase smoothly. When I need another servo motor, I think it'll be a brushed version. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
Members fibersport Posted January 8 Members Report Posted January 8 11 hours ago, Edsbear said: Thanks for the info, does your new motor creep in like a clutch motor Not exactly creep but the ramp up speed is so slow it almost feels like it. The creep you mention is what I would call slip. With my motor and synchronizer, it's set up where I can get one stitch per tap on the treadle. I think buried down in the settings, I can adjust the speed as well. I don't want others to think I'm promoting one brand of motor, but if you search in my previous posts and then do a little research, you can find out more details from others to see the motor in action. After that, then you can make your own decision. Quote
Moderator Wizcrafts Posted January 8 Moderator Report Posted January 8 16 hours ago, Edsbear said: Hi, I have a Brother LS-B837 industrial machine and added a sevo motor which is great apart from when starting to sew, the motor doesn't come in slow and smooth like the old clutch motor used to. When its running its slow enough but would like a smooth start instead of it jumping straight into the slowest speed which is quite slow. Does anyone know of a mod that will acheive a smooth slow start like a clutched motor does Thanks If you can't tame your digital servo motor, consider replacing it with an analog model that has brushes. The Consew CSM-550 is a perfect replacement. I use this type of servo motor, under different brand names over the years, on all of my walking foot machines, including my huge Cowboy cb4500. Servo motors with brushes like the CSM-550 start at zero rpm, but with very low torque at the minimum speed setting. They gradually increase their starting torque as you turn the speed knob a little higher. Once in motion, you can back off to maintain your preferred speed. Adding a speed reducer can double or triple the torque. Machines with this motor and a speed reducer can start turning over at less than one stitch per second and punch through whatever is under the foot/feet. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members beefy Posted January 9 Members Report Posted January 9 (edited) Something I've only heard mentioned once is the use of a VFD (variable frequency drive) for a 3 phase synchronous motor. The guy claimed the control with this setup totally outshines any servo motor. You can get these drives with single phase input and variable frequency 3 phase output, so you don't need a 3 phase supply to run a 3 phase motor. These drives are often used in industry and have many adjustable settings. Some that may be of interest are: Current limit - this will limit the torque of the motor and could be used as an electronic safety clutch. No need for a mechanical clutch. Max speed - these drives go from 0 hz to a frequency you would not want to run your machine at LOL. However, the max frequency can be set. External braking resistor option to reduce stopping time. This is a guess but I bet they also have a ramp up option which will be adjustable. Likewise my guess is they will have a ramp down option although this may not be wanted/needed. Probably some other settings that would be useful. Google and find a user manual and you'll get an idea. Something I should add is that I've heard running at very low rpm can cause motor heating as the internal fan of the motor is not doing anything useful. I'll leave anyone interested to do further research on that one. However, if the current limit is turned down and thus the current is low relative to the normal operating current of the motor, perhaps this heating effect will not be of any concern. Edited January 9 by beefy Quote
Members dikman Posted January 9 Members Report Posted January 9 There have been quite a few posts on here regarding using VFD's and yes, it can be done, along with using DC motors and gearboxes. There is, of course, quite a bit more involved than simply installing a servo but it can be done. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
